Home » Modeling » EMF » EMF - Teneo-EclipseLink - @OneToMany
EMF - Teneo-EclipseLink - @OneToMany [message #429273] |
Thu, 16 April 2009 12:23 |
Robert Jaemmrich Messages: 17 Registered: July 2009 |
I'm trying to generate
- .genmodel
- orm.xml and
- Model/Edit Code
from an Ecore file with Teneo-EclipseLink.
This is working well for single entities, but my one-to-many relationship
fails. EclipseLink warns as follows:
[EL Warning]: Element [protected org.eclipse.emf.common.util.EList
simple.impl.WriterImpl.books] within entity class [class
simple.impl.WriterImpl] uses a collection type [interface
org.eclipse.emf.common.util.EList] when the JPA specification only
supports java.util.Collection, java.util.Set, java.util.List, or
java.util.Map. This type is supported with eager loading; using lazy
loading with this collection type requires additional configuration and an
IndirectContainer implementation that extends [interface
org.eclipse.emf.common.util.EList] or setting the mapping to use basic
indirection and the type to be ValueholderInterface.
I don't know how to set "the mapping to use basic indirection and the type
to be ValueholderInterface" in the Ecore file, strictly speaking. ;-)
BTW: Contents of the EclipseCon 2009 session
http://www.eclipsecon.org/2009/sessions?id=614
(Teneo--Integrating EMF & EclipseLink for Model-Driven Development with
Persistence)
are looking very promising, but I wasn't able to find any examples or
other uploaded content for that session yet. :-(
But maybe one could give me a hint how to fix my ecore file (or provide me
with a working example):
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="simple"
nsURI="http:///model2.ecore" nsPrefix="simple.model">
<eClassifiers xsi:type="ecore:EClass" name="Writer">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"
iD="true">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Id @GeneratedValue"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EReference" name="books"
upperBound="-1"
eType="#//Book" containment="true" eOpposite="#//Book/writer">
<details key="appinfo" value="@OneToMany
(mappedBy="writer", indexed=false)"/>
</eAnnotations>
<eAnnotations source="http:///org/eclipse/emf/ecore/util/
ExtendedMetaData">
<details key="kind" value="element"/>
<details key="name" value="books"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Book">
iD="true">
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="writer"
eType="#//Writer"
resolveProxies="false" eOpposite="#//Writer/books">
<details key="appinfo" value="@ManyToOne"/>
</eAnnotations>
ExtendedMetaData">
<details key="name" value="writer"/>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Versions used:
eclipselink-plugins-1.1.1.v20090415-r3948
emf-xsd-SDK-I200904141800
emf-teneo-eclipselink-SDK-M200904031023
OK, versions are highly experimental, but I think my error is rather
"fundamental" ;-)
TIA
Robert
Re: EMF - Teneo-EclipseLink - @OneToMany [message #431262 is a reply to message #429273] |
Mon, 06 July 2009 20:58 |
Antonel Ernest Pazargic Messages: 69 Registered: July 2009 |
Member |
I have the same issue with OneToMany relations (even if the exception
message looks a little bit changed) and the EMF-Teneo-JPA application stop
working. A error message dialog popped up in Eclipse IDE and the following
exception are thrown:
!ENTRY org.eclipse.osgi 4 0 2009-07-06 23:53:20.620
!MESSAGE An error occurred while automatically activating bundle
ro.crito.medyna.ui (9).
!STACK 0
org.osgi.framework.BundleException: Exception in
ro.crito.medyna.model.ui.Activator.start() of bundle ro.crito.medyna.ui.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:189)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: org.eclipse.emf.common.util.WrappedException:
javax.persistence.PersistenceException: Exception [EclipseLink-0] (Eclipse
Persistence Services - 1.1.2.v20090612-r4475):
org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Exception [EclipseLink-1] (Eclipse Persistence Services -
org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The attribute [books] is not declared as type
ValueHolderInterface, but its mapping uses indirection.
