Home » Modeling » EMF » [Teneo] No longer need EMFTupelizer override?
Re: [Teneo] No longer need EMFTupelizer override? [message #431271 is a reply to message #431270] |
Tue, 07 July 2009 08:45 |
David Wynter Messages: 4624 Registered: July 2009 |
I manually added org.eclipse.emf.teneo.hibernate as a plugin dependency
in MANIFEST.MF, it did not complain. But when I show the plugin
dependencies it does not include the
org.eclipse.emf.teneo.hibernate.extra and TeneoInternalEOject still
cannot be resolved to a type. when I click "Find unused dependencies" it
finds org.eclipse.emf.teneo.hibenate?
Thx.
David
David Wynter wrote:
> That explains it. I do not have that plugin in the Galileo install,
> org.eclipse.emf.teneo.hibernate.eclipse is there as a plugin but not
> org.eclipse.emf.teneo.hibernate. In fact the only plugins listed are
> org.eclipse.emf.teneo.hibernate.eclipse.source
> org.eclipse.emf.teneo.hibernate.mapper.source
> org.eclipse.emf.teneo.hibernate.hibernate.source
> I did an update of Teneo Hibernate and it tells me that it is already
> installed, I assume it checks all the jars.
> Ideas?
> David
> Martin Taal wrote:
>> Hi David,
>> It is inside the org.eclipse.emf.teneo.hibernate plugin/jar file.
>> Afaics the package (org.eclipse.emf.teneo.hibernate.mapping.internal)
>> is exported by that plugin.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> That jar you mention does not appear to be in the std install of
>>> Galileo with EMF? org.eclipse.emf.teneo.hibernate.extra.jar
>>> Where do I get it from?
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> It is still there though, see line 218 in the EMFTuplizer. This is
>>>> related to a very detailed thing:
>>>> This interface ensures that the cglib proxyfactory does not
>>>> encounter a security exception
>>>> because the EMF InternalEObject is signed with a different signature.
>>>> The TeneoInternalEObject is located in a separate jar file inside of
>>>> (org.eclipse.emf.teneo.hibernate.extra.jar). This to prevent it from
>>>> being signed by the build process.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> I have updated to Teneo 1.1.1 and Galileo. Based on a previous
>>>>> message here I built an override class for the EMFTupelizer ( I
>>>>> cannot even remember why now...).
>>>>> When I upgraded the import
>>>>> org.eclipse.emf.teneo.hibernate.mapping.internal has gone and with
>>>>> it the interface used here:
>>>>> proxyInterfaces.add(TeneoInternalEObject.class);
>>>>> I could not find the Javadoc for Teneo online. where has
>>>>> TeneoInternalEObject gone?
>>>>> Thx.
>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431273 is a reply to message #431271] |
Tue, 07 July 2009 09:29 |
Hi David,
org.eclipse.emf.teneo.hibernate.extra is not a plugin but a jar file in org.eclipse.emf.teneo.hibernate. This package
which contains the TeneoInternalEOject is org.eclipse.emf.teneo.hibernate.mapping.internal. This package is exported by
the org.eclipse.emf.teneo.hibernate plugin. So I would hope that after adding the org.eclipse.emf.teneo.hibernate plugin
to the dependency that you can use the TeneoInternalEObject.... Or can you try import packages with the
org.eclipse.emf.teneo.hibernate.mapping.internal package?
gr. Martin
David Wynter wrote:
> Thx.
> David
> David Wynter wrote:
>> Hi,
>> Ideas?
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> of org.eclipse.emf.teneo.hibernate
>>>>> from being signed by the build process.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> Thx.
>>>>>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] No longer need EMFTupelizer override? [message #431275 is a reply to message #431273] |
Tue, 07 July 2009 10:47 |
Hi again,
When I use the auto complete on the import for that
org.eclipse.emf.teneo.hibernate.mapping.internal package it does not
show up.
Only the org.eclipse.emf.teneo.hibernate.mapping.econtainer,
org.eclipse.emf.teneo.hibernate.mapping.elist,
org.eclipse.emf.teneo.hibernate.mapping.identifier and
org.eclipse.emf.teneo.hibernate.mapping.property show up as packages.
So I opened the jar file and there is not internal under mapping! So it
must be in a different jar? I am looking at
org.eclipse.emf.teneo.hibernate_1.1.0.v200906180911.jar
Thx.
David
Martin Taal wrote:
> Hi David,
> org.eclipse.emf.teneo.hibernate. This package which contains the
> This package is exported by the org.eclipse.emf.teneo.hibernate plugin.
> plugin to the dependency that you can use the TeneoInternalEObject....
> gr. Martin
> David Wynter wrote:
>> Hi,
>> dependency in MANIFEST.MF, it did not complain. But when I show the
>> plugin dependencies it does not include the
>> it finds org.eclipse.emf.teneo.hibenate?
>> Thx.
>> David
>> David Wynter wrote:
>>> Hi,
>>> Ideas?
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> Afaics the package
>>>> (org.eclipse.emf.teneo.hibernate.mapping.internal) is exported by
>>>> that plugin.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> with it the interface used here:
>>>>>>> Thx.
