Problem with JBoss 3.2.3, Web Start and RCP [message #435772] |
Tue, 23 August 2005 13:18 |
Originally posted by: avier5.hotmail.com
Hi all,
Your help is needed...
I have wrote a plugin and tried to call it from Web Start . I use JBoss
3.2.3 as my server.
The downloads from Web Start work fine but now before the plugin show
itself I get the following exception:
*************** Start Here ****************************
!SESSION 2005-08-23 16:02:38.109
eclipse.buildId=unknown
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
!ENTRY org.eclipse.osgi 2005-08-23 16:02:38.703
!MESSAGE Error installing bundle:
reference:file:DMshared/RMorg.eclipse.osgi_3.1.0.jar/
!STACK 0
org.osgi.framework.BundleException: Bundle "system.bundle" version "3.1.0"
has already been installed from: System Bundle
at
org.eclipse.osgi.framework.internal.core.Framework.createAnd VerifyBundle(Framework.java:557)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:822)
at
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:737)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:788)
************* End Here *************************
Of course that I put in the server all my plugin's required plugins.
I don't know what to do more.... Need Help
Any ideas ?
Avier
Re: Problem with JBoss 3.2.3, Web Start and RCP [message #435991 is a reply to message #435982] |
Mon, 29 August 2005 08:32 |
Originally posted by: avier5.gmail.com
ted stockwell wrote:
> avier wrote:
>> Hi Pascal,
>> I need a way to work around this bug. Can you give me any idea how to do
>> it OR please tell me when and where I can get build 3.1.1 of Eclipse's
>> sdk ?
>> Thank you Avier
> I was getting the same error until I added the
org.eclipse.update.configurator plugin to my 'wrapping' feature. Perhaps
doing
> that will fix your problem also.
> I am using Eclipse 3.1.0.
I am doing exactly as it is written in the eclipse help undar-"Deploying
eclipse based application with Java Web Start" - and I can't go over step
2 with export of the feature.
What did I foreget ?
Avier
FUDForum. Page generated in 0.04670 seconds
