Home » Modeling » EMF » EMF generics and Rational Rose
Re: EMF generics and Rational Rose [message #431925 is a reply to message #431915] |
Wed, 29 July 2009 16:53 |
Ed Merks Messages: 33113 Registered: July 2009 |
--------------080304040502020301060906
Maik,
Comments below.
Maik Wurdel wrote:
> I just figured out that EMF offers generics since version 3.4 which is
> pretty helpful. However, I can't find a way to specify those generics
> in Rational Rose.
> I'm aware of the custom ecore properties within Rational Rose. Still I
> can't find a way to specify that a certain class has a generic parameter.
> So my questions are:
> Is there a real comprehensive tutorial or reference which stereotypes
> and ecore properties are used of the rose importer? It is not the
> first I'm posting a question regarding this topic, so I'd be glad to
> have a reference.
> Is there a way to specify generics using Rational Rose taken into
> account by the rose importer?
There is and I'm pretty sure I've attached a *.mdl file with examples of
all the things that can be specified in some previous newsgroup
posting. But I don't have Rose installed anymore (not being at IBM and
all) so I don't know if the attached file is the right one. Hopefully
it is and it helps.
> Any help would be appreciated!
> Thanks
> Maik
name="template.mdl"
Content-Disposition: inline;
filename="template.mdl"
(object Petal
version 42
_written "Rose 4.5.8163.3"
charSet 0)
(object Design "Logical View"
is_unit TRUE
is_loaded TRUE
defaults (object defaults
rightMargin 0.250000
leftMargin 0.250000
topMargin 0.250000
bottomMargin 0.500000
pageOverlap 0.250000
clipIconLabels TRUE
autoResize TRUE
snapToGrid TRUE
gridX 16
gridY 16
defaultFont (object Font
size 10
face "Arial"
bold FALSE
italics FALSE
underline FALSE
strike FALSE
color 0
default_color TRUE)
showMessageNum 1
showClassOfObject TRUE
notation "Unified")
root_usecase_package (object Class_Category "Use Case View"
quid "4564386F0028"
exportControl "Public"
global TRUE
logical_models (list unit_reference_list)
logical_presentations (list unit_reference_list
(object UseCaseDiagram "Main"
quid "4564386F002F"
title "Main"
zoom 100
max_height 28350
max_width 21600
origin_x 0
origin_y 0
items (list diagram_item_list))))
root_category (object Class_Category "Logical View"
quid "4564386F0027"
global TRUE
subsystem "Component View"
quidu "4564386F0029"
(object Class_Category "template"
attributes (list Attribute_Set
(object Attribute
tool "Ecore"
name "nsPrefix"
value "template")
(object Attribute
tool "Ecore"
name "nsURI"
value "http:///org/example/template")
(object Attribute
tool "Ecore"
name "basePackage"
value "org.example")
(object Attribute
tool "Ecore"
name "prefix"
value "Template"))
quid "45643875016F"
(object Class "Container"
quid "45643C900365"
operations (list Operations
(object Operation "<T extends EJavaException> foo"
quid "45716A7E0169"
parameters (list Parameters
(object Parameter "t"
type "T"))
result "T"
exceptions "T"
concurrency "Sequential"
opExportControl "Public"
uid 0))
class_attributes (list class_attribute_list
(object ClassAttribute "E"
quid "45643C98008C"
stereotype "parameter"
exportControl "Public")
(object ClassAttribute "instanceClass"
quid "456846060196"
type "EJavaClass<E>"
(object ClassAttribute "a"
quid "457174A701C6"
type "E"
(object ClassAttribute "r"
quid "45717504037C"
stereotype "reference"
type "E"
exportControl "Public")))
(object Class "DerivedContainer"
quid "45643CAA005F"
superclasses (list inheritance_relationship_list
(object Inheritance_Relationship
quid "45643CBB03AD"
stereotype "<E>"
supplier "Logical View::template::Container"
quidu "45643C900365"))
