[CDO] SQL Exception: Failed to create database [message #431914] |
Wed, 29 July 2009 11:28 |
Originally posted by: ralph.kretzler.gmail.com
I try to start the CDO Server. For that I followed the instructions of
this tutorial ... http://wiki.eclipse.org/Getting_started_with_CDO_Galileo
But when I hit the run button I got an exception.
I am using Mac OS X and the Eclipse Modelling Package. EMF 2.5 and CDO 2.0.
Ralph
cdo-server.xml
<cdoServer>
<!--acceptor type="http"/ -->
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<!-- negotiator type="challenge" description="/temp/users.db"/ -->
</acceptor>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="false"/>
<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<dbAdapter name="derby-embedded"/>
<dataSource class="org.apache.derby.jdbc.EmbeddedDataSource"
databaseName="/temp/cdodb1"
createDatabase="create"/>
</store>
</repository>
</cdoServer>
Exception
[INFO] CDO Server starting
[ERROR] SQL Exception: Failed to create database '/temp/cdodb1', see the
next exception for details.
org.eclipse.net4j.db.DBException: SQL Exception: Failed to create
database '/temp/cdodb1', see the next exception for details.
org.eclipse.net4j.internal.db.DataSourceConnectionProvider.g etConnection(DataSourceConnectionProvider.java:46)
org.eclipse.emf.cdo.server.internal.db.DBStore.getConnection (DBStore.java:180)
org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DB Store.java:230)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:65)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:94)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:84)
org.eclipse.emf.cdo.internal.server.Repository.doActivate(Re pository.java:581)
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOSe rverUtil.java:73)
org.eclipse.emf.cdo.internal.server.RepositoryConfigurator.c onfigure(RepositoryConfigurator.java:83)
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion.doStart(CDOServerApplication.java:51)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplicat ion.java:61)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: SQL Exception: Failed to create database '/temp/cdodb1', see
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at org.apache.derby.impl.jdbc.EmbedConnection.newSQLException(U nknown
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Un known
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver30.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.EmbeddedDataSource.getConnection(Unkno wn Source)
org.eclipse.net4j.internal.db.DataSourceConnectionProvider.g etConnection(DataSourceConnectionProvider.java:42)
... 26 more
Re: [CDO] SQL Exception: Failed to create database [message #431916 is a reply to message #431914] |
Wed, 29 July 2009 14:02 |
Originally posted by: hamak.email.cz
Hi. I solved this error on linux by changing /temp/cdodb1 to
/tmp/cdodb1. So I guess you don't have the /temp/ directory. Either
create /temp/ or change it to something else in <dataSource>.
Ondrej Hamak
Ralph Kretzler napsal(a):
> Hello,
> Ralph
> cdo-server.xml
> <cdoServer>
> </acceptor>
> <store type="db">
> </mappingStrategy>
> </store>
> </repository>
> </cdoServer>
> Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedConnection.newSQLException(U nknown Source)
> Source)
> Source)
> Source)
> at
> ... 26 more
Re: [CDO] SQL Exception: Failed to create database [message #431926 is a reply to message #431916] |
Wed, 29 July 2009 17:02 |
ohh, so simple ... it works also under Mac OS X.
Thanks a lot,
Ralph
> Ondrej Hamak
>> Hello,
>> this tutorial ...
>> 2.0.
>> Thanks,
>> Ralph
>> cdo-server.xml
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cdoServer>
>> </acceptor>
>> <store type="db">
>> </mappingStrategy>
>> </store>
>> </repository>
>> </cdoServer>
>> Exception
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Un known Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> ... 26 more
FUDForum. Page generated in 0.03247 seconds
