Home » Modeling » EMF » [Teneo] hibernate collection lazy loading behavior ?
[Teneo] hibernate collection lazy loading behavior ? [message #425641] |
Wed, 03 December 2008 15:51 |
Stephane fournier Messages: 340 Registered: July 2009 |
To continue from the previous post (see
http://www.eclipse.org/newsportal/article.php?id=37502&g roup=eclipse.tools.emf#37502),
I failed to load collections lazily. :(
I tried with the very simple Library model with 3 classes : Library, Book,
Writer to avoid FeatureMap collections, Library that contains other ones
and so on...
I create a root library with a book and its writer.
Here the cfg parameters, I use to initialize the HbDataStore (sorry for
the code format due to copy/paste in the newsportal) :
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "lacarotte");
props.setProperty(Environment.URL,
"jdbc:mysql://localhost:3306/testOldLibrary");
props.setProperty(Environment.PASS, "lcelb");
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
props.setProperty(Environment.HBM2DDL_AUTO, "update");
props.setProperty(Environment.SHOW_SQL, Boolean.TRUE.toString());
props.setProperty(Environment.FORMAT_SQL, Boolean.TRUE.toString());
props.setProperty(Environment.DEFAULT_BATCH_FETCH_SIZE, "10");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
props.setProperty(PersistenceOptions.DEFAULT_CACHE_STRATEGY, "NONE");
props.setProperty(PersistenceOptions.SET_PROXY,
// Initialize create the HbDataStore
HbDataStore hbds =
HbHelper.INSTANCE.createRegisterDataStore("library");
hbds.setEPackages(new EPackage[] { LibraryPackage.eINSTANCE });
hbds.setProperties(props);
hbds.initialize();
The resource is loaded with topClassesBehavior that runs a query ("from
library").
I debugged the query execution that returns the root library with its
children.
At that point, lazy loading failed.
The code that loads the children is located in
TwoPhaseLoad#initializeEntity(..) (called by
QueryLoader#initializeEntitiesAndCollections):
Object[] hydratedState = entityEntry.getLoadedState();
if ( log.isDebugEnabled() )
log.debug("resolving associations for " +
MessageHelper.infoString(persister, id, session.getFactory()));
Type[] types = persister.getPropertyTypes();
for ( int i = 0; i < hydratedState.length; i++ ) {
final Object value = hydratedState[i];
if ( value!=LazyPropertyInitializer.UNFETCHED_PROPERTY &&
value!=BackrefPropertyAccessor.UNKNOWN ) {
hydratedState[i] = types[i].resolve( value, session, entity );
The hydratedState array corresponds to my root library. This one contains
2 MarkerObject instances set to NOT_NULL_COLLECTION regarding the 'books'
and the 'writers' collections.
The call to types[i].resolve( value, session, entity ) when types[i] is
such a MarkerObject resolves it as a PersistentList with its data.
I would expect a new MarkerObject set to UNFECTCHED_COLLECTION or a not
loaded PersistentList (i.e a lazy one).
Here is a copy, of the generated hibernate mapping where data are
collections are well tagged as lazy ones.
Help would be appreciated.
Stephane.
Mapping content :
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="org.eclipse.example.library.impl.BookImpl"
entity-name="Book" abstract="false" lazy="true" table="`book`"
proxy="org.eclipse.example.library.Book">
<meta attribute="eclassName">Book</meta>
<meta
attribute="epackage">http:///org/eclipse/example/library.ecore</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="title" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`title`"/>
</property>
<property name="pages" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`pages`"/>
</property>
<property name="category" lazy="false" not-null="false" insert="true"
update="true" unique="false">
<column not-null="false" unique="false" name="`category`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param
name="enumClass">org.eclipse.example.library.BookCategory</param >
</type>
</property>
<many-to-one name="author" entity-name="Writer" lazy="proxy"
foreign-key="book_author" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`book_author_e_id`"/>
</many-to-one>
</class>
<class name="org.eclipse.example.library.impl.LibraryImpl"
entity-name="Library" abstract="false" lazy="true" table="`library`"
proxy="org.eclipse.example.library.Library">
<meta attribute="eclassName">Library</meta>
<meta
</id>
</version>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<list name="writers" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="library_writers">
<column name="`library_writers_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`library_writers_idx`"/>
<one-to-many entity-name="Writer"/>
</list>
<list name="books" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="library_books">
<column name="`library_books_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`library_books_idx`"/>
<one-to-many entity-name="Book"/>
</list>
</class>
<class name="org.eclipse.example.library.impl.WriterImpl"
entity-name="Writer" abstract="false" lazy="true" table="`writer`"
proxy="org.eclipse.example.library.Writer">
<meta attribute="eclassName">Writer</meta>
<meta
</id>
</version>
</property>
<list name="books" table="`writer_books`" lazy="true">
<key update="true">
<column name="`writer_e_id`" not-null="true" unique="false"/>
</key>
<list-index column="`writer_books_idx`"/>
<many-to-many entity-name="Book" unique="true">
<column name="`book_e_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
</class>
</hibernate-mapping>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425658 is a reply to message #425641] |
Wed, 03 December 2008 22:47 |
Hi Stéphane,
I tested this and with me it worked fine.