>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431276 is a reply to message #431275] |
Tue, 07 July 2009 10:50 |
Hi David,
And do you see the extra jar file in the plugin itself? The TeneoInternalEObject is located in that jar file.
The strange thing is that if I try this with the development projects it works (importing the TeneoInternalEObject in
another class in another plugin is possible).
gr. Martin
David Wynter wrote:
> Hi again,
> show up.
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> in org.eclipse.emf.teneo.hibernate. This package which contains the
>> exported by the org.eclipse.emf.teneo.hibernate plugin. So I would
>> hope that after adding the org.eclipse.emf.teneo.hibernate plugin to
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> Thx.
>>> David
>>> David Wynter wrote:
>>>> Hi,
>>>> already installed, I assume it checks all the jars.
>>>> Ideas?
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> Afaics the package
>>>>> that plugin.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> is related to a very detailed thing:
>>>>>>> signature.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431278 is a reply to message #431276] |
Tue, 07 July 2009 10:59 |
Yes I should have read your response more carefully. It is in the extras
jar file. But it does not seem to be exported, I am on Ubuntu 9.0.4 now
not Windoze as previous, maybe that is a difference?
David
Martin Taal wrote:
> Hi David,
> works (importing the TeneoInternalEObject in another class in another
> gr. Martin
> David Wynter wrote:
>> Hi again,
>> show up.
>> it must be in a different jar? I am looking at
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> dependencies" it finds org.eclipse.emf.teneo.hibenate?
>>>> Thx.
>>>> David
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> not org.eclipse.emf.teneo.hibernate. In fact the only plugins
>>>>> listed are
>>>>> Ideas?
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> Afaics the package
>>>>>> that plugin.
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> signature.
>>>>>>>> inside of org.eclipse.emf.teneo.hibernate
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> Thx.
>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431279 is a reply to message #431278] |
Tue, 07 July 2009 11:07 |
I am on Ubuntu to :-)
I think the problem is that the TeneoInternalEObject is in a jar inside the plugin and the plugin is not unpacked.
Normally this is not a problem (who wants to get to this terrible object anyway ;-). But now I can see that you are
stuck with this.
Can you unzip the org.eclipse.emf.teneo.hibernate plugin? in the plugins directory (so it becomes a folder)? and then
remove the org.eclipse.emf.teneo.hibernate.jar file (so that only the folder remains), and then restart Eclipse with the
-clean in the eclipse.ini file.
gr. Martin
David Wynter wrote:
> David
> Martin Taal wrote:
>> Hi David,
>> it works (importing the TeneoInternalEObject in another class in
>> gr. Martin
>> David Wynter wrote:
>>> Hi again,
>>> show up.
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx.
>>>>> David
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> install, org.eclipse.emf.teneo.hibernate.eclipse is there as a
>>>>>> plugin but not org.eclipse.emf.teneo.hibernate. In fact the only
>>>>>> plugins listed are
>>>>>> Ideas?
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> Afaics the package
>>>>>>> that plugin.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> signature.
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I cannot even remember why now...).
>>>>>>>>>> Thx.
>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431282 is a reply to message #431279] |
Tue, 07 July 2009 13:44 |
I unpacked the whole teneo.hibernate jar and linked to the extras jar as
a variable. But it stopped the plugin working as a plugin.
I also tried unpacking just the extras jar and putting that in the
plugin directory and linking to that as a variable, that worked.
David
> the plugin and the plugin is not unpacked. Normally this is not a
> can see that you are stuck with this.
> directory (so it becomes a folder)? and then remove the
> remains), and then restart Eclipse with the -clean in the eclipse.ini file.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> extras jar file. But it does not seem to be exported, I am on Ubuntu
>> 9.0.4 now not Windoze as previous, maybe that is a difference?
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi again,
>>>> show up.
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> file in org.eclipse.emf.teneo.hibernate. This package which
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> still cannot be resolved to a type. when I click "Find unused
>>>>>> Thx.
>>>>>> David
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> plugins listed are
>>>>>>> Ideas?
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> file. Afaics the package
>>>>>>>> by that plugin.
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> of Galileo with EMF? org.eclipse.emf.teneo.hibernate.extra.jar
>>>>>>>>> Thx.
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> This is related to a very detailed thing:
>>>>>>>>>> signature.
>>>>>>>>>> it from being signed by the build process.
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> previous message here I built an override class for the
>>>>>>>>>>> EMFTupelizer ( I cannot even remember why now...).
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431288 is a reply to message #431282] |
Tue, 07 July 2009 15:15 |
Hi David,
Hmm, this does not sound like a long-term strategy. I am wondering if there is another way to do this. To understand the
background, for what reason do you extend the EMFTuplizer?
gr. Martin
David Wynter wrote:
> David
>> inside the plugin and the plugin is not unpacked. Normally this is not
>> now I can see that you are stuck with this.
>> plugins directory (so it becomes a folder)? and then remove the
>> file.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> projects it works (importing the TeneoInternalEObject in another
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi again,
>>>>> not show up.
>>>>> So it must be in a different jar? I am looking at
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> Thx.
>>>>>>> David
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> plugins listed are
>>>>>>>> Ideas?