quid "45643CB003E3"
(object Class "X"
quid "4564539901A2"
(object Operation "<E extends EJavaObject & Container<E>, F extends E> foo"
quid "4565B13D0355"
(object Parameter "e"
type "E")
(object Parameter "list"
type "EJavaList<? super F>")
(object Parameter "x"
type "String"))
result "E"
uid 0)
(object Operation "foo"
quid "4565B9BD038A"
result "EJavaList<EJavaObject>"
uid 0))
(object ClassAttribute "c"
quid "456453AA00CA"
type "Container<EJavaObject>"
(object ClassAttribute "list"
quid "4565899C01A0"
type "EJavaList<Container<EJavaNumber>>"
(object Class "EStringToStringMap"
quid "45757CDF003E"
stereotype "Interface"
(object ClassAttribute "java.util.Map<java.lang.String, java.lang.String>"
quid "45757CF802CE"
stereotype "javaclass"
(object Class "ExtendedMap"
quid "45757D65034B"
quid "45757D720128"
supplier "Logical View::template::EStringToStringMap"
quidu "45757CDF003E"))
(object ClassAttribute "d"
quid "45757D7D03D8"
type "ListOfDecimal"
(object ClassAttribute "h"
quid "45757D870109"
type "ListOfHexadecimal"
abstract TRUE)
(object Class "EJavaList"
quid "456439040052"
stereotype "datatype"
quid "45643944007C"
(object ClassAttribute "java.util.List"
quid "456439EC010A"
(object Class "EEList"
quid "45643A04006F"
quid "45643A090134"
(object ClassAttribute "org.eclipse.emf.common.util.EList"
quid "45643A130020"
(object Class "EJavaObject"
quid "45643B57004E"
(object ClassAttribute "java.lang.Object"
quid "45643B630073"
(object Class "EJavaNumber"
quid "45643B74032B"
(object ClassAttribute "java.lang.Number"
quid "45643B870328"
(object Class "EJavaClass"
quid "456845B80138"
(object ClassAttribute "T"
quid "456845C60399"
(object ClassAttribute "java.lang.Class"
quid "4568466A006D"
(object Class "EJavaException"
quid "45716AB60040"
(object ClassAttribute "java.lang.Exception"
quid "45716ACC031E"
(object Class "ListOfDecimal"
quid "457301AF0282"
(object ClassAttribute "java.util.List<java.lang.Integer>"
quid "457312CD0011"
(object Class "ListOfHexadecimal"
quid "4573024102B1"
quid "457312DA032E"
(object Association "$UNNAMED$0"
quid "456589F10094"
roles (list role_list
(object Role "$UNNAMED$1"
quid "456589F201CC"
supplier "Logical View::template::X"
quidu "4564539901A2"
is_navigable TRUE
is_aggregate TRUE)
(object Role "derivedContainer<? extends EJavaNumber>"
quid "456589F201CD"
label "derivedContainer<? extends EJavaNumber>"
supplier "Logical View::template::DerivedContainer"
quidu "45643CAA005F"
client_cardinality (value cardinality "0..n")
is_navigable TRUE))))
(object ClassDiagram "Main"
quid "456438F6020B"
title "Main"
zoom 100
max_height 28350
max_width 21600
origin_x 0
origin_y 0
(object ClassView "Class" "Logical View::template::EJavaList" @1
ShowCompartmentStereotypes TRUE
IncludeAttribute TRUE
IncludeOperation TRUE
location (464, 224)
label (object ItemLabel
Parent_View @1
location (192, 140)
fill_color 13434879
nlines 1
max_width 544
justify 0
label "EJavaList")
stereotype (object ItemLabel
Parent_View @1
location (192, 90)
fill_color 13434879
anchor 10
nlines 1
max_width 544
justify 0
label "<<datatype>>")
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "456439040052"
compartment (object Compartment
Parent_View @1
location (192, 200)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 3
max_width 550)
width 562
height 292
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::EEList" @2
location (656, 592)
Parent_View @2
location (184, 536)
fill_color 13434879
nlines 1
max_width 944
justify 0
label "EEList")
Parent_View @2
location (184, 486)
fill_color 13434879
anchor 10
nlines 1
max_width 944
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "45643A04006F"
Parent_View @2
