Home » Modeling » Epsilon » [EGL] [newbie] Multiple input models problem
Re: [EGL] [newbie] Multiple input models problem [message #432790 is a reply to message #432405] |
Thu, 30 July 2009 17:15 |
Louis Rose Messages: 440 Registered: July 2009 Location: York, United Kingdom |
Orcun wrote:
> Hi all,
> I'm trying to use two different (two meta-model) input models in EGL
> template run configuration but it seems that it accepts only the first
> one. For instance, if I define models as ModelX and ModelY, ModelY is
> not recognized by engine and vice versa.
Just to clarify, do you have 2 models: 1 is an instance of MetamodelX
and 1 is an instance of MetamodelY?
> I tried models with their own related codes, one by one and both models
> are flawless separately. On the other hand, running two input model
> displays an error message for the second model: "Type 'ModelYSubType'
> not found".
What results do you get when running the following simple template with
2 input models, one called ModelX and the other called ModelY?
[%=ModelX!AClassFromMetamodelX.all%]
[%=ModelY!AClassFromMetamodelY.all%]
Be sure to replace AClassFromMetamodelX (AClassFromMetamodelY) with the
name of an EClass from the the metamodel of ModelX (ModelY).
Louis.
Louis Rose
Research Student
Department of Computer Science,
University of York,
Heslington, York, YO10 5DD, United Kingdom.
+44 1904 434762
Twitter: @louismrose
Re: [EGL] [newbie] Multiple input models problem [message #440584 is a reply to message #432790] |
Fri, 31 July 2009 08:40 |
Orcun Dayibas Messages: 8 Registered: July 2009 |
[%=DomainModel!Component.all%]
<delimiter>
[%=FeatureModel!Feature.all%]
[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1875a82 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@2ca90c (name: Component)
(instanceClassName: null) (abstract: false, interface: false)),
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@14742ee (eClass:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@17b3295 (eClass:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1360218 (eClass:
(instanceClassName: null) (abstract: false, interface: false))]
<delimiter>
[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@c03da9 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@6288ed (name: Feature)
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1103411 (eClass:
Re: [EGL] [newbie] Multiple input models problem [message #441280 is a reply to message #440584] |
Fri, 31 July 2009 10:10 |
> <delimiter>
> <delimiter>
Great, so this looks like you have 4 Components in your domain model and
2 Features in your feature model.
Be sure to prefix all uses of a metaclass name with the name of the
model. So, always use (for example):
rather than:
Component
Does this answer your original question, or do you still have errors
when running your EGL script?
Louis.
Re: [EGL] [newbie] Multiple input models problem [message #571793 is a reply to message #432405] |
Orcun wrote:
> Hi all,
> not found".
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Re: [EGL] [newbie] Multiple input models problem [message #571922 is a reply to message #432790] |
<delimiter>
<delimiter>
Re: [EGL] [newbie] Multiple input models problem [message #571943 is a reply to message #440584] |
> <delimiter>
> <delimiter>
rather than:
Component
Louis.
Current Time: Fri Apr 19 20:31:37 GMT 2024
Powered by FUDForum. Page generated in 0.03357 seconds
