Home » Eclipse Projects » Web Tools incubator » Visual Editor for XML (VEX) Testing
Re: Visual Editor for XML (VEX) Testing [message #435083 is a reply to message #435082] |
Fri, 21 November 2008 15:29 |
Originally posted by: dcarver.starstandard.org
One more thing, once you get it installed, you should have a new
Perspective called Document, and you can open DocBook, or DITA files
with the editor by selecting them, and say Open With->VEX XML Editor
Dave
David Carver wrote:
> Reed Elliott wrote:
>> I am trying to introduce myself to Eclipse Open Source projects by
>> participating in the Visual Editor for XML project. In order to test
>> VEX, I installed the 3.1 Build (Build Date: 2008-11-21) from the
>> http://build.eclipse.org/webtools/committers/ website and ran Eclipse
>> 3.5. Eclipse runs fine, but I can't seem find the VEX editor. What am
>> I am doing wrong?
> Make sure you have Eclipse 3.5, and all dependencies for Eclipse 3.1.
> VEX is on the R0.5 version, so it's separate from the 3.5, and Webtools
> 3.1 download. You can get the latest version from here:
> http://build.eclipse.org/webtools/committers/vex-R0.5-I/2008 1112020646/I-I20081112020646-20081112020646/
>> Thanks for your help!
> No problem, looking forward to some more testing and enhancements.
> Dave
Re: Visual Editor for XML (VEX) Testing [message #435084 is a reply to message #435083] |
Fri, 21 November 2008 18:19 |
Reed Elliott Messages: 8 Registered: July 2009 |
Dave,
Thanks for the directions. Eclipse is running, and I see the Document
Perspective and the Vex XML Editor.
Reed
"David Carver" <dcarver@starstandard.org> wrote in message
news:4926D3CC.5040708@starstandard.org...
> Perspective called Document, and you can open DocBook, or DITA files with
> Dave
>>> 3.5. Eclipse runs fine, but I can't seem find the VEX editor. What am I
>>> am doing wrong?
>> Make sure you have Eclipse 3.5, and all dependencies for Eclipse 3.1. VEX
>> is on the R0.5 version, so it's separate from the 3.5, and Webtools 3.1
>> Dave
Re: Visual Editor for XML (VEX) Testing [message #562971 is a reply to message #435082] |
Dave
>> I am doing wrong?
> Dave
Re: Visual Editor for XML (VEX) Testing [message #562992 is a reply to message #435083] |
Dave,
Reed
> Dave
>>> am doing wrong?
>> Dave
Current Time: Thu Apr 25 11:29:15 GMT 2024
Powered by FUDForum. Page generated in 0.03419 seconds