location (184, 596)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 3
max_width 953)
width 962
height 236
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::EJavaObject" @3
location (1600, 240)
Parent_View @3
location (1291, 181)
fill_color 13434879
nlines 1
max_width 618
justify 0
label "EJavaObject")
Parent_View @3
location (1291, 131)
fill_color 13434879
anchor 10
nlines 1
max_width 618
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "45643B57004E"
Parent_View @3
location (1291, 241)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 2
max_width 625)
width 636
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::EJavaNumber" @4
location (1616, 608)
Parent_View @4
location (1296, 549)
fill_color 13434879
nlines 1
max_width 640
justify 0
label "EJavaNumber")
Parent_View @4
location (1296, 499)
fill_color 13434879
anchor 10
nlines 1
max_width 640
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "45643B74032B"
Parent_View @4
location (1296, 609)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 2
max_width 646)
width 658
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::Container" @5
ShowOperationSignature TRUE
location (528, 1072)
Parent_View @5
location (126, 891)
fill_color 13434879
nlines 1
max_width 804
justify 0
label "Container")
icon_style "Icon"
line_color 3342489
fill_color 13434879
Parent_View @5
location (126, 951)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 6
max_width 800)
width 822
height 386
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::X" @6
location (2096, 1088)
Parent_View @6
location (1087, 932)
fill_color 13434879
nlines 1
max_width 2018
justify 0
label "X")
icon_style "Icon"
line_color 3342489
fill_color 13434879
Parent_View @6
location (1087, 992)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 5
max_width 2025)
width 2036
height 336
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::DerivedContainer" @7
location (336, 1488)
Parent_View @7
location (149, 1407)
fill_color 13434879
nlines 1
max_width 374
justify 0
label "DerivedContainer")
icon_style "Icon"
line_color 3342489
fill_color 13434879
Parent_View @7
location (149, 1467)
icon_style "Icon"
fill_color 16777215
anchor 2
nlines 2
max_width 381)
width 392
height 186
annotation 8
autoResize TRUE)
(object InheritView "" @8
stereotype (object SegLabel @9
Parent_View @8
location (581, 1354)
anchor 10
anchor_loc 1
nlines 1
max_width 450
justify 0
label "<<<E>>>"
pctDist 0.313253
height 134
orientation 1)
line_color 3342489
quidu "45643CBB03AD"
client @7
supplier @5
line_style 3
origin_attachment (447, 1395)
terminal_attachment (447, 1265))
(object AssociationViewNew "$UNNAMED$0" @10
location (1502, 1528)
stereotype TRUE
line_color 3342489
quidu "456589F10094"
roleview_list (list RoleViews
(object RoleView "$UNNAMED$1" @11
Parent_View @10
location (1150, 24)
stereotype TRUE
line_color 3342489
quidu "456589F201CC"
client @10
supplier @6
vertices (list Points
(1502, 1528)
(2200, 1528)
(2200, 1256))
line_style 3
origin_attachment (1502, 1528)
terminal_attachment (2200, 1256))
(object RoleView "derivedContainer<? extends EJavaNumber>" @12
Parent_View @10
location (1150, 24)
label (object SegLabel @13
Parent_View @12
location (1196, 1473)
anchor 1
anchor_loc 1
nlines 1
max_width 816
justify 0
label "+derivedContainer<? extends EJavaNumber>"
pctDist 0.315396
height 56
orientation 1)
stereotype TRUE
line_color 3342489
quidu "456589F201CD"
client @10
supplier @7
line_style 3
terminal_attachment (532, 1528)
label (object SegLabel @14
Parent_View @12
location (630, 1582)
anchor 2
anchor_loc 1
nlines 1
max_width 15
justify 0
label "0..*"
pctDist 0.900000
height 54
orientation 0))))
