Re: .ecore file export as xmi file [message #426157 is a reply to message #426131] |
Wed, 17 December 2008 13:47 |
Originally posted by: cdamus.zeligsoft.com
Hi, gitanjali,
If you need to export your Ecore file to OMG standard EMOF, then in the
Ecore Editor you just do "Save As..." and change the file extension to
".emof"
Otherwise, the Ecore file is already in XMI format.
Christian
gitanjali punj wrote:
> Can you please tell me how to export a .ecore file to xmi and also to
> import an xml file as .ecore .
> I dont want the api part but how is it done through the
> emf ui perspective like wht options to click on ui etc.
> Because in the import case only 3 options are available
> xsd,rose and ecore.
> Then how to import a xml file?
FUDForum. Page generated in 0.03035 seconds
