Home » Modeling » EMF » [CDO] Thread race condition with two transactions.
Re: [CDO] Thread race condition with two transactions. [message #431621 is a reply to message #431619] |
Sun, 19 July 2009 07:17 |
Kai,
I fear we must apologize because the reload() methods, i.e.
CDOObject.cdoReload() and CDOView.reload() are meant to be removed:
274111: Remove CDOView.reload
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274111
It seems to be a historical relict and we even could not find out why it
was provided initially (crippeled CVS history after move) ;-(
As an alternative solution in your scenario we could consider adding a
utility method that blocks until a given commit operation of transaction
A is visible in transaction B:
transactionA.commit();
long commitTime = transactionA.getLastCommitTime();
viewB.waitForCommit(commitTime);
Would that help? Please file file an enhancement request ;-)
Cheers
/Eike
Kai Schlamp schrieb:
> Something I should have mentioned. In thread A I use object.cdoReload
> when that event occurs. I assumed that by object.cdoReload the
> repository is checked if there are any updates (and thread B already
> committed at that time). But the committed changes are still not there
> after cdoReload.
> So it seems that cdoReload does not do what I expect from it.
> Kai Schlamp wrote:
>> Hello.
>> I have the following problem.
>> I have two threads with each having a CDO transaction of the same
>> session accessing the same resource. In thread B I imported an object
>> of thread A by using transaction.getObject(). In thread B I
>> manipulate the object, commit and fire a separate event (with that
>> object attached). That event is consumed by thread A again which
>> imports the event attached object by it's transaction.getObject().
>> The problem is now that sometimes the modifications of thread B are
>> visible in thread A, and sometimes not.
>> Is there a way to make sure that all updates from the other thread
>> have arrived?
>> Regards,
>> Kai
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Thread race condition with two transactions. [message #431625 is a reply to message #431624] |
Sun, 19 July 2009 11:40 |
> In the meantime I am listening to changes with the help of
> CDOViewInvalidationEvent and CDOTransactionHandler, but I still think
> that this would be a good enhancement.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=283947
Thx.
> Another question. Is enabling CDOViewInvalidationEvent a big overhead?
> (I guess that's why it is no enabled by default).
It's not too big, although it can involve some extra threads and EMF
adapter notification.
It's not the default because CDOSessionInvalidationEvent often is a
better alternative, like in this case.
Cheers
/Eike
> Eike Stepper wrote:
>> Kai,
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>>> after cdoReload.
>>> Kai Schlamp wrote:
>>>> Hello.
>>>> have arrived?
>>>> Regards,
>>>> Kai
Cheers
/Eike
Re: [CDO] Thread race condition with two transactions. [message #431632 is a reply to message #431628] |
Sun, 19 July 2009 13:43 |
> I just tried it with CDOSessionInvalidationEvent instead, and guess
> what ... the same problem of not visible updates in transaction A.
> If I listen to CDOSessionInvalidationEvent in thread A, it is not
> guaranteed that the updates of transaction B in thread B have already
> arrived.
> With CDOViewInvalidationEvent that works (at least I have not had a
> problem so far).
> Is that really the way it should be?
Sorry, my fault ;-(
Yes, it's meant to be like that: CDOSessionInvalidationEvent indicates
avaiability of new revisions. The same internal code that fires these
events also calls the internal view methods that emit the EMF
notifications and finally fire the CDOViewInvalidationEvent. But the
last two happen asynchronously.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] Thread race condition with two transactions. [message #431635 is a reply to message #431634] |
Sun, 19 July 2009 14:27 |
Kai,
Yes, I'll also use CDOViewInvalidationEvent for the new convenience methods.
Cheers
/Eike
>>> arrived.
>>> problem so far).
>> Sorry, my fault ;-(
> Just for clarification ... when I use CDOViewInvalidationEvent in my
> example I can always assume that the object in transaction A of thread
> A is completely updated (with the modifications from transaction B),
> and so CDOViewInvalidationEvent is the way to go for me.
> Right?
