Home » Modeling » EMF » EObject <-> Nested Property Map/Bean
EObject <-> Nested Property Map/Bean [message #425945] Fri, 12 December 2008 21:54 Go to next message
Originally posted by: mduduzi.keswa.isizwe.com
With all the tooling around EMF, I thought this capability is available
somehow. Let me explain:
1. I'm trying to send to clients Data Transfer Objects (DTOs) that have
been converted from instances of EObjects.
2. I imagine the conversion will be such that all nested attributes will
be converted to name-value pairs of the form
('attribname1.attribname2.attribname3','value') pair and references
will be converted to ('attribname1.attribname2.attribname3','RefID').
Is there a feature/tool/util that allows reflection (setting and
getting) using 'a.b.c.d' form of nested attributes within an EObject?
Thanks for your help.
-Mdu
Re: EObject <-> Nested Property Map/Bean [message #425948 is a reply to message #425945] Fri, 12 December 2008 22:08 Go to previous messageGo to next message
Mdu,
Comments below.
> available somehow. Let me explain:
> have been converted from instances of EObjects.
> will be converted to name-value pairs of the form
I don't really follow.
You can use eObject.eGet(eObject.eClass().getEStructuralFeature(<name>))
to look up a named feature...
> -Mdu
Re: EObject <-> Nested Property Map/Bean [message #425949 is a reply to message #425948] Fri, 12 December 2008 22:26 Go to previous messageGo to next message
Thanks Ed - see my comments below:
Ed Merks wrote:
> Mdu,
> Comments below.
I'm using databinding feature of a GUI library that generally works with
beans. The GUI/form fields are bound using a.b.c.d conversion to
refer to a nested bean property whose literal value is 3 levels deep -
in this example. In java code I would normally call getA().getB().getC().
Now I want to use reflective features of an EObject to do the same. From
below it sounds like you're suggesting doing something like:
EObject p = eObject.eGet(eObject.eClass().getEStructuralFeature("a"));
p = p.eGet(eObject.eClass().getEStructuralFeature("b"));
p = p.eGet(eObject.eClass().getEStructuralFeature("c"));
I could then take any EObject and convert to a java Map object of the
form [('a.b.c','some literal value'), ...] and back to the original EOBject?
I'm oversimplifying my example for clarity.
>> -Mdu
Re: EObject <-> Nested Property Map/Bean [message #425950 is a reply to message #425949] Fri, 12 December 2008 22:44 Go to previous message
Mdu,
Comments below.
> Ed Merks wrote:
>> Mdu,
>> Comments below.
> with beans. The GUI/form fields are bound using a.b.c.d conversion
> to refer to a nested bean property whose literal value is 3 levels
> deep - in this example. In java code I would normally call
The data binding guys are doing some new work on properties-based data
binding that sounds related...
> From below it sounds like you're suggesting doing something like:
You'd want to use p's eClass().
> EOBject?
I guess so. I don't really understand that part... It does sound like
what you want is closely related to some new APIs the guys are working on.
>> You can use
>> eObject.eGet(eObject.eClass().getEStructuralFeature(<name>)) to look
>>> -Mdu
Previous Topic:Synchronizing the form editor with an XML source editor
Next Topic:[CDO] Update from 1.0.0 to 1.0.x
Current Time: Tue Mar 31 10:55:21 GMT 2020
Powered by FUDForum. Page generated in 0.03210 seconds
