Re: EStructuralFeature.isNullable() [message #431284 is a reply to message #431283] |
Tue, 07 July 2009 14:06 |
Ed Merks Messages: 33141 Registered: July 2009 |
Sven,
Comments below.
Sven Efftinge wrote:
> how can I find out whether a certain feature can be set to null?
Perhaps you should consider unsetting the feature, i.e., eUnset(feature)
rather eSet(feature, null). Certainly null isn't going to be valid for
an isMany feature, nor will it be valid for a single-valued feature if
EDataType.getInstanceClass().isPrimitive() is true because null is not
in the value space for primitives. There's also
EClassifier.getDefaultValue() which is null except for primitives.
> For example if I have a feature of type EInt I get a
> classcastexception, because under the hood the code trys to autobox
> null to an int.
> Are there any flags, which could give me a hint?
Maybe I should ask specifically what you're trying to do because eUnset
might be better, or setting to the feature's type's default value might
be better, but there's a subtle difference of course because an
unsettable feature will be set after you call eSet...
> Cheers,
> Sven
Ed Merks
Re: EStructuralFeature.isNullable() [message #431285 is a reply to message #431284] |
Tue, 07 July 2009 14:28 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Ed,
"EDataType.getInstanceClass().isPrimitive()" is what I was asking for.
I was just stumbling over a bug in Xtext
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=280873) and was curious
about how to find this out reflectively.
Sven
Ed Merks schrieb:
> Sven,
> Comments below.
>> Hi,
>> null to an int.
>> Cheers,
>> Sven
FUDForum. Page generated in 0.04884 seconds
