Re: using UUID for/in HREF [message #426056 is a reply to message #426055] |
Mon, 15 December 2008 13:14 |
Ed Merks Messages: 33137 Registered: July 2009 |
Soeren,
Comments below.
Soeren Kemmann wrote:
> Hello everyone,
> I have a semantic model which is split into several resources.
> The problem is that the uri references are problematic with lazy loading
> resources and keeping the references consistent.
> I have now changed the (de-)serialization to use UUIDs (by using the
> GMFResourceFactory).
> Now I have a unique identifier for each Object in a resource, but the
> references are still stored with "path_to_resource#//Containment.n". Is it
> possible to use the resource path and the uuid instead?
That's normally what ought to happen.
> I.e., I would like to have something like "path_to_resource#UUID" for
> resolving the object reference?
If you load the referencing resource, ensure that all proxies are
resolved, e.g., EcoreUtil.resolveAll or invoking Validate... in the
editor, and then save, it should use the new style references. Note
that you could also defines eKeys for your containment references so
that you'd get references of the form @feature[key='value']. UUIDs are
not cheap. They have an overhead of roughly 175 bytes per object...
> Thanks in advance!
> Soeren
Ed Merks
FUDForum. Page generated in 0.01866 seconds