This is for example the mapping for the library.books:
</key>
</list>
and when I get the library it is not loaded:
Library lib = (Library) res.getContents().get(0);
only when I do this (in the testcase), the books get loaded:
assertEquals(3, lib.getBooks().size());
Some info, an unloaded Hibernate persistentlist has a list member with value null, if it is loaded
there will be an arraylist in there.
With you the list member of the hibernate persistentlist is set?
gr. Martin
Stéphane Fournier wrote:
rary,
> Book, Writer to avoid FeatureMap collections, Library that contains
> other ones and so on...
> HbDataStore hbds =
> hbds.initialize();
> library").
> children.
> contains 2 MarkerObject instances set to NOT_NULL_COLLECTION regarding
> the 'books' and the 'writers' collections.
> Stephane.
> Mapping content :
> <meta
> </id>
> </version>
> </property>
> </property>
> insert="true" update="true" unique="false">
> <type
> <param
> </type>
> </property>
> </many-to-one>
> </class>
> <meta
> </id>
> </version>
> </property>
> unique="false"/>
> </key>
> </list>
> unique="false"/>
> </key>
> </list>
> </class>
> <meta
> </id>
> </version>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </many-to-many>
> </list>
> </class>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425681 is a reply to message #425658] |
Thu, 04 December 2008 15:32 |
Guillaume Brocard Messages: 25 Registered: July 2009 |
Hi Martin,
I'm working with Stéphane on this, and since he can't answer right now,
I'm taking up the torch.
I have conducted the very same test with the extended library model (the
one with feature map), and basically, the objects stored in the database
are looking like the following tree :
Library demo
Library NoName
Book book1
Writer writer2
Borrower borrower3
Library library4
Library library5
Book book6
Borrower borrower9999
Book book10000
So objects are being possessed through libraries, using either the
Library.stock, Library.people, or Library.branches containment
relationships.
We are using a HibernateResource, with initial query set to :
"SELECT library FROM Library library WHERE library.name='demo'"
As I debug the loading of my resource (
HibernateResource.loadUsingDefinedQueries(SessionWrapper sess); line 500) :
final List<?> qryResult = sess.executeQuery(element);
the resulting list does contain Library Demo.
Unfortunately, its branches list is initialized with Library NoName, which
in turn is initialized with book1, writer2, ..., library4, ... book10000
all resolved.
As Stéphane said, that has to do with the hydrated states of the objects
(see Stéphane's explanations).
What are we missing here ?
Thanks in advance,
Guillaume.
Martin Taal wrote:
> Hi Stéphane,
> </key>
> </list>
> gr. Martin
>> Hi,
> rary,
>> HbDataStore hbds =
>> hbds.initialize();
>> library").
>> children.
>> Stephane.
>> Mapping content :
>> <?xml version="1.0" encoding="UTF-8"?>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> <type
>> <param
>> </type>
>> </property>
>> </many-to-one>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> unique="false"/>
>> </key>
>> </list>
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </many-to-many>
>> </list>
>> </class>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425686 is a reply to message #425681] |
Thu, 04 December 2008 16:41 |
Hi Brocard,
Yes I can see what you mean but I would need to debug locally to see what goes on. Can you email me
a test Eclipse project with a database dump (mysql)? Hibernate libs are not needed. Then I can try
myself.
gr. Martin
Brocard Guillaume wrote:
> Hi Martin,
> Library demo
> Library NoName
> Book book1
> Writer writer2
> Borrower borrower3
> Library library4
> Library library5
> Book book6
> Book book10000
> relationships.
> which in turn is initialized with book1, writer2, ..., library4, ...
> book10000 all resolved.
