Home » Modeling » EMF » [Teneo] Problem saving EPackage loaded from database
[Teneo] Problem saving EPackage loaded from database [message #426338] |
Fri, 26 December 2008 21:34 |
Originally posted by: mduduzi.keswa.isizwe.com
Happy Holidays Everyone!
I'm storing all generated Epackages in the database. Here's the the
scenario (in separate junit test cases) - what am I doing wrong?:
1. Store EcorePackage.eINSTANCE in the database:
1.1 session.save(EcorePackage.eINSTANCE);
RESULT: Successful
2. Create a new EPackage 'SchoolBook':
2.1 HbDataStore hds = DbUtil.createHBDS(new
EPackage[]{EcorePackage.eINSTANCE});
2.2 Query qry = session.createQuery("from EPackage where
name='ecore'");
2.3 List<EPackage> pkgs = qry.list();
2.4 EPackage ecorePkg = pkgs.get(0);
2.5 tx.begin();
2.6 session.save(schoolPackage);
2.7 tx.commit();
2.8 session.close();
RESULT: Successful (with an entry in 'ecore_eobject' table of the new
EPackage)
3. Add an EClass to the existing 'SchoolBook' package (epackage is
EcorePackage.eINSTANCE):
3.1 HbDataStore hds = DbUtil.createHBDS(new
3.2 SessionFactory sessionFactory = hds.getSessionFactory();
3.3 tx.begin();
3.4 Query qry = session.createQuery("from EPackage where name='ecore'");
3.5 List<EPackage> pkgs = qry.list();
3.6 EPackage ecorePkg = pkgs.get(0);
3.7 Registry.INSTANCE.put(ecorePkg.getNsURI(), ecorePkg);
3.8 qry = session.createQuery("from EPackage where
name='SchoolPackage'");
3.9 pkgs = qry.list();
3.10 EPackage schPkg = pkgs.get(0);
3.11 Registry.INSTANCE.put(schPkg.getNsURI(), schPkg);
3.12 hds.setEPackages(new EPackage[]{ecorePkg,schPkg});
3.11 hds.initialize();
3.12 EClass schoolBookEClass = efactory.createEClass();
3.13 schoolBookEClass.setName("SchoolBook");
// create a new attribute for this EClass
3.14 EAttribute level = efactory.createEAttribute();
3.15 level.setName("level");
3.16 level.setEType(epackage.getEInt());
3.17 schoolBookEClass.getEStructuralFeatures().add(level);
3.18 session.save(level);
3.19 session.save(schoolBookEClass);
3.20 schPkg.getEClassifiers().add(schoolBookEClass);
3.21 session.save(schPkg);
3.22 tx.commit();
3.23 session.close();
RESULT:
ERROR: org.hibernate.TransientObjectException: object references an
unsaved transient instance - save the transient instance before
flushing: EClassifier
TRACE:
INFO: indexes: [primary, fk5cd8f2424d8f171]
Dec 26, 2008 4:29:07 PM org.hibernate.tool.hbm2ddl.DatabaseMetadata
getTableMetadata
INFO: table not found: eobject
Dec 26, 2008 4:29:07 PM org.hibernate.tool.hbm2ddl.SchemaUpdate execute
SEVERE: Unsuccessful: alter table `eobject` add index
emodelelement_eannotations (`eannotation_emodelelement_e_id`), add
constraint emodelelement_eannotations foreign key
(`eannotation_emodelelement_e_id`) references `eobject` (e_id)
SEVERE: Can't create table '.\solutionassembly\#sql-2ec_4d.frm' (errno: 121)
============ MANY MORE 'SEVERE' ERRORS IN BETWEEN =====================
Dec 26, 2008 4:29:08 PM org.hibernate.tool.hbm2ddl.SchemaUpdate execute
INFO: schema update complete
Re: [Teneo] Problem saving EPackage loaded from database [message #426339 is a reply to message #426338] |
Sat, 27 December 2008 00:56 |
Hi Mdu,
I see that you reinitialize the datastore in step 3.11 but do not get a new session. Does the
exception occur if you remove these two lines:
Then next I would put a breakpoint at the location where hibernate throws the exception and then
check which instance it fails on.
gr. Martin
> RESULT: Successful
> name='ecore'");
> 2.5 tx.begin();
> 2.7 tx.commit();
> EPackage)
> 3.3 tx.begin();
> 3.22 tx.commit();
> RESULT:
> TRACE:
> getTableMetadata
> 121)
> 121)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problem saving EPackage loaded from database [message #426340 is a reply to message #426339] |
Sat, 27 December 2008 01:38 |
Hi Martin - thanks again for your time. See my imbedded comments below:
Martin Taal wrote:
> Hi Mdu,
> new session. Does the exception occur if you remove these two lines:
I did remove these two lines - but I still get the same error.
