Home » Modeling » EMF » is EMF right solution for me? - Overriding load / save format
is EMF right solution for me? - Overriding load / save format [message #431842] |
Tue, 28 July 2009 04:58 |
Originally posted by: switzer.jeff+eclipse.gmail.com
Hello. Sorry for the newbie question.
I've been re-writing an old C++ program of mine as an RCP app. I had a
basic JavaBeans model working that would load / save my model, but when
working on the GUI, I realized I should have a stronger framework/model
to work with, so I've been looking into EMF.
I have a few questions:
For this application, I've reversed engineered a file format (for a
hardware sampler). I want to be able to make changes to the model, and
save the resource in a format that the sampler can read. This means (at
a high level) I cannot load/save resources in XMI format (they need to
be some format that I *partially* know about). For instance, the way I
currently manipulate the files, is by reading the original ~2MB file
into a byte[]. I then load in the objects that I've reversed engineered
(and know the structure of) from the file. When I save the resource, I
write the original byte[] back to disk, then overwrite certain *known*
portions of the data with my manipulated Objects.
If you're still with me, my question is, what's the best way to go about
overriding loading/saving of resources in EMF? I've looked at code like:
resource = editingDomain.getResourceSet().getResource(resourceURI, true);
And the generated test Example, with lines like:
Resource resource =
resourceSet.createResource(URI.createURI("http:///My.esxfile"));
EsxFile root = EsxFileFactory.eINSTANCE.createEsxFile();
resource.getContents().add(root);
resource.save(System.out, null);
My unfamiliarity with EMF/Java standards (Factories / Adapters), is
making it hard for me to grasp where/how I should start with overriding
the default load/save behavior.
Also I'm just wondering if this a common problem, and if you think EMF
is a good solution for me to use?
I've included a link to my initial ecore model. Once I figure out how
to load/save correctly, I will continue to tweak it:
http://skratchdot.com/eclipse/EsxFile.ecore
Thanks for any help you can provide!
-Jeff
Re: is EMF right solution for me? - Overriding load / save format [message #431859 is a reply to message #431842] |
Tue, 28 July 2009 10:39 |
Mario Winterer Messages: 136 Registered: July 2009 |
Hi Jeff,
see my comments below!
> true);
> Resource resource =
The correct way to customize loading and saving is to write your own
Resource and ResourceFactory implementation and register the custom
ResourceFactory for the preferred file extension.
Create a .genmodel file based on your Ecore model, select the
EsxFile-Package in the editor and open the Properties View.
+ Set All->Base Package (e.g. to com.skratchdot)
+ Set Model->Resource Type to "Basic" (that will generate a basic
Resource and ResourceFactory)
Generate the code.
In com.skratchdot.EsxFile.util you can find EsxFileResourceFactoryImpl
and EsxFileResourceImpl.
(1) Implement EsxFileResourceImpl#doSave(OutputStream, Map) and
EsxFileResourceImpl#doLoad(OutputStream, Map) so that the contents of
the resource gets saved/loaded.
(2) Register the EsxFileResourceFactoryImpl as resource factory for your
file extension:
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
class="com.skratchdot.EsxFile.util.EsxFileResourceFactoryImpl "
type="esxfile">
</parser>
</extension>
Now all URIs that ends in .esxfile will be handled by your
Resource/ResourceFactory:
Resource resource =
resourceSet.getResource(URI.createURI("http:///My.esxfile"), true);
It is a common problem and there are many resource-implementations out
there (e.g. XMLResourceImpl, XMIResourceImpl, BinaryResourceImpl,
CDOResourceImpl, HibernateResource etc.). I cannot see a reason why you
could not use EMF for your purpose. Even if you don't use the entire EMF
framework you could still use the code generator to get high-quality
JavaBean like data classes with a fine-grained notification mechanism
for free...
I've downloaded the model (I hope you don't mind) and generated model
code. My suggestion: lowercase the package name and carefully design
your containment references! Every object inside a single resource
should be reachable by one single containment reference!
