problem with prefix [message #431002] |
Tue, 23 June 2009 22:38 |
Originally posted by: rodrigo.garcia.kotasoft.com
I have a problem with the ns prefix. Sometimes the xml is created
writing the prefix before each element, but sometimes without it.
I have checked the .ecore and the .genmodel and I can't see anything wrong.
Any idea?
Best regards and thank you
Re: problem with prefix [message #431026 is a reply to message #431003] |
Wed, 24 June 2009 14:59 |
Well, I have observed that it seems it doesn't change more, but I have
the xml without the prefix and I'd like to have the prefix.
I have this element:
<precondition description="anything"/>
But I'd like :
<com.kotasoft.core.model.usecase:precondition description="anything"/>
I have the basePackage and the nsPrefix defined.
Any idea?
Ed Merks escribió:
> Rodrigo,
> Comments below.
> Rodrigo García wrote:
>> Hi,
> What's the difference between the sometimes when it does and the
> sometimes when it doesn't?
>> wrong.
> What specifically were you looking for?
>> Any idea?
> I imagine that it depends on the values in the DocumentRoot's
> XMLPrefixMap value, but given that the difference between "sometimes"
> and "sometimes not" is mysterious, it's really hard to say much of
> anything informative...
Re: problem with prefix [message #431056 is a reply to message #431027] |
Thu, 25 June 2009 10:50 |
--------------030301040801090404000501
Is a nested one.
The element should be qualified.
I attatch you the .ecore and the .genmodel and an example of xml
generated with my model.
Do you need some more info?
Thank you
Ed Merks escribi
Re: problem with prefix [message #431124 is a reply to message #431058] |
Mon, 29 June 2009 16:54 |
Ok, thank you Ed.
Best regards
Ed Merks escribió:
> Rodrigo,
> This part of the serialization makes it clear that you're serializing
> with an XMIResourceImpl
> <com.kotasoft.core.model.usecase:Usecase xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:com.kotasoft.core.model.usecase="http://kotasoft.com/usecase" name="UC-001" id="_eFym8WFmEd6ozbsTiu8hnQ" description="UC-001">
> You need to ensure that the generated resource factory with the right
> options is used to create the resource you use for loading and saving
> your instances.
>> Is a nested one.
>> Thank you
>> Ed Merks escribió:
>>> Rodrigo,
>>> Comments below.
>>>> have the xml without the prefix and I'd like to have the prefix.
>>> Hmmm.
>>> Is this a root element in the serialization or a nested one?
>>>> But I'd like :
>>> Is the element supposed to be qualified according to the schema or is
>>> it just an unqualified local element?
>>>> Any idea?
>>> You provide to little information for me to help properly.
>>>> Ed Merks escribió:
>>>>> Rodrigo,
>>>>> Comments below.
>>>>>> Hi,
>>>>>> anything wrong.
>>>>>> Any idea?
>>>>> "sometimes" and "sometimes not" is mysterious, it's really hard to
>>>>> say much of anything informative...
FUDForum. Page generated in 0.03293 seconds