> throws the exception and then check which instance it fails on.
By instance, what are you refering to? epackage or something else? And
to able to do this, do I needd access to Hibernate source code?
> gr. Martin
>> RESULT: Successful
>> name='ecore'");
>> 2.4 EPackage ecorePkg = pkgs.get(0); 2.5 tx.begin();
>> 2.6 session.save(schoolPackage); 2.7 tx.commit();
>> EPackage)
>> 3.3 tx.begin(); 3.4 Query qry = session.createQuery("from
>> 3.6 EPackage ecorePkg = pkgs.get(0); 3.7
>> 3.13 schoolBookEClass.setName("SchoolBook"); // create a
>> 3.17
>> 3.18 session.save(level); 3.19
>> session.save(schoolBookEClass); 3.20
>> 3.22 tx.commit();
>> RESULT:
>> TRACE:
>> getTableMetadata
>> (errno: 121)
>> (errno: 121)
Re: [Teneo] Problem saving EPackage loaded from database - more info [message #426341 is a reply to message #426339] |
Sat, 27 December 2008 02:22 |
Hi Martin,
I put a breakpoint in hibernate and the exception is coming from
ForeignKey.class in code:
* Return the identifier of the persistent or transient object, or throw
* an exception if the instance is "unsaved"
* Used by OneToOneType and ManyToOneType to determine what id value
should
* be used for an object that may or may not be associated with the
session.
* This does a "best guess" using any/all info available to use (not
just the
* EntityEntry).
public static Serializable getEntityIdentifierIfNotUnsaved(
final String entityName,
final Object object,
final SessionImplementor session)
throws HibernateException {
if ( object == null ) {
return null;
else {
Serializable id = session.getContextEntityIdentifier( object );
if ( id == null ) {
// context-entity-identifier returns null explicitly if the entity
// is not associated with the persistence context; so make some
// deeper checks...
if ( isTransient(entityName, object, Boolean.FALSE, session) ) {
throw new TransientObjectException(
"object references an unsaved transient instance - save the
transient instance before flushing: " +
(entityName == null ? session.guessEntityName( object ) : entityName)
id = session.getEntityPersister( entityName, object ).getIdentifier(
object, session.getEntityMode() );
return id;
The only thing I can make sense of is that in the above method call
entityName is 'EClassifier' and object is an 'EDataTypeImpl' whose inner
type is 'EInt' - the type of the attribute 'level' in the example. I'm
lost as to why this fails since I have loaded and registered 'ecore'
epackage in steps 3.x.
Am I making the right calls at the right sequence in step 3?
Thanks and regards,
-Mdu
Martin Taal wrote:
> Hi Mdu,
> gr. Martin
>> RESULT: Successful
>> name='ecore'");
>> EPackage)
>> 3.17
>> 3.22 tx.commit();
>> RESULT:
>> TRACE:
>> getTableMetadata
>> (errno: 121)
>> (errno: 121)
Re: [Teneo] Problem saving EPackage loaded from database - more info [message #426348 is a reply to message #426341] |
Mon, 29 December 2008 06:44 |
Hi Mdu,
Should have seen this right away:
This exception is thrown because you did not pass the xmltypepackage (
org.eclipse.emf.ecore.xml.type.XMLTypePackage) to the datastore (in addition to the ecorepackage).
gr. Martin
Mdu wrote:
> Hi Martin,
> throw
> should
> session.
> just the
> * EntityEntry).
> return null;
> else {
> if ( id == null ) {
> the entity
> make some
> // deeper checks...
> session) ) {
> instance - save the transient instance before flushing: " +
> ).getIdentifier( object, session.getEntityMode() );
> return id;
> Thanks and regards,
> -Mdu
> Martin Taal wrote:
>> Hi Mdu,
>> a new session. Does the exception occur if you remove these two lines:
>> gr. Martin
>>> RESULT: Successful
>>> name='ecore'");
>>> EPackage)
>>> 3.17
>>> 3.22 tx.commit();
>>> RESULT:
>>> an unsaved transient instance - save the transient instance before
>>> TRACE:
>>> getTableMetadata
>>> (errno: 121)
>>> (errno: 121)
The Netherlands
Current Time: Wed Apr 17 23:30:55 GMT 2024
Powered by FUDForum. Page generated in 0.23138 seconds