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[books]
Descriptor:
RelationalDescriptor(ro.crito.medyna.model.library.impl.Libr aryImpl -->
[DatabaseTable(LIBRARY)])
Exception Description: The attribute [writers] is not declared as type
Mapping: org.eclipse.persistence.mappings.OneToManyMapping[writers]
Descriptor:
Mapping: org.eclipse.persistence.mappings.ManyToManyMapping[books]
Descriptor:
RelationalDescriptor(ro.crito.medyna.model.library.impl.Writ erImpl -->
[DatabaseTable(WRITER)])
Runtime Exceptions:
at
org.eclipse.emf.teneo.eclipselink.resource.EclipseLinkResour ceImpl.openDatabase(EclipseLinkResourceImpl.java:588)
at
org.eclipse.emf.teneo.eclipselink.resource.EclipseLinkResour ceImpl$DatabaseContentsEList.loaded(EclipseLinkResourceImpl. java:248)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.didAdd(ResourceImpl.java:443)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:425)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:315)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList. java:307)
at ro.crito.medyna.model.ui.Activator.start(Activator.java:60)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
... 33 more
Caused by: javax.persistence.PersistenceException: Exception
[EclipseLink-0] (Eclipse Persistence Services - 1.1.2.v20090612-r4475):
Note: The only OneToMany info are in generated orm.xml. There are no
EAnnotation in library.ecore. That could be the source of the problem?
What can I do against that issue?
Thanks in advance, jtonic.
On Thu, 16 Apr 2009 15:23:00 +0300, Robert Jaemmrich
<mail@robert-jaemmrich.de> wrote:
> - .genmodel
> - orm.xml and
> - Model/Edit Code
> an
> type
> Persistence)
> me
> XMLSchema-instance"
> iD="true">
> </eAnnotations>
> upperBound="-1"
> </eAnnotations>
> ExtendedMetaData">
> </eAnnotations>
> </eClassifiers>
> iD="true">
> </eAnnotations>
> eType="#//Writer"
> </eAnnotations>
> ExtendedMetaData">
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> Versions used:
> "fundamental" ;-)
> TIA
> Robert
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: EMF - Teneo-EclipseLink - @OneToMany [message #431263 is a reply to message #431262] |
Mon, 06 July 2009 21:10 |
Hi Antonel,
Can you post the ecore and the orm you get? Persistence should work out-of-the-box (except for setting id and version
eattributes that is), so for one-to-manies you should not get these problems.
It is getting towards mid-night here so it will probably be tomorrow before I or other Teneo-EclipseLink committers can
take a look at it...
gr. Martin
> stop working. A error message dialog popped up in Eclipse IDE and the
> following exception are thrown:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Descriptor:
> Descriptor:
> Descriptor:
> Runtime Exceptions:
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 33 more
>> Hi,
>> - .genmodel
>> - orm.xml and
>> - Model/Edit Code
>> and an
>> type
>> Persistence)
>> provide me
>> <?xml version="1.0" encoding="UTF-8"?>
>> XMLSchema-instance"
>> iD="true">
>> </eAnnotations>
>> upperBound="-1"
>> </eAnnotations>
>> ExtendedMetaData">
>> </eAnnotations>
>> </eClassifiers>
>> iD="true">
>> </eAnnotations>
>> eType="#//Writer"
>> </eAnnotations>
>> ExtendedMetaData">
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> Versions used:
>> "fundamental" ;-)
>> TIA
>> Robert
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EMF - Teneo-EclipseLink - @OneToMany [message #431266 is a reply to message #431263] |
Mon, 06 July 2009 21:46 |
Member |
On Tue, 07 Jul 2009 00:10:48 +0300, Martin Taal <mtaal@elver.org> wrote:
> Hi Antonel,
> out-of-the-box (except for setting id and version eattributes that is),
> before I or other Teneo-EclipseLink committers can take a look at it...
