Editable emf objects properties [message #425837] |
Tue, 09 December 2008 18:24 |
Originally posted by: swt.magellium.fr
Hello all,
I'd like the properties view to be non-editable for my emf objects.
I don't know which way of doing this is the simplest, but I can think of
an easy solution : Make EMF generate the edit code so that all
"propertyDescriptors" are created with the "settable" property set to
"false" (instead of true...)
Is there a genmodel property which does this ? (I can't find one)
Or maybe there's a simpler way ?? Maybe overriding the Properties View
Part so that it becomes non-editable ?
The usage of dynamic templates seems too complex to do such a small job...
Thanks in advance !
Stephane
Re: Editable emf objects properties [message #425852 is a reply to message #425837] |
Wed, 10 December 2008 08:02 |
Stephane,
In the Genmodel properties view each model feature has a "Property Type"
property at the bottom of the list. You can set it to "Read-Only".
Cheers
/Eike
SWT schrieb:
> Hello all,
> of an easy solution : Make EMF generate the edit code so that all
> job...
> Thanks in advance !
> Stephane
Cheers
/Eike
http://www.esc-net.de
Re: Editable emf objects properties [message #425872 is a reply to message #425852] |
Wed, 10 December 2008 16:39 |
Eike,
I know that but then the feature will be read-only !
I just want it to be read-only *in the properties view*, that is to say
at the "edit" level, in the ItemProviderAdapter...
Stephane
Eike Stepper wrote :
> Stephane,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> SWT schrieb:
>> Hello all,
>> job...
>> Thanks in advance !
>> Stephane
Re: Editable emf objects properties [message #425875 is a reply to message #425872] |
Wed, 10 December 2008 17:38 |
I'm sorry... You're true.
The "Property Type" is for the ItemProvider. And it has nothing to do
with the "changeable" or "unsettable" properties of the feature...
I don't know why but I was searching in the class properties, so that
all features of the class become either editable or read-only. But it's
logic for that property to exist for each feature !
My mistake...
Shameful Stephane
SWT wrote :
> Eike,
> Regards,
> Stephane
>> Stephane,
>> Type" property at the bottom of the list. You can set it to "Read-Only".
>> Cheers
>> /Eike
>> SWT schrieb:
>>> Hello all,
>>> View Part so that it becomes non-editable ?
>>> job...
>>> Thanks in advance !
>>> Stephane
FUDForum. Page generated in 0.02083 seconds