> Thanks in advance,
> Guillaume.
> Martin Taal wrote:
>> Hi Stéphane,
>> unique="false"/>
>> </key>
>> </list>
>> value
>> gr. Martin
>>> Hi,
>>> Lib
>> rary,
>>> for the code format due to copy/paste in the newsportal) :
>>> "JOINED");
>>> "NONE");
>>> HbDataStore hbds =
>>> hbds.initialize();
>>> ("from library").
>>> children.
>>> regarding the 'books' and the 'writers' collections.
>>> is such a MarkerObject resolves it as a PersistentList with its data.
>>> not loaded PersistentList (i.e a lazy one).
>>> Stephane.
>>> Mapping content :
>>> DTD 3.0//EN"
>>> <meta
>>> </id>
>>> </version>
>>> update="true" not-null="false" unique="false" type="java.lang.String">
>>> </property>
>>> update="true" not-null="false" unique="false" type="int">
>>> </property>
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> </many-to-one>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </key>
>>> </list>
>>> unique="false"/>
>>> </key>
>>> </list>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> unique="false"/>
>>> </many-to-many>
>>> </list>
>>> </class>
The Netherlands
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425714 is a reply to message #425686] |
Fri, 05 December 2008 13:03 |
Hi Martin,
Stéphane has just sent you an e-mail with sample projects so as to
demonstrate the issue (if any).
We forgot to mention that the connection parameters are declared in the
activator of the library editor.
Just one last thing, this is using the very simple Library/Book/Writer
model, with no sub library and no feature map.
Guillaume.
PS :
My name is Guillaume. I must have stupidly switched my first name and my
last name at creation time.
Martin Taal wrote:
> Hi Brocard,
> myself.
> gr. Martin
>> Hi Martin,
>> Library demo
>> Library NoName
>> Book book1
>> Writer writer2
>> Borrower borrower3
>> Library library4
>> Library library5
>> Book book6
>> Book book10000
>> relationships.
>> Thanks in advance,
>> Guillaume.
>> Martin Taal wrote:
>>> Hi Stéphane,
>>> unique="false"/>
>>> </key>
>>> </list>
>>> value
>>> gr. Martin
>>>> Hi,
>>>> Lib
>>> rary,
>>>> "JOINED");
>>>> "NONE");
>>>> HbDataStore hbds =
>>>> hbds.initialize();
>>>> ("from library").
>>>> children.
>>>> Stephane.
>>>> Mapping content :
>>>> DTD 3.0//EN"
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </property>
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> </many-to-one>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </key>
>>>> </list>
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> unique="false"/>
>>>> </many-to-many>
>>>> </list>
>>>> </class>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425716 is a reply to message #425714] |
Fri, 05 December 2008 13:13 |
Hi Guillaume Brocard :-),
I received it, I will look at this weekend.
gr. Martin
> Hi Martin,
> Guillaume.
> PS :
> Martin Taal wrote:
>> Hi Brocard,
>> are not
>> myself.
>> gr. Martin
>>> Hi Martin,
>>> now, I'm taking up the torch.
>>> (the one with feature map), and basically, the objects stored in the
>>> database are looking like the following tree :
>>> Library demo
>>> Library NoName
>>> Book book1
>>> Writer writer2
>>> Borrower borrower3
>>> Library library4
>>> Library library5
>>> Book book6
>>> Book book10000
>>> relationships.
>>> 500) :
>>> objects (see Stéphane's explanations).
>>> Thanks in advance,
>>> Guillaume.
>>> Martin Taal wrote:
>>>> Hi Stéphane,
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> with value
>>>> gr. Martin
>>>>> Hi,
>>>>> Lib
>>>> rary,
>>>>> "JOINED");
>>>>> "NONE");
>>>>> HbDataStore hbds =
>>>>> hbds.initialize();
>>>>> ("from library").
>>>>> its children.
>>>>> types[i] is such a MarkerObject resolves it as a PersistentList
>>>>> with its data.
>>>>> Stephane.
