Re: source code [message #434303 is a reply to message #434300] |
Mon, 29 January 2007 22:24 |
Neil Hauge Messages: 475 Registered: July 2009 |
Tom,
The Entity Generation functionality wasn't in the 2.0 M4 build that you
have. It will however be in the M5 build, and should be available in a
menu on the project called "JPA" or "Java Persistence".
If you want to take a look at it in 0.5, you can check out the following
plugin in CVS from dev.eclipse.org/cvsroot/webtools -
org.eclipse.jpa/plugins/org.eclipse.dali.gen. The API you are looking for
is in the class EntityGenerator. There won't be much change with Entity
Gen between 0.5 and 1.0, so this should be an accurate view of it.
Details on how to log in are located here -
http://wiki.eclipse.org/index.php/CVS_Howto
Let me know if you need more info on this.
Neil
Tom Mutdosch wrote:
> Ah, I found it. I found the source code bundled with the 2.0 M4 build (I
had
> been using 0.5). In the build I have, however, the context menu to Add Java
> Persistence is not available, so I'm not sure how to bring up the Generate
> Entities wizard. Does anyone know which Dali/JPA class opens that wizard,
so I
> can take a look?
> Thanks
> Tom
> Tom Mutdosch wrote:
>> Hi all,
>> I am working on some data tooling and from a wizard I would like to be
>> able to hook into or call the Dali entity generation operation. I'm not
>> sure if this is possible; are there any exposed APIs?
>> I was going to take a look myself, but I'm not sure where I can get a
>> look at the source for the dali plugins. The download I have only
>> contained the binary plugins. Where is the best place to get a hold of
>> the source?
>> Thanks,
>> Tom
Re: source code [message #592147 is a reply to message #434300] |
Tom,
Neil
had
so I
> can take a look?
> Thanks
> Tom
> Tom Mutdosch wrote:
>> Hi all,
>> the source?
>> Thanks,
>> Tom
FUDForum. Page generated in 0.04872 seconds