> Thanks in advance,
> Kai
Cheers
/Eike
Re: [CDO] Thread race condition with two transactions. [message #431636 is a reply to message #431633] |
Sun, 19 July 2009 14:28 |
Kai Schlamp Messages: 344 Registered: July 2009 |
Oh thanks for the hint, Simon. I also must update the FAQ then, as I just added the
CDOViewInvalidationEvent there.
By the way, may I ask you, if you could take a short look in bug 279982
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some time in the next days.
It would mean much to me and my project.
Simon McDuff wrote:
> Small comments:
> CDOViewInvalidationEvent will always be trigger as soon as you have
> objects in your view that are invalidate. You do not control that.
> This is different than from the
> view.options().isInvalidationNotificationEnabled().
> isInvalidationNotificationEnabled will enabled EMF notifications.
> Simon
>> Thx.
>> Cheers
>> /Eike
>>> Eike Stepper wrote:
>>>> Kai,
>>>> why it
>>>> transaction
>>>> Cheers
>>>> /Eike
>>>>> after cdoReload.
>>>>> Kai Schlamp wrote:
>>>>>> Hello.
>>>>>> have arrived?
>>>>>> Regards,
>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431637 is a reply to message #431636] |
Sun, 19 July 2009 14:35 |
Simon Mc Duff Messages: 596 Registered: July 2009 |
The following is working
public void testLengthAnnotationPositive() throws Exception
disableConsole();
msg("Opening session");
CDOSession session = openModel1Session();
msg("Opening transaction");
CDOTransaction transaction1 = session.openTransaction();
msg("Creating resource");
CDOResource resource = transaction1.createResource("/test1");
List<Product1> products = new ArrayList<Product1>();
for (int i = 0; i < 1000; i++)
Product1 product = Model1Factory.eINSTANCE.createProduct1();
product.setName("unmodified");
products.add(product);
resource.getContents().add(product);
transaction1.commit();
final CDOTransaction transaction2 = session.openTransaction();
final ConcurrentValue<Boolean> changed = new
ConcurrentValue<Boolean>(Boolean.FALSE);
transaction1.addListener(new IListener()
public void notifyEvent(IEvent event)
if (event instanceof CDOViewInvalidationEvent)
changed.set(Boolean.TRUE);
for (Product1 product : products)
Product1 importedProduct = transaction2.getObject(product);
importedProduct.setName("modified");
transaction2.commit();
changed.acquire(Boolean.TRUE);
changed.set(Boolean.FALSE);
Product1 reimportedProduct = transaction1.getObject(importedProduct);
assertEquals("modified", reimportedProduct.getName());
> just added the CDOViewInvalidationEvent there.
> next days.
> Simon McDuff wrote:
>> Small comments:
>> Simon
>>> Thx.
>>> Cheers
>>> /Eike
>>>> Eike Stepper wrote:
>>>>> Kai,
>>>>> why it
>>>>> transaction
>>>>> Cheers
>>>>> /Eike
>>>>>> there
>>>>>> after cdoReload.
>>>>>> Kai Schlamp wrote:
>>>>>>> Hello.
>>>>>>> object
>>>>>>> have arrived?
>>>>>>> Regards,
>>>>>>> Kai
Re: [CDO] Thread race condition with two transactions. [message #431638 is a reply to message #431637] |
Sun, 19 July 2009 14:37 |
The only things that is missing is the following:
CDOViewInvalidationEvent.getView() (TO know from which source is come from).
Simon
> disableConsole();
>> 279982 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=279982) some
>> Simon McDuff wrote:
>>> Small comments:
>>> Simon
>>>> Thx.
>>>> Cheers
>>>> /Eike
>>>>> Eike Stepper wrote:
>>>>>> Kai,
>>>>>> why it
>>>>>> adding a
>>>>>> transaction
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> object.cdoReload
>>>>>>> there
>>>>>>> after cdoReload.
>>>>>>> Kai Schlamp wrote:
>>>>>>>> Hello.
>>>>>>>> object
>>>>>>>> have arrived?
>>>>>>>> Regards,
>>>>>>>> Kai
Current Time: Fri Apr 19 06:12:26 GMT 2024
Powered by FUDForum. Page generated in 0.02972 seconds