>>>>> Mapping content :
>>>>> DTD 3.0//EN"
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </property>
>>>>> name="`category`"/>
>>>>> <type
>>>>> <param
>>>>> </type>
>>>>> </property>
>>>>> lazy="proxy" foreign-key="book_author" insert="true" update="true"
>>>>> not-null="false">
>>>>> </many-to-one>
>>>>> </class>
>>>>> table="`library`" proxy="org.eclipse.example.library.Library">
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </key>
>>>>> </list>
>>>>> </key>
>>>>> </list>
>>>>> </class>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </list>
>>>>> </class>
The Netherlands
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425748 is a reply to message #425716] |
Fri, 05 December 2008 23:13 |
Hi Stephane, Guillaume,
Your test project worked fine. I put a breakpoint in the HibernateResource. Then I opened the
editor, after stepping through the code I ended up in the method loadResource (in HibernateResource)
there the content of the resource is loaded in the storeList. When I look in the storeList there is
one library with two collections books and writers, both HibernatePersistableEList.
Now comes the tricky part: In the variables view I look at the content:
- if I click with my mouse on the books or writers (the label) then hibernate loads the list (as is
visible in the console). The same when I click on the label delegate within books/writers. I assume
that the debugger forces the list to load by asking for its contents or something.
- when I however click on the little triangle before the label the debug view opens the
HibernatePersistableList without loading the list. The same for the little triangle before the delegate.
- if you do this (open through the triangle) then you will see that the
hibernatepersistablelist.delegate has a list member which is null. So this means that after the load
of the library from the database, the writers and books list have not yet been loaded.
Let me know if you see other behavior.
gr. Martin
> gr. Martin
>> Hi Martin,
>> the activator of the library editor.
>> Thanks,
>> Guillaume.
>> PS :
>> my last name at creation time.
>> Martin Taal wrote:
>>> Hi Brocard,
>>> what
>>> are not
>>> myself.
>>> gr. Martin
>>>> Hi Martin,
>>>> Library demo
>>>> Library NoName
>>>> Book book1
>>>> Writer writer2
>>>> Borrower borrower3
>>>> Library library4
>>>> Library library5
>>>> Book book6
>>>> Book book10000
>>>> relationships.
>>>> 500) :
>>>> Thanks in advance,
>>>> Guillaume.
>>>> Martin Taal wrote:
>>>>> Hi Stéphane,
>>>>> </key>
>>>>> </list>
>>>>> with value
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> Lib
>>>>> rary,
>>>>>> contains other ones and so on...
>>>>>> (sorry for the code format due to copy/paste in the newsportal) :
>>>>>> "JOINED");
>>>>>> "NONE");
>>>>>> HbDataStore hbds =
>>>>>> hbds.initialize();
>>>>>> ("from library").
>>>>>> its children.
>>>>>> with its data.
>>>>>> a not loaded PersistentList (i.e a lazy one).
>>>>>> Stephane.
>>>>>> Mapping content :
>>>>>> DTD 3.0//EN"
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </property>
>>>>>> name="`category`"/>
>>>>>> <type
>>>>>> <param
>>>>>> </type>
>>>>>> </property>
>>>>>> not-null="false">
>>>>>> </many-to-one>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </key>
>>>>>> </list>
>>>>>> </key>
>>>>>> </list>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> <key update="true">
>>>>>> unique="false"/>
>>>>>> </key>
>>>>>> unique="false"/>
>>>>>> </many-to-many>
>>>>>> </list>
>>>>>> </class>
The Netherlands
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425765 is a reply to message #425748] |
Mon, 08 December 2008 13:23 |
Hi Martin,
I do not understand the 'little triangle' trick. Whenever I click it (for
collections, I can see a little (rotated yellow) square, no little
triangle), it is being resolved, as it selects the whole line.
Anyway, your analysis seems to be perfectly correct.
When displaying the sql queries, I can see that indeed, the initial query
is just asking for a library. And browsing through the editor nodes does
lead to new queries, as books and writers should be displayed.
I've been fooled by the debugging process...
However that still does not work with the extended library example, which
I am using along with the EMF Transaction framework (my application
requires that feature). It seems that the transaction change recorder is
loading the whole resource while adding itself as an adapter (at resource
loading time).
So Teneo is behaving exactly as expected, thanks a lot for your help (and
time).
Guillaume.
Then I opened the
something.
view opens the
been loaded.
> gr. Martin
>> gr. Martin
>>> Hi Martin,
>>> Thanks,
>>> Guillaume.
>>> PS :
>>> Martin Taal wrote:
>>>> Hi Brocard,
>>>> what
>>>> are not
>>>> myself.
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Library demo
>>>>> Library NoName
>>>>> Book book1
>>>>> Writer writer2
>>>>> Borrower borrower3
>>>>> Library library4
>>>>> Library library5
>>>>> Book book6
>>>>> Book book10000
>>>>> relationships.