library.ecore
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="library"
nsURI="http://jtonic.ro/library" nsPrefix="lib">
ordered="false" lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//ELong" iD="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pages"
http://www.eclipse.org/emf/2003/XMLType#//Int"
unsettable="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="category"
lowerBound="1"
eType="#//BookCategory" unsettable="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="author"
lowerBound="1"
eType="#//Writer" eOpposite="#//Writer/books"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BookCategory">
<eLiterals name="Mystery"/>
<eLiterals name="ScienceFiction" value="1"/>
<eLiterals name="Biography" value="2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Library">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
<eStructuralFeatures xsi:type="ecore:EReference" name="writers"
upperBound="-1"
eType="#//Writer" containment="true" resolveProxies="false"/>
upperBound="-1"
eType="#//Book" containment="true" resolveProxies="false"/>
</eClassifiers>
upperBound="-1"
eType="#//Book" eOpposite="#//Book/author"/>
</eClassifiers>
</ecore:EPackage>
orm.xml
<orm:entity-mappings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:orm="http://java.sun.com/xml/ns/persistence/orm"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm
http://java.sun.com/xml/ns/persistence/orm_1_0.xsd" version="1.0">
<orm:persistence-unit-metadata>
<orm:xml-mapping-metadata-complete/>
<orm:persistence-unit-defaults>
<orm:access>FIELD</orm:access>
</orm:persistence-unit-defaults>
</orm:persistence-unit-metadata>
<orm:entity class="ro.crito.medyna.model.library.impl.BookImpl"
name="Book">
<orm:table name="BOOK"/>
<orm:inheritance strategy="JOINED"/>
<orm:attributes>
<orm:id name="id">
<orm:generated-value/>
</orm:id>
<orm:basic fetch="EAGER" name="title" optional="false"/>
<orm:basic fetch="EAGER" name="pages" optional="false"/>
<orm:basic fetch="EAGER" name="category" optional="false">
<orm:enumerated>STRING</orm:enumerated>
</orm:basic>
<orm:basic name="eContainerFeatureID">
<orm:column name="ECONT_FEAT_ID"/>
</orm:basic>
<orm:many-to-one fetch="EAGER" name="author" optional="true"
target-entity="ro.crito.medyna.model.library.impl.WriterImpl ">
<orm:cascade>
<orm:cascade-persist/>
<orm:cascade-merge/>
<orm:cascade-refresh/>
</orm:cascade>
</orm:many-to-one>
<orm:many-to-one name="eContainer"
target-entity="ro.crito.medyna.model.library.impl.LibraryImpl ">
<orm:join-column name="LIBRARY_BOOKS_E_ID"/>
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:many-to-one>
</orm:attributes>
</orm:entity>
<orm:entity class="ro.crito.medyna.model.library.impl.LibraryImpl"
name="Library">
<orm:table name="LIBRARY"/>
<orm:attributes>
<orm:id name="id">
</orm:id>
<orm:basic fetch="EAGER" name="name" optional="false"/>
</orm:basic>
<orm:one-to-many fetch="LAZY" mapped-by="eContainer" name="writers"
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:one-to-many>
<orm:one-to-many fetch="LAZY" mapped-by="eContainer" name="books"
target-entity="ro.crito.medyna.model.library.impl.BookImpl" >
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:one-to-many>
</orm:attributes>
</orm:entity>
<orm:entity class="ro.crito.medyna.model.library.impl.WriterImpl"
name="Writer">
<orm:table name="WRITER"/>
<orm:attributes>
<orm:id name="id">
</orm:id>
</orm:basic>
<orm:join-column name="LIBRARY_WRITERS_E_ID"/>
<orm:cascade>
<orm:cascade-all/>
</orm:cascade>
</orm:many-to-one>
<orm:one-to-many fetch="LAZY" name="books"
<orm:join-table name="WRITER_BOOKS">
<orm:join-column insertable="true" name="WRITER_E_ID"
nullable="false" unique="false" updatable="true"/>
<orm:inverse-join-column insertable="true" name="BOOK_E_ID"
</orm:join-table>
<orm:cascade>
</orm:cascade>
</orm:one-to-many>
</orm:attributes>
</orm:entity>
</orm:entity-mappings>
Thanks for your quick answer, jtonic
off-topic: RIP MJ :((((
> gr. Martin
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Descriptor:
>> Descriptor:
>> Descriptor:
>> Runtime Exceptions:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
>>> Hi,
>>> - .genmodel
>>> - orm.xml and
>>> - Model/Edit Code
>>> relationship
>>> and an
>>> type
>>> Persistence)
>>> provide me
>>> XMLSchema-instance"
>>> iD="true">
>>> </eAnnotations>
>>> upperBound="-1"
>>> </eAnnotations>
>>> ExtendedMetaData">
>>> </eAnnotations>
>>> </eClassifiers>
>>> iD="true">
>>> </eAnnotations>
>>> eType="#//Writer"
>>> </eAnnotations>
>>> ExtendedMetaData">
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> Versions used:
>>> "fundamental" ;-)
>>> TIA
>>> Robert
Current Time: Thu Apr 25 23:33:34 GMT 2024
Powered by FUDForum. Page generated in 0.03114 seconds
