Home » Modeling » EMF » [CDO] CDO sources workspace setup under Linux
[CDO] CDO sources workspace setup under Linux [message #431592] Sat, 18 July 2009 11:59 Go to next message
Kai Schlamp is currently offline Kai SchlampFriend
Eike, as we already discussed some time, when setting up the workspace with the provided
SetupWorkspace under Linux, it fails cause SetupWorkspace.java can't unpack tar.gz files.
If you would add org.apache.ant as a referenced library to develop.setup, then I could implement
that also a tar.gz file is handled correctly.
Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431593 is a reply to message #431592] Sat, 18 July 2009 12:05 Go to previous messageGo to next message
Or better to say ... I just need ant.jar
> with the provided SetupWorkspace under Linux, it fails cause
> develop.setup, then I could implement that also a tar.gz file is handled
> correctly.
> Regards,
> Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431594 is a reply to message #431593] Sat, 18 July 2009 12:41 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Can you file a bugzilla with the patch?
I'd be happy to apply it ;-)
Cheers
/Eike
>> workspace with the provided SetupWorkspace under Linux, it fails
>> handled correctly.
>> Regards,
>> Kai
Re: [CDO] CDO sources workspace setup under Linux [message #431615 is a reply to message #431594] Sat, 18 July 2009 13:36 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283928
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>>> handled correctly.
>>> Regards,
>>> Kai
Previous Topic:Distinguishing between XMIException
Next Topic:[CDO] CDO sources and "Unsatisfied version constraint"
Current Time: Fri Jan 22 01:37:44 GMT 2021
Powered by FUDForum. Page generated in 0.02641 seconds