>>>>> 500) :
>>>>> Thanks in advance,
>>>>> Guillaume.
>>>>> Martin Taal wrote:
>>>>>> Hi Stéphane,
>>>>>> </key>
>>>>>> </list>
>>>>>> with value
>>>>>> gr. Martin
>>>>>>> Hi,
>>>>>>> Lib
>>>>>> rary,
>>>>>>> "JOINED");
>>>>>>> "NONE");
>>>>>>> HbDataStore hbds =
>>>>>>> hbds.initialize();
>>>>>>> ("from library").
>>>>>>> its children.
>>>>>>> with its data.
>>>>>>> Stephane.
>>>>>>> Mapping content :
>>>>>>> DTD 3.0//EN"
>>>>>>> <meta
>>>>>>> </id>
>>>>>>> </version>
>>>>>>> </property>
>>>>>>> </property>
>>>>>>> name="`category`"/>
>>>>>>> <type
>>>>>>> <param
>>>>>>> </type>
>>>>>>> </property>
>>>>>>> not-null="false">
>>>>>>> </many-to-one>
>>>>>>> </class>
>>>>>>> <meta
>>>>>>> </id>
>>>>>>> </version>
>>>>>>> </property>
>>>>>>> </key>
>>>>>>> </list>
>>>>>>> </key>
>>>>>>> </list>
>>>>>>> </class>
>>>>>>> <meta
>>>>>>> </id>
>>>>>>> </version>
>>>>>>> </property>
>>>>>>> <key update="true">
>>>>>>> unique="false"/>
>>>>>>> </key>
>>>>>>> unique="false"/>
>>>>>>> </many-to-many>
>>>>>>> </list>
>>>>>>> </class>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425767 is a reply to message #425765] |
Mon, 08 December 2008 13:38 |
Hi Guillaume,
Ok, the HibernateResource has a getNonResolvingAllContents method which returns an iterator over the
content which should not result in loading non-loaded content. Maybe you can make use of that one in
this case.
gr. Martin
> Hi Martin,
> (for collections, I can see a little (rotated yellow) square, no little
> query is just asking for a library. And browsing through the editor
> nodes does lead to new queries, as books and writers should be displayed.
> which I am using along with the EMF Transaction framework (my
> application requires that feature). It seems that the transaction change
> recorder is loading the whole resource while adding itself as an adapter
> (at resource loading time).
> (and time).
> Guillaume.
>> HibernateResource.
> Then I opened the
>> look in
>> within
> something.
> view opens the
>> little
>> the hibernatepersistablelist.delegate has a list member which is null.
>> So this
> been loaded.
>> gr. Martin
>>> gr. Martin
>>>> Hi Martin,
>>>> Library/Book/Writer model, with no sub library and no feature map.
>>>> Thanks,
>>>> Guillaume.
>>>> PS :
>>>> and my last name at creation time.
>>>> Martin Taal wrote:
>>>>> Hi Brocard,
>>>>> see what
>>>>> are not
>>>>> myself.
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> model (the one with feature map), and basically, the objects
>>>>>> stored in the database are looking like the following tree :
>>>>>> Library demo
>>>>>> Library NoName
>>>>>> Book book1
>>>>>> Writer writer2
>>>>>> Borrower borrower3
>>>>>> Library library4
>>>>>> Library library5
>>>>>> Book book6
>>>>>> Book book10000
>>>>>> relationships.
>>>>>> line 500) :
>>>>>> NoName, which in turn is initialized with book1, writer2, ...,
>>>>>> library4, ... book10000 all resolved.
>>>>>> Thanks in advance,
>>>>>> Guillaume.
>>>>>> Martin Taal wrote:
>>>>>>> Hi Stéphane,
>>>>>>> </key>
>>>>>>> </list>
>>>>>>> with value
>>>>>>> gr. Martin
>>>>>>>> Hi,
>>>>>>>> Lib
>>>>>>> rary,
>>>>>>>> "JOINED");
>>>>>>>> "NONE");
>>>>>>>> HbDataStore hbds =
>>>>>>>> hbds.initialize();
>>>>>>>> ("from library").
>>>>>>>> with its children.
>>>>>>>> with its data.
>>>>>>>> or a not loaded PersistentList (i.e a lazy one).
>>>>>>>> are collections are well tagged as lazy ones.
>>>>>>>> Stephane.
