Home » Modeling » EMF » [Teneo] @ManyToMany JPA Annotation give double association table
Re: [Teneo] @ManyToMany JPA Annotation give double association table [message #426184 is a reply to message #426183] |
Thu, 18 December 2008 13:07 |
Hi Thomas,
Normally Teneo should detect the mtm and create one jointable if both sides are non-indexed. What
are the tablenames?
There are no other annotations on the two ereferences?
You can set a @JoinTable(name="myJoinTable") on both sides with the same join table name. Then both
sides should use the same jointable.
gr. Martin
Thomas wrote:
> Response in your message
> Martin Taal a écrit :
>> Hi Thomas,
>> Indexed mtm relations with one join table are not supported by hibernate:
>> http://www.elver.org/hibernate/hibernate_relations.html#Mapp ing+indexed+many-to-many+(nm)+relations
>> a solution is to make both sides non-indexed by setting indexed=false
>> on the association. But then you can't predict the order in which the
>> elements are returned.
> Oh yes, I have forgotten this specific teneo property.
> But ever with that property, I have 2 tables, without indexes now. Is
> the action of changing the name of a table (as resource is a key word
> for oracle we use OResource instead) can make this behavior?
>> I am not sure why the repeated column exception occurs... Did you set
>> the @JoinTable annotation on both sides?
> No, it was on one side.
>> gr. Martin
>> Thomas wrote:
>>> Hello (Martin ? ;),
>>> A strange stuff with teneo and ManyToMany bidirectionnal relations
>>> I have a bidirectionnal ManyToMany between Resource (table ORESOURCE)
>>> and ResourceCategory
>>> I put on the ManyToMany of Resource a mappedBy as I want the
>>> ResourceCategory would be the master.
>>> On the generated database, I have 2 tables of relation
>>> one call ORSRC_RESRCECTEGRY with a composite id on the id of
>>> ORESOURCE and an index
>>> one other call RSRCECTEGRY_RESRCE with a composite id on the id of
>>> ResourceCategory and an index
>>> It works with those both association, but why is there not only one
>>> relation table with a composite id on id of OResource and the id of
>>> Resource Category ???
>>> And if I try to force the JoinTable to be on both ID with this
>>> annotation
>>> @JoinTable(
>>> joinColumns=@JoinColumn(referencedColumnName=ID)
>>> inverseJoinColumns=@JoinColumn(referencedColumnName=ID)
>>> I have this error:
>>> Repeated column in mapping for collection: ResourceCategory.resources
>>> column: NULL
>>> Thanks for the light you can give to me
>>> Thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] @ManyToMany JPA Annotation give double association table [message #426190 is a reply to message #426184] |
Thu, 18 December 2008 16:20 |
Thomas Messages: 37 Registered: July 2009 |
Member |
Ok, I have add a @JoinTable(name="RSRCECTEGRY_RESRCE") on both side
the result is a table RSRCECTEGRY_RESRCE with 4 columns columns, 2 with
Resource id and 2 with ResourceCategory id
I know that we can also force column name, BUT
I have also a table called ORSRC_RESRCECTEGRY. Can it be teneo that add
this relation in my back ???
> Hi Thomas,
> sides are non-indexed. What are the tablenames?
> join table name. Then both sides should use the same jointable.
> gr. Martin
>>> Hi Thomas,
>>> hibernate:
>>> gr. Martin
>>> Thomas wrote:
>>>> Hello (Martin ? ;),
>>>> ORESOURCE) and ResourceCategory
>>>> annotation
>>>> @JoinTable(
>>>> I have this error:
>>>> ResourceCategory.resources column: NULL
>>>> Thomas
Re: [Teneo] @ManyToMany JPA Annotation give double association table [message #426191 is a reply to message #426190] |
Thu, 18 December 2008 16:35 |
Member |
Here is the getMappingXML():
<class entity-name="Oresource" abstract="false" lazy="false"
discriminator-value="Oresource" table="`ORESOURCE`">
<bag name="resourceCategories" lazy="true" cascade="refresh"
inverse="true" table="`ORSRC_RESRCECTEGRY`">
<key/>
<many-to-many entity-name="ResourceCategory" unique="false"
foreign-key="ORSRC_RSRCCTEGRIES"/>
</bag>
<class entity-name="ResourceCategory" abstract="false" lazy="false"
discriminator-value="ResourceCategory" table="`RESOURCECATEGORY`">
<bag name="resources" lazy="false" cascade="all"
table="`RSRCECTEGRY_RESRCE`">
<key/>
<many-to-many entity-name="Oresource" unique="false"
foreign-key="RSRCCTEGRY_RESRCES"/>
</bag>
>> Hi Thomas,
>> same join table name. Then both sides should use the same jointable.
>> gr. Martin
>>>> Hi Thomas,
>>>> hibernate:
>>>> indexed=false on the association. But then you can't predict the
>>>> order in which the elements are returned.
>>>> set the @JoinTable annotation on both sides?
>>>> gr. Martin
>>>> Thomas wrote:
>>>>> Hello (Martin ? ;),
>>>>> annotation
>>>>> @JoinTable(
>>>>> I have this error:
>>>>> Thomas
Re: [Teneo] @ManyToMany JPA Annotation give double association table [message #426192 is a reply to message #426191] |
Thu, 18 December 2008 16:42 |
Hi Thomas,
Seems indeed strange, the mapping shows two join tables although you added a @JoinTable annotation
(with the same name) on both sides and this single join table gets 4 columns.
Can you zip a testproject and email it to me?
gr. Martin
> <key/>
> </bag>
> <key/>
> </bag>
>> with Resource id and 2 with ResourceCategory id
>> add this relation in my back ???
>>> Hi Thomas,
>>> gr. Martin
>>>>> Hi Thomas,
>>>>> hibernate:
>>>> Is the action of changing the name of a table (as resource is a key
>>>> word for oracle we use OResource instead) can make this behavior?
>>>>> gr. Martin
>>>>> Thomas wrote:
>>>>>> Hello (Martin ? ;),
>>>>>> one relation table with a composite id on id of OResource and the
>>>>>> id of Resource Category ???
>>>>>> annotation
>>>>>> @JoinTable(
>>>>>> I have this error:
>>>>>> Thomas
The Netherlands
Current Time: Tue Apr 23 14:13:46 GMT 2024
Powered by FUDForum. Page generated in 0.03678 seconds
