Home » Modeling » EMF » Refer to an EAttribute of a different model
Refer to an EAttribute of a different model [message #431484] Mon, 13 July 2009 09:35 Go to next message
Sebastian Fuchs is currently offline Sebastian FuchsFriend
Member
I need some help in understanding how I can use EMF for MDSD.
My idea is to use an EMF generated Ecore model M1 as data model and to
have another Ecore model M2 describing details of my application, e.g.
the structure of an editor.
M2 should be transformed to Java code by XPand.
How can I refer at modelling time (e.g. in the ecore editor) from M2 to
an EAttribute of M1, e.g. to say that a particular EDouble of the model
(instances at runtime) should be displayed in that particular text field
(described by M2) ?
Thanks for your answers
Sebastian
Re: Refer to an EAttribute of a different model [message #431485 is a reply to message #431484] Mon, 13 July 2009 10:47 Go to previous messageGo to next message
Joel Greenyer is currently offline Joel GreenyerFriend
Hello Sebastian,
to pinpoint the attribute value, you can reference the data object and the EAttribute in the (meta-)model.
Joel
Sebastian Fuchs wrote:
> Hello,
> (described by M2) ?
> Sebastian
Re: Refer to an EAttribute of a different model [message #431486 is a reply to message #431485] Mon, 13 July 2009 11:35 Go to previous messageGo to next message
Member
Hi Joel,
Unfortunately I am not sure WHICH metamodel you mean.
Here is what I want:
// the metamodel for all possible editors in applications
// MM2
Editor.ecore
- EClass TextField
- EAttribute EString 'label' // the label of the Field
- EReference EAttribute 'modelProperty' // the Property of an
(yet) unknown datamodel to show
// the datamodel for a concrete application
// M1
Person.ecore
- EClass Person
- EAttribute EString 'name' // the name of a Person
// model of a person editor of the concrete application
// dynamic instance of Editor.ecore
// M2
PersonEditor.xmi
- TextField
- label = "Person's name"
- modelProperty = ***Person.ecore#EAttribute('name')***
So far I am not able to either select Person nor one of its attribute
in the properties view of the PersonEditor.xmi-Editor.
I even tried to let Person be an dynamic instance of the ecore-model
(platform:/plugin/org.eclipse.emf.ecore/model/Ecore) without success.
Sebastian
Joel Greenyer schrieb:
> Hello Sebastian,
> Joel
Re: Refer to an EAttribute of a different model [message #431490 is a reply to message #431486] Mon, 13 July 2009 13:39 Go to previous messageGo to next message
Sebastian,
In all cases, if you use Load Resource... to load a resource, the
objects in that resource will be available for any feature whose type
allows that object. So loading Person.ecore into the PersonEditor.xmi
shoudl make the Person EClass and the name EAttribute available...
> Hi Joel,
> // MM2
> Editor.ecore
> - EClass TextField
> // M1
> Person.ecore
> - EClass Person
> // M2
> PersonEditor.xmi
> - TextField
> Sebastian
>> Hello Sebastian,
>> Joel
Re: Refer to an EAttribute of a different model [message #431492 is a reply to message #431490] Mon, 13 July 2009 14:39 Go to previous messageGo to next message
Member
It works when I specify "modelProperty" as an EObject.
When loading ressource
platform:/plugin/org.eclipse.emf.ecore/model/Ecore in Editor.ecore
to specify "modelProperty" as an EAttribute, I can't select any value
in PersonEditor.xmi after reopening the xmi-editor.
Overall it works now - thank you.
Sebastian
Ed Merks schrieb:
> Sebastian,
>> Hi Joel,
>> // MM2
>> Editor.ecore
>> - EClass TextField
>> // M1
>> Person.ecore
>> - EClass Person
>> // M2
>> PersonEditor.xmi
>> - TextField
>> Sebastian
>>> Hello Sebastian,
>>> Joel
Re: Refer to an EAttribute of a different model [message #431494 is a reply to message #431492] Mon, 13 July 2009 14:46 Go to previous message
Sebastian,
Comments below.
Well, Ecore being it's own meta model does lead to some odd cases. But
I do expect your generated model to refer to the actual
EcorePackage.Literals.EATTRIBUTE instance and for loaded *.ecore models
to have objects that are an instance of that class...
> Sebastian
> Ed Merks schrieb:
>> Sebastian,
>> PersonEditor.xmi shoudl make the Person EClass and the name
>>> Hi Joel,
>>> // MM2
>>> Editor.ecore
>>> - EClass TextField
>>> // M1
>>> Person.ecore
>>> - EClass Person
>>> // M2
>>> PersonEditor.xmi
>>> - TextField
>>> Sebastian
>>>> Hello Sebastian,
>>>> Joel
Previous Topic:[CDO] Weird race condition when committing
Next Topic:passing a hibernate.cfg.xml to teneo
Current Time: Mon Jul 13 06:31:09 GMT 2020
Powered by FUDForum. Page generated in 0.02718 seconds