(object ClassView "Class" "Logical View::template::EJavaClass" @15
location (2368, 272)
Parent_View @15
location (2067, 188)
fill_color 13434879
nlines 1
max_width 602
justify 0
label "EJavaClass")
Parent_View @15
location (2067, 138)
fill_color 13434879
anchor 10
nlines 1
max_width 602
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "456845B80138"
Parent_View @15
location (2067, 248)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 3
max_width 609)
width 620
height 292
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::EJavaException" @16
location (2384, 624)
Parent_View @16
location (2044, 565)
fill_color 13434879
nlines 1
max_width 680
justify 0
label "EJavaException")
Parent_View @16
location (2044, 515)
fill_color 13434879
anchor 10
nlines 1
max_width 680
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "45716AB60040"
Parent_View @16
location (2044, 625)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 2
max_width 687)
width 698
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::ListOfDecimal" @17
location (608, 1760)
Parent_View @17
location (164, 1701)
fill_color 13434879
nlines 1
max_width 888
justify 0
label "ListOfDecimal")
Parent_View @17
location (164, 1651)
fill_color 13434879
anchor 10
nlines 1
max_width 888
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "457301AF0282"
Parent_View @17
location (164, 1761)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 2
max_width 890)
width 906
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::ListOfHexadecimal" @18
location (1632, 1760)
Parent_View @18
location (1188, 1701)
fill_color 13434879
nlines 1
max_width 888
justify 0
label "ListOfHexadecimal")
Parent_View @18
location (1188, 1651)
fill_color 13434879
anchor 10
nlines 1
max_width 888
justify 0
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "4573024102B1"
Parent_View @18
location (1188, 1761)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 2
max_width 890)
width 906
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::EStringToStringMap" @19
location (720, 2096)
Parent_View @19
location (130, 2037)
fill_color 13434879
nlines 1
max_width 1180
justify 0
label "EStringToStringMap")
Parent_View @19
location (130, 1987)
fill_color 13434879
anchor 10
nlines 1
max_width 1180
justify 0
label "<<Interface>>")
icon "Interface"
icon_style "Label"
line_color 3342489
fill_color 13434879
Parent_View @19
location (130, 2097)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 2
max_width 1187)
width 1198
height 242
annotation 8
autoResize TRUE)
(object ClassView "Class" "Logical View::template::ExtendedMap" @20
location (352, 2448)
font (object Font
italics TRUE)
Parent_View @20
location (126, 2342)
fill_color 13434879
nlines 1
max_width 452
justify 0
label "ExtendedMap")
icon_style "Icon"
line_color 3342489
fill_color 13434879
quidu "45757D65034B"
Parent_View @20
location (126, 2402)
icon_style "Icon"
fill_color 13434879
anchor 2
nlines 3
max_width 0)
width 470
height 236
annotation 8
autoResize TRUE)
(object InheritView "" @21
stereotype TRUE
line_color 3342489
quidu "45757D720128"
client @20
supplier @19
line_style 3
origin_attachment (381, 2330)
terminal_attachment (381, 2217)))))))
quid "4564386F002D"
title "Main"
zoom 100
max_height 28350
max_width 21600
origin_x 0
origin_y 0
root_subsystem (object SubSystem "Component View"
quid "4564386F0029"
physical_models (list unit_reference_list)
physical_presentations (list unit_reference_list
(object Module_Diagram "Main"
quid "4564386F002E"
title "Main"
zoom 100
max_height 28350
max_width 21600
origin_x 0
origin_y 0
process_structure (object Processes
quid "4564386F002A"
ProcsNDevs (list
