Home » Eclipse Projects » XML Schema Definition (XSD) » Schema diagnostics
Schema diagnostics [message #42914] Fri, 30 April 2004 10:15 Go to next message
Originally posted by: invalid.soft-gems.net
Hi group,
I'm trying currently to get diagnostics information as described in the
FAQs but somehow I've got the feeling they do not work as expected. What I
have is an xsd file, which includes 3 other schemas. I made one of the
references invalid (non-existing file) and expected to find an entry
telling me about a missing reference but the diagnostic information from
my main schema is empty.
Additionally, XML Spy reports an error in one of my included schemas,
which I would expect to be reported too, but which also not appears.
Btw., may I ask an slightly off-topic question? Why does XML Spy consider
the following text invalid?
<xs:schema targetNamespace="http://msgax1i.msg.de/afis/odie"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="http://msgax1i.msg.de/afis"
xmlns:io="http://msgax1i.msg.de/afis/io"
xmlns:layout="http://msgax1i.msg.de/afis/layout"
xmlns:local="http://msgax1i.msg.de/afis/localization"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
<xs:documentation xml:lang="de">
Copyright 2004 msg systems ag. All rights reserved.
</xs:documentation>
</xs:annotation>
<xs:element name="td" type="tdType"/>
<xs:complexType name="tdType">
<xs:attribute name="colspan" type="xs:positiveInteger" default="1"/>
</xs:complexType>
<xs:element name="table" type="tableType" substitutionGroup="td"/>
<xs:complexType name="tableType">
<xs:complexContent>
=====> Error message here: undefined value for 'base' encountered.
=====> tdType is defined just a couple lines above.
<xs:extension base="tdType">
<xs:sequence>
<xs:element ref="tr" maxOccurs="unbounded"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name="tr" type="trType"/>
<xs:complexType name="trType">
<xs:sequence>
<xs:element ref="td" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
For me it looks ok, however I'm a beginner with XML Schemas so I likely
overlooked an important part.
Mike
www.soft-gems.net
Re: Schema diagnostics [message #42945 is a reply to message #42914] Fri, 30 April 2004 11:58 Go to previous messageGo to next message
Mike,
Have a look at XSDMainTest and how it implements -validate to walk all the
resources to find all the schemas to report all the errors. The
XSDSchema.getAllDiagnostics method will only get the diagnostics that apply to
components directly contained by that schema; the included and imported schemas
are in separate resources and have their own lists of diagnostics.
You left "odie" out of your xmnls=".../odie"; I assume it should match your
target namespace.
Mike Lischke wrote:
> Hi group,
> <xs:annotation>
> </xs:documentation>
> </xs:annotation>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Mike
> www.soft-gems.net
Re: Schema diagnostics [message #42976 is a reply to message #42945] Fri, 30 April 2004 12:49 Go to previous messageGo to next message
Ed Merks wrote:
> Mike,
to
schemas
> target namespace.
I should tell you how much I appreciate your help, Ed. Thank you very
much. It appears you are almost the only one replying to the questions in
this group. Excellent work!
Mike
www.soft-gems.net
Re: Schema diagnostics [message #43059 is a reply to message #42976] Fri, 30 April 2004 13:39 Go to previous message
Mike,
You're welcome. I just don't give other people much of a chance, do I. ;-)
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> to
> schemas
> > target namespace.
> Mike
> www.soft-gems.net
Re: Schema diagnostics [message #586384 is a reply to message #42914] Fri, 30 April 2004 11:58 Go to previous message
Mike,
target namespace.
Mike Lischke wrote:
> Hi group,
> <xs:annotation>
> </xs:documentation>
> </xs:annotation>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Mike
> www.soft-gems.net
Ed Merks
Re: Schema diagnostics [message #586395 is a reply to message #42945] Fri, 30 April 2004 12:49 Go to previous message
Mike Lischke is currently offline Mike LischkeFriend
Member
Ed Merks wrote:
> Mike,
to
schemas
> target namespace.
Mike
www.soft-gems.net
Re: Schema diagnostics [message #586424 is a reply to message #42976] Fri, 30 April 2004 13:39 Go to previous message
Mike,
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> to
> schemas
> > target namespace.
> Mike
> www.soft-gems.net
Ed Merks
Previous Topic:Namespaces
Next Topic:Code completion
Current Time: Thu Dec 03 21:15:32 GMT 2020
Powered by FUDForum. Page generated in 0.01751 seconds
