Home » Modeling » EMF » XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml
XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #431142] Tue, 30 June 2009 09:19 Go to next message
Guido Schnider is currently offline Guido SchniderFriend
I trying to remove the xsi:type information like
<language xsi:type="language">de</language>
and found the following code snipplet and tried it out but it has no
effect.
How can I remove the xsi type informatin when persisting to xml
resource.getDefaultSaveOptions().put(XMLResource.OPTION_SAVE _TYPE_INFORMATION,
Boolean.FALSE);
I'm using emf version 2.4
Thanks for you help!
Guido
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #431145 is a reply to message #431142] Tue, 30 June 2009 09:25 Go to previous messageGo to next message
Guido,
You need to provide an instance of XMLTypeInfo not just a Boolean.
Guido Schnider wrote:
> effect.
> Boolean.FALSE);
> Guido
Ed Merks
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #431151 is a reply to message #431145] Tue, 30 June 2009 10:08 Go to previous messageGo to next message
Thanks for the quick help, it works!
Here the code just as reference for others:
XMLTypeInfo typeInfo = new XMLSave.XMLTypeInfo() {
public boolean shouldSaveType(EClass arg0, EClassifier
arg1,EStructuralFeature arg2) {
return false;
public boolean shouldSaveType(EClass arg0, EClass arg1,EStructuralFeature
arg2) {
return false;
typeInfo);
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #661993 is a reply to message #431151] Mon, 28 March 2011 19:10 Go to previous messageGo to next message
Piotr Przybylski is currently offline Piotr PrzybylskiFriend
I tried to use this option and code from the previous post but it does not seem to have any effect when the type is xsd:uinon. Irrespective of the value returned by the XMLTypeInfo implementation, the xsi:type is always serialized. Is this caused by design of enforcing correct form irrespective of options ? Or can there be any other reason option has no effect for this specific type ? It does work for other types.
Thank you,
Piotr
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #661995 is a reply to message #661993] Mon, 28 March 2011 19:20 Go to previous messageGo to next message
Piotr,
I'd need to see a complete example. You have a global elements of that
union type?
Piotr Przybylski wrote:
> Hi, I tried to use this option and code from the previous post but it
> Thank you,
> Piotr
Ed Merks
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662094 is a reply to message #661995] Tue, 29 March 2011 09:25 Go to previous messageGo to next message
Ed,
I don't think there are global elements of that type, its defined as follows (relevant fragments, the whole thing is part of industry schemas - oagis/star)
<xsd:simpleType name="CountryContentType">
<xsd:union memberTypes=" CountryEnumeratedType"/>
</xsd:simpleType>
<xsd:simpleType name="CountryEnumeratedType">
<xsd:restriction base="xsd:normalizedString">
<xsd:enumeration value="US">
</xsd:enumeration>
<xsd:enumeration value="AF">
and being used deep down in the structure of the document, the trimmed xml looks something like code below, the [xsi:type="p:CountryEnumeratedType"] is the one I would like to remove.
<p:SyncVehicleServiceHistoryType xmlns:p="http://www.company.com/xsitypetest" xmlns:ns0="http://www.company.com/xsitypetest" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="p:SyncVehicleServiceHistoryType">
<p:SyncVehicleServiceHistoryDataArea>
<p:VehicleServiceHistory>
<p:VehicleServiceHistoryDetail>
<p:OwnerParty>
<p:SpecifiedPerson>
<p:PostalAddress>
<p:CountryID xmlns:ns1="http://www.company.com/xsitypetest" xsi:type="p:CountryEnumeratedType">US</p:CountryID>
</p:PostalAddress>
</p:SpecifiedPerson>
</p:OwnerParty>
</p:VehicleServiceHistoryDetail>
</p:VehicleServiceHistory>
</p:SyncVehicleServiceHistoryDataArea>
</p:SyncVehicleServiceHistoryType>
Thank you,
Piotr.
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662166 is a reply to message #662094] Tue, 29 March 2011 15:22 Go to previous messageGo to next message
Piotr,
Comments below.