(object Process_Diagram "Deployment View"
quid "4564386F002C"
title "Deployment View"
zoom 100
max_height 28350
max_width 21600
origin_x 0
origin_y 0
properties (object Properties
(object Attribute
tool "DDL"
name "propertyId"
value "809135966")
(object Attribute
tool "DDL"
name "default__Project"
value (list Attribute_Set
(object Attribute
tool "DDL"
name "Directory"
value "AUTO GENERATE")
(object Attribute
tool "DDL"
name "DataBase"
value ("DataBaseSet" 800))
(object Attribute
tool "DDL"
name "DataBaseSet"
(object Attribute
tool "DDL"
name "ANSI"
value 800)
(object Attribute
tool "DDL"
name "Oracle"
value 801)
(object Attribute
tool "DDL"
name "SQLServer"
value 802)
(object Attribute
tool "DDL"
name "Sybase"
value 803)
(object Attribute
tool "DDL"
name "Watcom"
value 804)))
(object Attribute
tool "DDL"
name "PrimaryKeyColumnName"
value "Id")
(object Attribute
tool "DDL"
name "PrimaryKeyColumnType"
value "NUMBER(5)")
(object Attribute
tool "DDL"
name "ViewName"
value "V_")
(object Attribute
tool "DDL"
name "TableName"
value "T_")
(object Attribute
tool "DDL"
name "InheritSuffix"
value "_V")
(object Attribute
tool "DDL"
name "DropClause"
value FALSE)
(object Attribute
tool "DDL"
name "BaseViews"
value FALSE)
(object Attribute
tool "DDL"
name "DDLScriptFilename"
value "DDL1.SQL")))
(object Attribute
tool "DDL"
name "default__Attribute"
(object Attribute
tool "DDL"
name "ColumnType"
value "VARCHAR")
(object Attribute
tool "DDL"
name "Length"
value "")
(object Attribute
tool "DDL"
name "NullsOK"
value TRUE)
(object Attribute
tool "DDL"
name "PrimaryKey"
value FALSE)
(object Attribute
tool "DDL"
name "Unique"
value FALSE)
(object Attribute
tool "DDL"
name "CompositeUnique"
value FALSE)
(object Attribute
tool "DDL"
name "CheckConstraint"
value "")))
(object Attribute
tool "DDL"
name "HiddenTool"
value FALSE)
(object Attribute
tool "IDL"
name "propertyId"
value "809135966")
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
name "CreateMissingDirectories"
value TRUE)
(object Attribute
tool "IDL"
name "StopOnError"
value TRUE)
(object Attribute
tool "IDL"
name "Directory"
(object Attribute
tool "IDL"
name "GeneratePreserveRegions"
value TRUE)))
(object Attribute
tool "IDL"
name "default__Class"
(object Attribute
tool "IDL"
name "ImplementationType"
value "")
(object Attribute
tool "IDL"
name "ConstValue"
value "")
(object Attribute
tool "IDL"
name "GenerateDefaultSpecifier"
value FALSE)
(object Attribute
tool "IDL"
name "DefaultSpecifier"
value "")
(object Attribute
tool "IDL"
name "IDLElement"
value TRUE)
(object Attribute
tool "IDL"
name "IDLSpecificationType"
value ("IDLSpecSet" 22))
(object Attribute
tool "IDL"
name "IDLSpecSet"
(object Attribute
tool "IDL"
name "Interface"
value 22)
(object Attribute
tool "IDL"
name "Typedef"
value 54)
(object Attribute
tool "IDL"
name "Enumeration"
value 8)
(object Attribute
tool "IDL"
name "Const"
value 71)
(object Attribute
tool "IDL"
name "Exception"
value 61)
(object Attribute
tool "IDL"
name "Struct"
value 51)
(object Attribute
tool "IDL"
name "Union"
value 81)))))
(object Attribute
tool "IDL"
name "default__Module-Spec"
(object Attribute
tool "IDL"
name "Generate"
value TRUE)
(object Attribute
tool "IDL"
name "CmIdentification"
value (value Text " %X% %Q% %Z% %W%"))
(object Attribute
tool "IDL"
name "CopyrightNotice"
value (value Text ""))
(object Attribute
tool "IDL"
name "FileName"
(object Attribute
tool "IDL"
name "GenerateIDLModule"
value FALSE)
(object Attribute
tool "IDL"
name "InclusionProtectionSymbol"
(object Attribute
tool "IDL"
name "AdditionalIncludes"
(object Attribute
tool "IDL"
name "IncludeBySimpleName"
value FALSE)))
(object Attribute
tool "IDL"
