Re: Problems with Text control [message #432944 is a reply to message #432935] |
Tue, 30 March 2004 15:30 |
Robert Bacs Messages: 165 Registered: July 2009 |
Yes, I know that, but in the ControlExample it's working without
SWT.V_SCROLL and I'm runninng with the same SWT version both example
(ControlExample and my snippet).
What is the difference between my snippet and the example provided by
ControlExample ?
Because, I do not see any !
Boby
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:c4bv5u$lh4$1@eclipse.org...
> 1) Give it a vertical scroll bar using SWT.V_SCROLL (in SWT 2.1.x)
> 2) The problem has already been worked around in SWT 3.0 (SWT.V_SCROLL
> should not be necessary but it's not harmful).
> "Robert Bacs" <boby@zerosoft.ro> wrote in message
> news:c4bms6$9qe$1@eclipse.org...
> > Hi,
> > I want to create a multiline Text control using the native Text widget.
> > The problem with the above snippet is that I cannot introduce more than
7
> > lines of text.
> > Well, in the examples provided by Eclipse (ControlExample) the Text
> control
> > created with SWT.MULTI it has'nt this limitation.
> > What is wrong in my snippet ?
> > import org.eclipse.swt.SWT;
> > import org.eclipse.swt.layout.*;
> > import org.eclipse.swt.widgets.*;
> > * @author Robert Bacs
> > public class XTableTest {
> > public static void main(String []args){
> > final Display display = new Display();
> > final Shell shell = new Shell(display);
> > shell.setLayout(new GridLayout());
> > Group textGroup = new Group (shell, SWT.NULL);
> > textGroup.setLayout (new GridLayout ());
> > textGroup.setLayoutData (new GridData (GridData.GRAB_HORIZONTAL |
> > GridData.HORIZONTAL_ALIGN_FILL | GridData.VERTICAL_ALIGN_FILL));
> > textGroup.setText ("Text");
> > Text text = new Text(textGroup, SWT.MULTI);
> > int size = 100;
> > GridData gridData = new GridData ();
> > gridData.widthHint = size;
> > gridData.heightHint = size;
> > text.setLayoutData(gridData);
> > text.setText("Multiline\nText\ncontrol");
> > shell.pack();
> > shell.open();
> > while (!shell.isDisposed ()) {
> > if (!display.readAndDispatch ()) display.sleep ();
> > display.dispose ();
Re: Problems with Text control [message #433000 is a reply to message #432944] |
Wed, 31 March 2004 13:46 |
I found the difference: in the Java build path I have two version of swt.jar
Boby
news:c4c2ua$r78$1@eclipse.org...
> ControlExample ?
> Best regards,
> Boby
> > > Hi,
widget.
than
> 7
> > > lines of text.
> > control
> > > int size = 100;
> > > shell.pack();
> > > shell.open();
> > > display.dispose ();
FUDForum. Page generated in 0.02977 seconds