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> by that plugin.
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Thx.
>>>>>>>>>> David
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi David,
>>>>>>>>>>> signature.
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> and with it the interface used here:
>>>>>>>>>>>> Thx.
>>>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431382 is a reply to message #431288] |
Wed, 08 July 2009 10:20 |
Back in Nov 18th 2008 I added a override class for EMFTuplizer. You
advised this because at the time Teneo was getting a CCE due to taking a
class out of an unordered List of some kind, I cannot find the email. I
searched the Release notes of all Teneo releases since then for the term
EMFTuplizer and could not find it, so am not sure whatever it was that
was wrong is now fixed.
I reverted to not use my override and use EMFTuplizer and I still get
the class not found error at runtime for EMFTuplizer. I have removed the
extras jar and the reference to it, back to a std install of Teneo 1.1.0.
I tried to update to Teneo 1.1.1 SDK but ended up in the usual
dependency hell that p2 is supposed to prevent. It is trying to install
the already install V1.1.0 and the V1.1.1 in the dropins directory at
the same time. Also comparing th eTeneo SDK 1.1.1 with an the EMF
Moidelling plugin?
I reverted to just the Teneo 1.1.1 runtime and the dropins does not get
deployed, I click update and it says nothing to deploy, what a pile of
crap p2 is. Take me back to the old UM, at least it worked.
So at the moment I am stalled.
David
Martin Taal wrote:
> Hi David,
> there is another way to do this. To understand the background, for what
> gr. Martin
> David Wynter wrote:
>> Hi,
>> as a variable. But it stopped the plugin working as a plugin.
>> David
>>> But now I can see that you are stuck with this.
>>> file.
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi again,
>>>>>> not show up.
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Thx.
>>>>>>>> David
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> Ideas?
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> by that plugin.
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>> Hi David,
>>>>>>>>>>>> signature.
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Thx.
>>>>>>>>>>>>> David
Re: [Teneo] No longer need EMFTupelizer override? [message #431391 is a reply to message #431382] |
Wed, 08 July 2009 10:38 |
Hi David,
The latest build (5 minutes old) contains an unpacked teneo.hibernate plugin:
http://www.eclipse.org/modeling/emf/downloads/?project=teneo &showAll=1&hlbuild=M200907080536#M200907080536
As a tip, the last few times I installed plugins/features I did not put them in dropins anymore but just directly in the
eclipse installation (so that the files end up in features/plugins). That seemed to work.... (but no guarantees from my
side).
gr. Martin
David Wynter wrote:
> Moidelling plugin?
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> David
>>>> eclipse.ini file.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Ubuntu 9.0.4 now not Windoze as previous, maybe that is a difference?
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi again,
>>>>>>> not show up.
>>>>>>> packages.
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> is exported by the org.eclipse.emf.teneo.hibernate plugin. So I
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> the
>>>>>>>>> Thx.
>>>>>>>>> David
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Ideas?
>>>>>>>>>> David
>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>> Hi David,
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> install of Galileo with EMF?
>>>>>>>>>>>> Thx.
>>>>>>>>>>>> David
>>>>>>>>>>>> Martin Taal wrote:
>>>>>>>>>>>>> Hi David,
>>>>>>>>>>>>> signature.
>>>>>>>>>>>>> prevent it from being signed by the build process.
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> Thx.
>>>>>>>>>>>>>> David
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431403 is a reply to message #431401] |
Wed, 08 July 2009 11:09 |
Well good luck that's what I can say....
The build runs all testcases on an eclipse installation with the same plugins installed as the ones which are
downloadable, the testcases all pass.
I hope that having the teneo.hibernate plugin unpacked will solve your class not found exception.
gr. Martin
David Wynter wrote:
> Yeah I tried that too, but they never show up as plugins anymore if I
> put them directly into the plugins and features directories. So then I
> cannot include them as dependencies in my plugin.xml.
> Tried with your latest build, but does not deploy from the dropins and
> is not recognized as a plugin if I place it directly in the plugins and
> features directories. Way to go p2 team!
> Might have to do a fresh install of Eclipse and start again.
> David
> Martin Taal wrote:
>> Hi David,
>> plugin:
>> put them in dropins anymore but just directly in the eclipse
>> seemed to work.... (but no guarantees from my side).
>> gr. Martin
The Netherlands
Re: [Teneo] No longer need EMFTupelizer override? [message #431418 is a reply to message #431403] |
Wed, 08 July 2009 16:58 |
It seems that publishing the new versions of Teneo without an Update
site is now a waste of time, as according to the guys on Equinox now
that Teneo is a managed set of bundles, dropins don't work.
I did try expanding teneo.hibernate jar for 1.1.0 that comes with
Galileo, but that created a whole new set of exceptions. So I will have
to wait until the next release with an Update Site for download.
David
Martin Taal wrote:
> plugins installed as the ones which are downloadable, the testcases all
> pass.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> and features directories. Way to go p2 team!
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> plugin:
>>> gr. Martin
Current Time: Thu Mar 28 19:23:29 GMT 2024
Powered by FUDForum. Page generated in 0.04307 seconds
