[ATL] An internal error occurred during: "Launching". [message #43201] |
Wed, 30 May 2007 22:44 |
Originally posted by: aquamp.gmail.com
hello,
I am new to ATL and trying a transformation using the same ource and
target metamodel (AADL by uri:http:///AADL/core, both source and target
models AADL)
It was working for a few rules, as I added another the Launching error
popped up. I reverted back to the state where it was working but it
continued to throw the error. Also tried with the option 'Continue
execution after errors in run mode'.
I have gone back to the point where there is a single rule and a very
simple input file but does not help. In ATL debugger, main thread
terminates at once.
Can someone help me get thru this? Thanks in advance for your time.
The ATL console had printed the following socketexception once but has
been displaying "Dumping ASM to /AADL2AADL/AADL2AADL1.asm" for some time
now.
java.net.SocketException: Software caused connection abort: socket write
error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at java.io.DataOutputStream.flush(Unknown Source)
at
org.atl.engine.vm.adwp.ADWPDebugger.realSendCommand(ADWPDebu gger.java:34)
at org.atl.engine.vm.adwp.ADWPDebugger.sendCommand(ADWPDebugger .java:23)
at
org.atl.eclipse.adt.debug.core.AtlDebugTarget.breakpointChan ged(AtlDebugTarget.java:291)
at
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.run(BreakpointManager.java:801)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.notify(BreakpointManager.java:821)
at
org.eclipse.debug.internal.core.BreakpointManager.fireUpdate (BreakpointManager.java:735)
at
org.eclipse.debug.internal.core.BreakpointManager.access$1(B reakpointManager.java:725)
at
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint ManagerVisitor.update(BreakpointManager.java:605)
at
org.eclipse.debug.internal.core.BreakpointManager.resourceCh anged(BreakpointManager.java:541)
at
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:280)
at
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:274)
at
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
at
org.eclipse.core.internal.resources.Workspace.broadcastBuild Event(Workspace.java:240)
at
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:146)
at
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
----- and the exception: java.lang.NullPointerException
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:247)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:168)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:145)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:121)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:97)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
Re: [ATL] An internal error occurred during: "Launching". [message #43266 is a reply to message #43236] |
Wed, 30 May 2007 23:26 |
Thank you for the quick reply. I tried debugging after removing
breakpoints, still get the same error. The console prints:
****** BEGIN Stack Trace
exception:
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:26 5)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.debug(AtlLauncher.java:84 )
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:228)
at
at
at
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .access$0(AtlLaunchConfigurationDelegate.java:107)
at
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate $1.run(AtlLaunchConfigurationDelegate.java:85)
A.main() : ??#22 null
local variables = {self=AADL2AADL1 : ASMModule}
local stack = []
A.__matcher__() : ??#5 null
local stack = []
A.__matchsystemImpl() : ??#2 null
local stack = []
****** END Stack Trace
Trying to continue execution despite the error.
I also tried naming source and target metamodels different, thought they
point to the same metamodel by uri, does not help.
FUDForum. Page generated in 0.03203 seconds