name "default__Module-Body"
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
name "FileName"
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
value FALSE)))
(object Attribute
tool "IDL"
name "default__Operation"
(object Attribute
tool "IDL"
name "OperationIsOneWay"
value FALSE)
(object Attribute
tool "IDL"
name "Context"
value "")
(object Attribute
tool "IDL"
name "Raises"
value "")))
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
name "CaseSpecifier"
value "")
(object Attribute
tool "IDL"
name "GenerateDataMember"
value TRUE)
(object Attribute
tool "IDL"
name "DataMemberName"
value "$relationship")
(object Attribute
tool "IDL"
name "IsReadOnly"
value FALSE)
(object Attribute
tool "IDL"
name "IsConst"
value FALSE)
(object Attribute
tool "IDL"
name "ConstValue"
value "")))
(object Attribute
tool "IDL"
name "default__Has"
(object Attribute
tool "IDL"
name "NameIfUnlabeled"
value "the_$supplier")
(object Attribute
tool "IDL"
value TRUE)
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
name "GenerateForwardReference"
value FALSE)
(object Attribute
tool "IDL"
name "IsReadOnly"
value FALSE)
(object Attribute
tool "IDL"
name "BoundedHasRelType"
value ("HasRelTypeSet" 47))
(object Attribute
tool "IDL"
name "HasRelTypeSet"
(object Attribute
tool "IDL"
name "Array"
value 24)
(object Attribute
tool "IDL"
name "Sequence"
value 47)))))
(object Attribute
tool "IDL"
name "default__Role"
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
value TRUE)
(object Attribute
tool "IDL"
(object Attribute
tool "IDL"
value FALSE)
(object Attribute
tool "IDL"
name "IsReadOnly"
value FALSE)
(object Attribute
tool "IDL"
name "BoundedRoleType"
value ("AssocTypeSet" 47))
(object Attribute
tool "IDL"
name "AssocTypeSet"
(object Attribute
tool "IDL"
name "Array"
value 24)
(object Attribute
tool "IDL"
name "Sequence"
value 47)))))
(object Attribute
tool "IDL"
name "default__Uses"
(object Attribute
tool "IDL"
value FALSE)))
(object Attribute
tool "IDL"
name "default__Subsystem"
(object Attribute
tool "IDL"
name "Directory"
value "AUTO GENERATE")))
(object Attribute
tool "IDL"
name "HiddenTool"
value FALSE)
(object Attribute
tool "SCC"
name "HiddenTool"
value FALSE)
(object Attribute
tool "Ecore"
name "propertyId"
value "809135969")
(object Attribute
tool "Ecore"
name "default__Category"
(object Attribute
tool "Ecore"
name "packageName"
value "")
(object Attribute
tool "Ecore"
name "nsPrefix"
value "")
(object Attribute
tool "Ecore"
name "nsURI"
value "")
(object Attribute
tool "Ecore"
name "basePackage"
value "")
(object Attribute
tool "Ecore"
name "prefix"
value "")
(object Attribute
tool "Ecore"
name "annotation"
value "")))
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "classifierName"
value "")
(object Attribute
tool "Ecore"
name "constraints"
value "")
(object Attribute
tool "Ecore"
name "xmlName"
value "")
(object Attribute
tool "Ecore"
name "xmlContentKind"
value ("ContentKind" 0))
(object Attribute
tool "Ecore"
name "ContentKind"
(object Attribute
tool "Ecore"
name "Unspecified"
value 0)
(object Attribute
tool "Ecore"
name "Empty"
value 1)
(object Attribute
tool "Ecore"
name "Simple"
value 2)
(object Attribute
tool "Ecore"
name "Mixed"
value 3)
(object Attribute
tool "Ecore"
name "ElementOnly"
value 4)))
(object Attribute
tool "Ecore"
name "annotation"
value "")))
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "operationName"
value "")
(object Attribute
tool "Ecore"
name "isUnique"
value TRUE)
(object Attribute
tool "Ecore"
name "annotation"
value "")))
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "attributeName"
value "")
(object Attribute
tool "Ecore"
name "isTransient"