Mario
> -Jeff
Re: is EMF right solution for me? - Overriding load / save format [message #431861 is a reply to message #431859] |
Tue, 28 July 2009 12:13 |
Jeff S. Messages: 29 Registered: July 2009 |
Mario-
Thanks alot! That's a huge help. See inline comments.
Mario Winterer wrote:
> Hi Jeff,
>> a basic JavaBeans model working that would load / save my model, but
>> when working on the GUI, I realized I should have a stronger
>> framework/model to work with, so I've been looking into EMF.
>> and save the resource in a format that the sampler can read. This
>> means (at a high level) I cannot load/save resources in XMI format
>> (they need to be some format that I *partially* know about). For
>> instance, the way I currently manipulate the files, is by reading the
>> original ~2MB file into a byte[]. I then load in the objects that
>> I've reversed engineered (and know the structure of) from the file.
>> When I save the resource, I write the original byte[] back to disk,
>> then overwrite certain *known* portions of the data with my
>> about overriding loading/saving of resources in EMF? I've looked at
>> code like:
>> true);
>> Resource resource =
>> overriding the default load/save behavior.
> Generate the code.
This is a step I was definitely missing. I wouldn't have know to set
Package->Model->Resource Type to "Basic". Thanks alot for that!
> file extension:
> <parser
> type="esxfile">
> </parser>
> </extension>
> Resource resource =
> for free...
Great! I'm really doing this as a learning exercise as well, and the
more I learn about EMF, the more I want to use it in future projects...
> Mario
No problem at all (that's why I included it :) ). Once I get a little
further along, the project will be open source anyways. I was actually
hoping for some tips like you gave (because I need to nail down the
model before fully implementing the load/save). Now that I think about
it, I should have just shared the .genmodel I had been using.
One more question: do you know of a good reference for some of the
..genmodel Package settings (and other property view settings for
different types of nodes in the .genmodel)?
I've found a good reference for some types of objects (in the Docs
section- by Ed Merck):
http://www.scribd.com/doc/11342394/Refcard-38-Essential-EMF
But I haven't found great descriptions of the features like
Package->Model->Resource Type->Basic (that you alerted me to).
I think I'm going to pick up the "EMF: Eclipse Modeling Framework, 2nd
Edition" book this week (and hopefully it describes some of these features).
Thanks again for your help!
>> -Jeff
Re: is EMF right solution for me? - Overriding load / save format [message #431866 is a reply to message #431861] |
Tue, 28 July 2009 13:13 |
See comments inline below!
Jeff S. schrieb:
> Mario-
>> Hi Jeff,
>>> code like:
>>> resource =
>>> Resource resource =
>> Generate the code.
In fact this setting isn't really required because it just generates the
body of the Resource and ResourceFactory, which you can also do 'per hand'.
>> your file extension:
>> <parser
>> type="esxfile">
>> </parser>
>> </extension>
>> Resource resource =
>>> EMF is a good solution for me to use?
>> you could not use EMF for your purpose. Even if you don't use the
>> entire EMF framework you could still use the code generator to get
>> high-quality JavaBean like data classes with a fine-grained
>> notification mechanism for free...
We started (almost) the same way and now we're using EMF all around our
application...
One little hint: If you plan to use EMF for more than just creating java
beans, make sure that all model modifications are done via EMF-commands
(either existing or custom ones). Do not directly modify the model (via
setters and getters) - except from within your own commands - as this
will get you into troubles if you want to use extended EMF features like
undo/redo, EMF Transaction API, and so on.
I'm writing this because in the beginning we didn't consider this and
had to work hard to fix that.
>>> how to load/save correctly, I will continue to tweak it:
>> Mario
Usually you do not have to tweak lots of the .genmodel parameters - the
default values are very useful. I consider it more important to
carefully design the model and use the correct settings there (e.g.
derived or transient attributes, containment vs. references, etc.)
> features).
Yes. Good idea! This book is really helpful!
You're welcome!
>>> -Jeff
Current Time: Fri Apr 19 01:27:04 GMT 2024
Powered by FUDForum. Page generated in 0.03131 seconds
