Re: embedding JPQL in a typesafe manner [message #434918] |
Fri, 04 July 2008 08:57 |
Miguel Garcia Messages: 77 Registered: July 2009 |
Member |
Doug,
>I believe the best solution for development time checking of JPQL
>statements is through enhanced tooling.
That would indeed be the ideal solution. As far as I can see, the current
support (as of March 2008) for JPQL completion and validation is discussed
at
http://dev.eclipse.org/mhonarc/lists/dali-dev/msg00590.html
I'll check more regularly the sources of Dali to make sure I don't miss any
developments around that. At this point, it's not obvious to me that (a)
below is easier than (b):
(a) provide a parser for JPQL in Dali (with error recovery),
customize JDT's Content Assist to react based on the partial concrete
syntax tree for JPQL being edited.
vs.
(b) provide a compilation participant to rule out those remaining cases
accepted by JDT type checking,
yet breaking the static semantics of JPQL + underlying DB schema
Both approaches can cope with Content Assist, and both have a hard time with
DB refactorings. Given that it's an open question which approach is more
effective (whatever that means), I guess both need to be further explored to
better understand their pros and cons. I'll explore the JPQL embedding
following the techniques described in http://bugs.eclipse.org/234003
Miguel
http://www.sts.tu-harburg.de/~mi.garcia/
----- Original Message -----
Newsgroups: eclipse.rt.eclipselink
Sent: Thursday, July 03, 2008 12:34 PM
Subject: Re: embedding JPQL in a typesafe manner
>statements is through enhanced tooling. I believe this is in the Dali
>project's future plans.
> In our classic API we have expressions which use a generic API to define
> queries. It still takes strings for the entity attribute names and will
> not report spelling mistakes until runtime.
> Doug
"Doug Clarke" <douglas.clarke@oracle.com> wrote in message
news:bc9515fe5c3d447ea49467323d9fb9d3$1@www.eclipse.org...
> Doug
FUDForum. Page generated in 0.03447 seconds
