Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problem implementing content provider for a table viewer
Re: problem implementing content provider for a table viewer [message #439319 is a reply to message #439233] |
Fri, 09 July 2004 14:03 |
Paul E. Keyser Messages: 878 Registered: July 2009 |
0) Think of the ContentProvider as being rather like the "Subject"
(patterns sense) or "Model" (MVC-sense) of the Viewer.
1) For TableViewer, one must provide not IContentProvider, but
IStructuredContentProvider
2) You will also need to provide a LabelProvider, in particular, one
that implements ITableLabelProvider
3) Whether or not the method-name makes sense is a question I'll evade;
but in fact, within inputChanged() you should take the third parameter,
usually called "newInput", and do something with it -- that is the input
value that you set via Viewer.setInput(); in particular, you should use
it to return something suitable in the method getElements() of the
interface IStructuredContentProvider ...
HTH,
Paul
Paul Davis wrote:
> I am getting an assertion exception trying to add a content provider to a
> TableViewer with the following code:
> TableViewer tv = new TableViewer(new Table(c,SWT.NONE|SWT.SINGLE
> SWT.H_SCROLL|SWT.V_SCROLL|SWT.FULL_SELECTION));
> tv.setContentProvider(new IContentProvider(){
> public void dispose() {}
> public void inputChanged(Viewer viewer, Object arg1, Object arg2) {}
> Also, I am confused about how the IContentProvider is supposed to provide
> content.
> inputChanged doesn't seem like a method name to get the initial content.
> Should I just manipulate the SWT control directly?
> thanks
Re: problem implementing content provider for a table viewer [message #439323 is a reply to message #439319] |
Fri, 09 July 2004 17:28 |
Paul Davis Messages: 11 Registered: July 2009 |
Junior Member |
Thank you Paul,
Using the other interface works great. It even makes sense, unlike (as I
stated before) the 'required' one didn't.
I think I see the design decision that resulted in having this require a
different interface than the compiler requires. It would be nice if the
javadocs would inform those poor ignorant API consumers like myself.
At any rate, thank you very much. I now have a new entry for my notebook.
> HTH,
> Paul
>> content.
>> thanks
Re: problem implementing content provider for a table viewer [message #439324 is a reply to message #439319] |
Fri, 09 July 2004 17:43 |
Junior Member |
Ok, maybe I'm not "getting it".
So, I've implemented getObjects to return an array of strings.
However, nothing ever shows up in the table.
If the IStructeredContentProvider is the model in MVC, and the TableViewer
is the controller, how do I get the View to look like the Model?
> HTH,
> Paul
>> content.
>> thanks
Re: problem implementing content provider for a table viewer [message #440229 is a reply to message #439324] |
Mon, 26 July 2004 22:47 |
Um, possibly silly question -- did you call the TableViewer
instance-method "setInput()"? And did you pass in to that method some
object that your IStructureContentProvider implementation of
"inputChanged()" knows what to do with, when it receives that same
object as "newInput"? (Or are you always returning the same String[]
from the getElements() method?)
If you did all that, you may need to call the "layout()" method on the
Composite that hold the Table of your TableViewer.
If that doesn't work, I'm not sure what's up ...
HTH,
Paul
>>HTH,
>>Paul
>>>content.
>>>thanks
Current Time: Wed Apr 24 19:53:13 GMT 2024
Powered by FUDForum. Page generated in 0.01755 seconds
