Home » Modeling » EMF » How to display emf data model items in logical folders in treeview
How to display emf data model items in logical folders in treeview [message #431511] Tue, 14 July 2009 16:45 Go to next message
Kyle is currently offline KyleFriend
I created an emf model from an XML definition, where I have a MyFiles
object that contains a list of filename objects:
DocumentRoot
+- MyExplorer
+-MyFiles
---file1
---file2
---file3
---file4
where:
file1 = /root/file1
file2 = /root/subdir1/file2
file3 = /root/subdir1/file3
file4 = /root/subdir2/file4
Currently, when I display the data model in a treeview, I see each
filename object listed in the main MyFiles folder.
Instead, I would like to display each filename either under the
MyFiles root folder, or in logical subfolders based on the directory
where the file resides, so:
So I would want to see:
DocumentRoot
+- MyExplorer
+-MyFiles
--- file1
+- subdir1
---file2
---file3
+-subdir2
---file4
I would like to be able to do this in such a way that I wouldn't need
to modify my model in order to display these virtual folders. Can
anyone give me any pointers or suggestions?
Re: How to display emf data model items in logical folders in treeview [message #431514 is a reply to message #431511] Tue, 14 July 2009 19:39 Go to previous messageGo to next message
It looks like what I am trying to do is what the user describes he is
doing in this old thread:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg00572.html
However, he did not post his code he is using to do this.
Re: How to display emf data model items in logical folders in treeview [message #431537 is a reply to message #431511] Wed, 15 July 2009 13:54 Go to previous message
Kyle,
Comments below.
> DocumentRoot
> +- MyExplorer
> +-MyFiles
> ---file1
> ---file2
> ---file3
> ---file4
> where:
> file1 = /root/file1
> DocumentRoot
> +- MyExplorer
> +-MyFiles
> --- file1
> +- subdir1
> ---file2
> ---file3
> +-subdir2
> ---file4
It depends a little bit on how fancy you want to get. Certainly it's
possible to make MyFiles be stateful (a GenFeature property) and modify
the getChildren method to return something different from now. You
could use ItemProvider instances to induce folders that ultimately
contain files as the leaves. Or you could reuse specialized instances
of the MyFilesItemProvider to act as folders where basically the
getChildren shows a filtered list of "folders" and file leaves,
depending on the "folder path" they represent. That approach will be
more amenable to dealing with notifications to changes in the structure.
Ed Merks
Previous Topic:Model referencing existing emf classes
Next Topic:[EMF] Combining Reflective EMF with generated model code
Current Time: Wed Nov 25 03:22:27 GMT 2020
Powered by FUDForum. Page generated in 0.01844 seconds