value FALSE)
(object Attribute
tool "Ecore"
name "isVolatile"
value FALSE)
(object Attribute
tool "Ecore"
name "isChangeable"
value TRUE)
(object Attribute
tool "Ecore"
name "isUnsettable"
value FALSE)
(object Attribute
tool "Ecore"
name "isUnique"
value TRUE)
(object Attribute
tool "Ecore"
name "isID"
value FALSE)
(object Attribute
tool "Ecore"
name "visibility"
value ("VisibilityKind" 0))
(object Attribute
tool "Ecore"
name "VisibilityKind"
(object Attribute
tool "Ecore"
name "Unspecified"
value 0)
(object Attribute
tool "Ecore"
name "None"
value 1)
(object Attribute
tool "Ecore"
name "Read-only"
value 2)
(object Attribute
tool "Ecore"
name "Read-write"
value 3)
(object Attribute
tool "Ecore"
name "Read-only unsettable"
value 4)
(object Attribute
tool "Ecore"
name "Read-write unsettable"
value 5)))
(object Attribute
tool "Ecore"
name "xmlName"
value "")
(object Attribute
tool "Ecore"
name "xmlNamespace"
value "")
(object Attribute
tool "Ecore"
name "xmlFeatureKind"
value ("FeatureKind" 0))
(object Attribute
tool "Ecore"
name "FeatureKind"
(object Attribute
tool "Ecore"
name "Unspecified"
value 0)
(object Attribute
tool "Ecore"
name "Simple"
value 1)
(object Attribute
tool "Ecore"
name "Attribute"
value 2)
(object Attribute
tool "Ecore"
name "Element"
value 4)))
(object Attribute
tool "Ecore"
name "annotation"
value "")))
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "referenceName"
value "")
(object Attribute
tool "Ecore"
name "isTransient"
value FALSE)
(object Attribute
tool "Ecore"
name "isVolatile"
value FALSE)
(object Attribute
tool "Ecore"
name "isChangeable"
value TRUE)
(object Attribute
tool "Ecore"
name "isUnsettable"
value FALSE)
(object Attribute
tool "Ecore"
name "isResolveProxies"
value TRUE)
(object Attribute
tool "Ecore"
name "visibility"
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "Unspecified"
value 0)
(object Attribute
tool "Ecore"
name "None"
value 1)
(object Attribute
tool "Ecore"
name "Read-only"
value 2)
(object Attribute
tool "Ecore"
name "Read-write"
value 3)
(object Attribute
tool "Ecore"
value 4)
(object Attribute
tool "Ecore"
value 5)))
(object Attribute
tool "Ecore"
name "xmlName"
value "")
(object Attribute
tool "Ecore"
name "xmlNamespace"
value "")
(object Attribute
tool "Ecore"
(object Attribute
tool "Ecore"
name "FeatureKind"
(object Attribute
tool "Ecore"
name "Unspecified"
value 0)
(object Attribute
tool "Ecore"
name "Simple"
value 1)
(object Attribute
tool "Ecore"
name "Attribute"
value 2)
(object Attribute
tool "Ecore"
name "Element"
value 4)))
(object Attribute
tool "Ecore"
name "annotation"
value "")))
(object Attribute
tool "framework"
name "HiddenTool"
value FALSE)
(object Attribute
tool "Java"
name "propertyId"
value "809135966")
(object Attribute
tool "Java"
(object Attribute
tool "Java"
value TRUE)
(object Attribute
tool "Java"
name "StopOnError"
value FALSE)
(object Attribute
tool "Java"
name "Directory"
(object Attribute
tool "Java"
name "UsePrefixes"
value FALSE)
(object Attribute
tool "Java"
name "InstanceVariablePrefix"
value "m_")
(object Attribute
tool "Java"
name "ClassVariablePrefix"
value "s_")
(object Attribute
tool "Java"
name "DefaultAttributeDataType"
value "int")
(object Attribute
tool "Java"
name "DefaultOperationReturnType"
value "void")))
(object Attribute
tool "Java"
(object Attribute
tool "Java"
name "Final"
value FALSE)
(object Attribute
tool "Java"
name "GenerateDefaultConstructor"
value TRUE)
(object Attribute
tool "Java"
name "ConstructorIs"
value ("Ctor_Set" 62))
(object Attribute
tool "Java"
name "Ctor_Set"
Ed Merks
Current Time: Fri Mar 29 00:29:24 GMT 2024
Powered by FUDForum. Page generated in 0.03551 seconds
