Home » Eclipse Projects » Dali » DDL Generation observations
DDL Generation observations [message #433932] |
Tue, 25 April 2006 20:25 |
Kevin Sutter Messages: 106 Registered: July 2009 |
First off, now that I finally got DDL generation to actually kick off and
process, I was quite impressed with the result. I had read through the
gotchas already discovered, so I was ready for those. But, overall, it
generated the necessary ddl that matched my annotated source. Thanks.
But, of course, I have a few observations...
o Are Discriminator columns supported yet? I had a Discriminator Column
defined for one of my tables, and I didn't see that get generated in my
DDL. I modified my script before running it.
o Should Embedded classes work yet? One of my Entities referenced an
Embeddable class for a couple of its properties. But, the generated ddl
for this table didn't include these additional fields. They were
TIMESTAMP fields, if that makes any difference.
o The statement terminator doesn't seem to be working quite right. By
default, it used "GO" as the statement terminator. But, the generated
script didn't have the special statement to indicate the terminator:
-- <ScriptOptions statementTerminator="GO">
o Related to this, why wouldn't the semi-colon (;) be the default value
for the statement terminator? The word "GO" seems too common since it
found that in several locations of my generated DDL and, of course, died
all over the place when I first tried to run it... :-)
o The DDL generation seems to combine table definitions from several
files. (Again, this may be due to only having the option of running this
tool at the Project level.) Because I was experimenting with generating
Entities at the same time, I had multiple Entity class files that were
referencing the same table names. The DDL generator just combined all of
these definitions into a single table definition. This doesn't seem
right. I would have preferred a warning or an error that it couldn't
generate the ddl due to conflicting annotations.
That's it. Once I worked around these items, I was able to generate ddl
that actually dropped my old tables and re-created new ones based on the
annotations.
Kevin
Re: DDL Generation observations [message #433935 is a reply to message #433932] |
Tue, 25 April 2006 21:20 |
Karen Butzke Messages: 220 Registered: July 2009 |
Hi Kevin,
I am currently adding support for Discriminator Column in our model and
UI. Once this is complete, we could take advantage of that in the DDL
gen. Could you open an enhancement request that is specific to
DiscriminatorColumn support in DDL gen?
This sounds like something that probably wasn't in our model when the ddl
gen was first written. Open an enhancement request for this as well.
I would report this to the WTP RDB component. We take our model and turn
it into an RDB model and then generate the ddl through through an RDB
wizard. After our .5 release we will be migrating to using DTP project
along with WTP, so you might want to report it to DTP as well as RDB.
I agree, it does seem that we should warn you or let you choose whether
that is what you want to do. Looks like another enhancement request is
necessary :)
Thanks for all your feedback.
Karen
Re: DDL Generation observations [message #433942 is a reply to message #433935] |
Wed, 26 April 2006 14:06 |
Thanks, Karen. I have opened the requested Enhancement and Bug reports.
Details of the reports are posted below...
Karen wrote:
> Hi Kevin,
Enhancement 138625 was opened.
Enhancement 138627 was opened.
Bug reports 138631 and 138633 were opened against rdp and dtp,
respectively.
> necessary :)
Enhancement 138634 was opened.
> Karen
Re: DDL Generation observations [message #584892 is a reply to message #433932] |
Hi Kevin,
necessary :)
Karen
Re: DDL Generation observations [message #584968 is a reply to message #433935] |
Karen wrote:
> Hi Kevin,
respectively.
> necessary :)
> Karen
Current Time: Wed Apr 24 23:57:39 GMT 2024
Powered by FUDForum. Page generated in 0.03259 seconds