>>>>>>>> Mapping content :
>>>>>>>> Mapping DTD 3.0//EN"
>>>>>>>> <meta
>>>>>>>> </id>
>>>>>>>> </version>
>>>>>>>> name="`title`"/>
>>>>>>>> </property>
>>>>>>>> name="`pages`"/>
>>>>>>>> </property>
>>>>>>>> name="`category`"/>
>>>>>>>> <type
>>>>>>>> <param
>>>>>>>> </type>
>>>>>>>> </property>
>>>>>>>> </many-to-one>
>>>>>>>> </class>
>>>>>>>> <meta
>>>>>>>> </id>
>>>>>>>> </version>
>>>>>>>> </property>
>>>>>>>> </key>
>>>>>>>> </list>
>>>>>>>> </key>
>>>>>>>> </list>
>>>>>>>> </class>
>>>>>>>> table="`writer`" proxy="org.eclipse.example.library.Writer">
>>>>>>>> <meta
>>>>>>>> </id>
>>>>>>>> </version>
>>>>>>>> </property>
>>>>>>>> <key update="true">
>>>>>>>> unique="false"/>
>>>>>>>> </key>
>>>>>>>> unique="false"/>
>>>>>>>> </many-to-many>
>>>>>>>> </list>
>>>>>>>> </class>
The Netherlands
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425772 is a reply to message #425767] |
Mon, 08 December 2008 15:14 |
Martin,
I could try that, providing my own editing domain implementation.
I'll let you know where the thing goes...
Guillaume.
Martin Taal wrote:
> Hi Guillaume,
> this case.
> gr. Martin
>> Hi Martin,
>> (and time).
>> Guillaume.
>>> HibernateResource.
>> Then I opened the
>>> look in
>>> within
>> something.
>> view opens the
>>> little
>>> So this
>> been loaded.
>>> gr. Martin
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Thanks,
>>>>> Guillaume.
>>>>> PS :
>>>>> Martin Taal wrote:
>>>>>> Hi Brocard,
>>>>>> see what
>>>>>> are not
>>>>>> myself.
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> Library demo
>>>>>>> Library NoName
>>>>>>> Book book1
>>>>>>> Writer writer2
>>>>>>> Borrower borrower3
>>>>>>> Library library4
>>>>>>> Library library5
>>>>>>> Book book6
>>>>>>> Book book10000
>>>>>>> relationships.
>>>>>>> line 500) :
>>>>>>> Thanks in advance,
>>>>>>> Guillaume.
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Stéphane,
>>>>>>>> </key>
>>>>>>>> </list>
>>>>>>>> with value
>>>>>>>> gr. Martin
>>>>>>>>> Hi,
>>>>>>>>> Lib
>>>>>>>> rary,
>>>>>>>>> "JOINED");
>>>>>>>>> "NONE");
>>>>>>>>> HbDataStore hbds =
>>>>>>>>> hbds.initialize();
>>>>>>>>> ("from library").
>>>>>>>>> with its children.
>>>>>>>>> with its data.
>>>>>>>>> Stephane.
>>>>>>>>> Mapping content :
>>>>>>>>> <meta
>>>>>>>>> </id>
>>>>>>>>> </version>
>>>>>>>>> name="`title`"/>
>>>>>>>>> </property>
>>>>>>>>> name="`pages`"/>
>>>>>>>>> </property>
>>>>>>>>> name="`category`"/>
>>>>>>>>> <type
>>>>>>>>> <param
>>>>>>>>> </type>
>>>>>>>>> </property>
>>>>>>>>> </many-to-one>
>>>>>>>>> </class>
>>>>>>>>> <meta
>>>>>>>>> </id>
>>>>>>>>> </version>
>>>>>>>>> </property>
>>>>>>>>> </key>
>>>>>>>>> </list>
>>>>>>>>> </key>
>>>>>>>>> </list>
>>>>>>>>> </class>
>>>>>>>>> <meta
>>>>>>>>> </id>
>>>>>>>>> </version>
>>>>>>>>> </property>
>>>>>>>>> <key update="true">
>>>>>>>>> unique="false"/>
>>>>>>>>> </key>
>>>>>>>>> unique="false"/>
>>>>>>>>> </many-to-many>
>>>>>>>>> </list>
>>>>>>>>> </class>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425778 is a reply to message #425772] |
Mon, 08 December 2008 16:25 |
Hi Martin,
To make a little wrap-up on this issue :
1) I have written my own HibernateResource with
getNonResolvingContent(EObject object_p) just made public.