> Ed, I don't think there are global elements of that type, its defined
Given there is an established schema, don't you need a serialization
that conforms to it?
> </xsd:simpleType>
> </xsd:enumeration>
This XML was produced by EMF?
> <p:OwnerParty>
> <p:SpecifiedPerson>
> <p:PostalAddress>
> <p:CountryID
What does the type for PostalAddress look like? In particular the
definition of the CountryID element and its type as well.
> </p:PostalAddress>
> </p:OwnerParty>
> Thank you,
> Piotr.
Ed Merks
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662186 is a reply to message #661995] Tue, 29 March 2011 16:18 Go to previous messageGo to next message
Ed,
yes, I would like to get XML matching schema but it seems the xsi:type for that specific element is invalid:
[Error] XSITypeTest.xml:9:110: cvc-elt.4.3: Type 'p:CountryEnumeratedType' is not validly derived from the type definition, 'CountryCodeType', of element 'p:CountryID'.
most likely caused by blockDefault="#all" directive.
Here is larger fragment of the schema with the types defined:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.company.com/xsitypetest" attributeFormDefault="unqualified"
blockDefault="#all" elementFormDefault="qualified"
targetNamespace="http://www.company.com/xsitypetest">
</xsd:enumeration>
</xsd:enumeration>
</xsd:restriction>
</xsd:simpleType>
<xsd:union memberTypes=" CountryEnumeratedType" />
</xsd:simpleType>
<xsd:simpleType name="CountryCodeType">
<xsd:restriction base="CountryContentType" />
</xsd:simpleType>
<xsd:complexType name="AddressABIEType">
<xsd:sequence>
<xsd:element name="City" type="xsd:string" minOccurs="0" />
<xsd:element name="State" type="xsd:string" minOccurs="0" />
<xsd:element minOccurs="0" name="CountryID" type="CountryCodeType">
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="PostalAddress" type="AddressABIEType">
</xsd:element>
Thank you,
Piotr.
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662237 is a reply to message #662186] Tue, 29 March 2011 18:43 Go to previous messageGo to next message
Piotr,
Comments below.
> Ed, yes, I would like to get XML matching schema but it seems the
It looks to me like it is validly derived. In any case, I don't see why
it's producing an xsi:type for a simple type in the first place. I'd
expect that only if there's a SimpleAnyType involved. You constructed
this instance using the generated APIs?
> </xsd:enumeration>
> </xsd:enumeration>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:simpleType>
> </xsd:simpleType>
> <xsd:sequence>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> Thank you,
> Piotr.
Ed Merks
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662475 is a reply to message #662237] Wed, 30 March 2011 18:15 Go to previous messageGo to next message
Ed,
thank you, you are absolutely right, the xsi:type is not generated by the api, it should not be there, at least in this case.
So it really is the question about figuring out if blockDefault="#all" is in effect when the serialization happens - saveElement in the XMLSaveImpl class.
Piotr
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #662492 is a reply to message #662475] Wed, 30 March 2011 20:11 Go to previous messageGo to next message
Piotr,
The mapping of XSD to Ecore ignores things like block/blockDefault so
there's nothing in EMF's serialization that supports it or knows about
it for that matter.
> Ed, thank you, you are absolutely right, the xsi:type is not generated
> by the api, it should not be there, at least in this case. So it
> class.
> Piotr
Ed Merks
Re: XMLResource.OPTION_SAVE_TYPE_INFORMATION has no effect when saved as xml [message #663407 is a reply to message #662492] Mon, 04 April 2011 21:31 Go to previous message
Ed,
that makes it clear, I suppose the mapping considers it irrelevant to any further processing. Thank you very much for your help.
Piotr.
Previous Topic:Filter the avaible values for a non-containment reference
Next Topic:Copying proxy objects
Current Time: Thu Jul 29 14:35:35 GMT 2021
Powered by FUDForum. Page generated in 0.03208 seconds