2) I have provided my own editing domain factory, with one that allows me
to override the change recorder of the newly created transactional editing
domain.
3) Each time the transactional editing domain feels like registering a
change recorder, I'm testing against being a container object. In this
case, I simply return the
myResource.getNonResolvingContent(myRoot).basicIterator() in the change
recorder implementation.
I still have to make sure this is behaving as intended, but loading an
editor on my database content (10 000 objects from the extended library
model) now takes 0.2s when it used to take 24s (on a h2 local database).
It seems like the objects are being resolved when needed only. I can
clearly see that queries are sent while I am exploring the model in the
editor.
That is great news.
Again, thanks a lot for your help.
Guillaume.
> Martin,
> Guillaume.
> Martin Taal wrote:
>> Hi Guillaume,
can
>> this case.
>> gr. Martin
>>> Hi Martin,
>>> (and time).
>>> Guillaume.
>>>> HibernateResource.
>>> Then I opened the
>>>> look in
>>>> within
>>> something.
>>> view opens the
>>>> little
>>>> So this
>>> been loaded.
>>>> gr. Martin
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> Thanks,
>>>>>> Guillaume.
>>>>>> PS :
>>>>>> Martin Taal wrote:
>>>>>>> Hi Brocard,
>>>>>>> see what
>>>>>>> are not
>>>>>>> myself.
>>>>>>> gr. Martin
>>>>>>>> Hi Martin,
>>>>>>>> Library demo
>>>>>>>> Library NoName
>>>>>>>> Book book1
>>>>>>>> Writer writer2
>>>>>>>> Borrower borrower3
>>>>>>>> Library library4
>>>>>>>> Library library5
>>>>>>>> Book book6
>>>>>>>> Book book10000
>>>>>>>> relationships.
>>>>>>>> line 500) :
>>>>>>>> Thanks in advance,
>>>>>>>> Guillaume.
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi Stéphane,
>>>>>>>>> </key>
>>>>>>>>> </list>
>>>>>>>>> with value
>>>>>>>>> gr. Martin
>>>>>>>>>> Hi,
>>>>>>>>>> Lib
>>>>>>>>> rary,
>>>>>>>>>> "JOINED");
>>>>>>>>>> "NONE");
>>>>>>>>>> HbDataStore hbds =
>>>>>>>>>> hbds.initialize();
>>>>>>>>>> ("from library").
>>>>>>>>>> with its children.
>>>>>>>>>> with its data.
>>>>>>>>>> Stephane.
>>>>>>>>>> Mapping content :
>>>>>>>>>> <meta
>>>>>>>>>> </id>
>>>>>>>>>> </version>
>>>>>>>>>> name="`title`"/>
>>>>>>>>>> </property>
>>>>>>>>>> name="`pages`"/>
>>>>>>>>>> </property>
>>>>>>>>>> name="`category`"/>
>>>>>>>>>> <type
>>>>>>>>>> <param
>>>>>>>>>> </type>
>>>>>>>>>> </property>
>>>>>>>>>> </many-to-one>
>>>>>>>>>> </class>
>>>>>>>>>> <meta
>>>>>>>>>> </id>
>>>>>>>>>> </version>
>>>>>>>>>> </property>
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> </class>
>>>>>>>>>> <meta
>>>>>>>>>> </id>
>>>>>>>>>> </version>
>>>>>>>>>> </property>
>>>>>>>>>> <key update="true">
>>>>>>>>>> unique="false"/>
>>>>>>>>>> </key>
>>>>>>>>>> unique="false"/>
>>>>>>>>>> </many-to-many>
>>>>>>>>>> </list>
>>>>>>>>>> </class>
Re: [Teneo] hibernate collection lazy loading behavior ? [message #425780 is a reply to message #425778] |
Mon, 08 December 2008 16:29 |
Hi Guillaume,
Thanks for the update and good to hear that it works better.
gr. Martin
> Hi Martin,
> me to override the change recorder of the newly created transactional
> editing domain.
> editor.
> That is great news.
> Guillaume.
>> Martin,
>> Guillaume.
>> Martin Taal wrote:
>>> Hi Guillaume,
> can
>>> this case.
>>> gr. Martin
>>>> Hi Martin,
>>>> little triangle), it is being resolved, as it selects the whole line.
>>>> displayed.
>>>> change recorder is loading the whole resource while adding itself as
>>>> an adapter (at resource loading time).
>>>> (and time).
>>>> Guillaume.
>>>>> HibernateResource.
>>>> Then I opened the
>>>>> I look in
>>>>> content:
>>>>> delegate within
>>>>> contents or
>>>> something.
>>>>> debug
>>>> view opens the
>>>>> little
>>>>> null. So this
>>>>> not yet
>>>> been loaded.
>>>>> gr. Martin
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> to demonstrate the issue (if any).
>>>>>>> in the activator of the library editor.
>>>>>>> Thanks,
>>>>>>> Guillaume.
>>>>>>> PS :
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Brocard,
>>>>>>>> see what
>>>>>>>> libs are not
>>>>>>>> myself.
>>>>>>>> gr. Martin
>>>>>>>>> Hi Martin,
>>>>>>>>> right now, I'm taking up the torch.
>>>>>>>>> Library demo
>>>>>>>>> Library NoName
>>>>>>>>> Book book1
>>>>>>>>> Writer writer2
>>>>>>>>> Borrower borrower3
>>>>>>>>> Library library4
>>>>>>>>> Library library5
>>>>>>>>> Book book6
>>>>>>>>> Book book10000
>>>>>>>>> the Library.stock, Library.people, or Library.branches
>>>>>>>>> containment relationships.
>>>>>>>>> line 500) :
>>>>>>>>> the objects (see Stéphane's explanations).
>>>>>>>>> Thanks in advance,
>>>>>>>>> Guillaume.
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi Stéphane,
>>>>>>>>>> </key>
>>>>>>>>>> </list>
>>>>>>>>>> member with value
>>>>>>>>>> gr. Martin
>>>>>>>>>>> Hi,
>>>>>>>>>>> Lib
>>>>>>>>>> rary,
>>>>>>>>>>> newsportal) :
>>>>>>>>>>> "10");
>>>>>>>>>>> "JOINED");
>>>>>>>>>>> "NONE");
>>>>>>>>>>> HbDataStore hbds =
>>>>>>>>>>> hbds.initialize();
>>>>>>>>>>> query ("from library").
>>>>>>>>>>> with its children.
>>>>>>>>>>> entity );
>>>>>>>>>>> one contains 2 MarkerObject instances set to
>>>>>>>>>>> NOT_NULL_COLLECTION regarding the 'books' and the 'writers'
>>>>>>>>>>> collections.
>>>>>>>>>>> UNFECTCHED_COLLECTION or a not loaded PersistentList (i.e a
>>>>>>>>>>> lazy one).
>>>>>>>>>>> Stephane.
>>>>>>>>>>> Mapping content :
>>>>>>>>>>> table="`book`" proxy="org.eclipse.example.library.Book">
>>>>>>>>>>> <meta
>>>>>>>>>>> </id>
>>>>>>>>>>> </version>
>>>>>>>>>>> name="`title`"/>
>>>>>>>>>>> </property>
>>>>>>>>>>> name="`pages`"/>
>>>>>>>>>>> </property>
>>>>>>>>>>> not-null="false" insert="true" update="true" unique="false">
>>>>>>>>>>> name="`category`"/>
>>>>>>>>>>> <type
>>>>>>>>>>> <param
>>>>>>>>>>> </type>
>>>>>>>>>>> </property>
>>>>>>>>>>> </many-to-one>
>>>>>>>>>>> </class>
>>>>>>>>>>> <class
>>>>>>>>>>> <meta
>>>>>>>>>>> </id>
>>>>>>>>>>> </version>
>>>>>>>>>>> name="`name`"/>
>>>>>>>>>>> </property>
>>>>>>>>>>> </key>
>>>>>>>>>>> </list>
>>>>>>>>>>> </key>
>>>>>>>>>>> </list>
>>>>>>>>>>> </class>
>>>>>>>>>>> <meta
>>>>>>>>>>> </id>
>>>>>>>>>>> </version>
>>>>>>>>>>> name="`name`"/>
>>>>>>>>>>> </property>
>>>>>>>>>>> <key update="true">
>>>>>>>>>>> unique="false"/>
>>>>>>>>>>> </key>
>>>>>>>>>>> unique="false"/>
>>>>>>>>>>> </many-to-many>
>>>>>>>>>>> </list>
>>>>>>>>>>> </class>
The Netherlands
Current Time: Thu Mar 28 19:38:59 GMT 2024
Powered by FUDForum. Page generated in 0.03561 seconds
