Home » Modeling » EMF » How to force a node to refresh it's properties view
How to force a node to refresh it's properties view [message #425600] |
Wed, 03 December 2008 06:31 |
Asha Ramegowda Messages: 77 Registered: July 2009 |
Member |
I have an editor generated for an emf model.
Based on some run time data I am adding some values to an aggregation
reference variable of the element. It will not reflect until, I save the
editor close it and reopen.
I would like to know, how I can force the node to refresh itself, so that
it generates property descriptors for newly added values in the list?
In fact, I am displaying the properties of the list elements, at the
parent node.
So, my problem is, when I add something to the list using the child
descriptors actions, it appears as a child, but the parent node's property
descriptor for the same list would not get refreshed. So, how can I
refresh the parent node?
Thank you,
Asha R.
Re: How to force a node to refresh it's properties view [message #425604 is a reply to message #425600] |
Wed, 03 December 2008 11:55 |
Ed Merks Messages: 33140 Registered: July 2009 |
Asha,
Comments below.
Asha R wrote:
> the editor close it and reopen.
Where is it not being reflected? Are you making the change using a command?
> that it generates property descriptors for newly added values in the
> list?
I'm not quite sure why it wouldn't already do this.
> parent node.
I'm not following how this is working...
> but the parent node's property descriptor for the same list would not
> get refreshed. So, how can I refresh the parent node?
If you are using a property descriptor to make the change how is it that
the list of property descriptors is affected by this?
Are you making sure the list of property descriptors is recomputed each
time? By default it's computed once and cached, but in your case, each
instance can have a different list, so you need to ensure it's being
recomputed.
> Thank you,
> Asha R.
Ed Merks
Re: How to force a node to refresh it's properties view [message #425631 is a reply to message #425604] |
Wed, 03 December 2008 14:28 |
Member |
Hi Ed,
Thanks for the reply.
I have seen the MappingItemProvider and implemented the properties of a
list to appear as if they are properties of it's parent node.
I mean if I have a Device, which has a list of Property, each of the
property in the list should appear as the property of the parent node.
Everything is same as the MappingItemProvider logic.
Like it displays each property listing with uniquie count like,
+ 1. Property
+ 2. Property
<my attributes for class>
etc.
This works only when I read all the properties initially into the Device
class.
If I add them dynamically it wont reflect until I close and re open the
editor.
I mean to test this, )earlier I blocked the collection of child
descriptors), I collected the child descriptors and tried to add the
Property instances in to the list. When, I add, and go back to the parent
node, it will not reflect the new property added, with a count and
expandable tree.
So, I have to close the editor and re open it.
So far have not tried commands to create this new properties.
But, I guess once I add them through command it should work.
But, when I am using child actions, they also fire commands you know, why
they are not working?
Sorry, if I am unable to put my problem properly, if you are not
understanding... :-).
Thank you,
Asha R.
Please find my comments below.
Ed Merks wrote:
> Asha,
> Comments below.
> Asha R wrote:
>> Hi,
>> list?
>> parent node.
> recomputed.
>> Thank you,
>> Asha R.
Re: How to force a node to refresh it's properties view [message #425635 is a reply to message #425631] |
Wed, 03 December 2008 14:49 |
Asha,
Comments below.
Asha R wrote:
> Hi Ed,
Goodness knows how I can ever get anything else done...
> a list to appear as if they are properties of it's parent node.
> + 1. Property
> + 2. Property
> etc.
> Device class.
> the editor.
I gather that. Can you show what your getPropertyDescriptors method
looks like?
> parent node, it will not reflect the new property added, with a count
> and expandable tree.
I though you needed to add an actual Property to the Device object and
normally doing that will be reflected in the tree view. Then the item
provider just creates property descriptors to wrap those Property instances.
Without commands, things won't work so well. Specifically, when you
execute a command, the properties view will be refreshed, and that's
exactly what's not happening.
yep.
> why they are not working?
Not so clear what's not working. I suspect it's because your caching
the list of property descriptors, as I mentioned, but now I'm asking to
see the code so that I'll be sure the question is answered.
> Thank you,
> Asha R.
> Ed Merks wrote:
>> Asha,
>> Comments below.
>> Asha R wrote:
>>> Hi,
>>> aggregation reference variable of the element. It will not reflect
>>> until, I save the editor close it and reopen.
>> command?
>>> list?
>>> parent node.
>>> not get refreshed. So, how can I refresh the parent node?
>> that the list of property descriptors is affected by this?
>> each time? By default it's computed once and cached, but in your
>> case, each instance can have a different list, so you need to ensure
>> it's being recomputed.
>>> Thank you,
>>> Asha R.
Ed Merks
Re: How to force a node to refresh it's properties view [message #425637 is a reply to message #425635] |
Wed, 03 December 2008 15:21 |
Member |
Hi Ed,
Thanks for the reply again. :-).
Please see my comments below.
Ed Merks wrote:
> Asha,
> Comments below.
> Asha R wrote:
>> Hi Ed,
I am Indian and my mother tongue is not English. So I don't know what you
mean by this and I don't know such good English. :)). So, I am not getting
what you said. I hope you are not sarcastic :)).
I am not even getting whether you complimented me or what :)))!
I am really confused, probably because of this so called dynamic
properties. :)). Sorry, if I am assuming something wrong. But, I really
feel bad for taking help from you all the time.
>> + 1. Property
>> + 2. Property
>> etc.
>> Device class.
>> the editor.
> looks like?
public List<IItemPropertyDescriptor> getPropertyDescriptors(Object object)
if (itemPropertyDescriptors == null) {
super.getPropertyDescriptors(object);
addDeviceNamePropertyDescriptor(object);
Device theDevice = (Device)object;
HdfPackage ePackage = HdfPackage.eINSTANCE;
boolean hasProperties = (theDevice.getDeviceProperties().size() > 0);
if (hasProperties)
int count = 1;
for (final Property childProperty :
theDevice.getDeviceProperties())
IItemPropertyDescriptor childPropertyItemPropertyDescriptor =
new
ItemPropertyDescriptor(((ComposeableAdapterFactory)adapterFa ctory).getRootAdapterFactory(),
getResourceLocator(),
//Can be replaced with a proper string from plugin.properties
//Count is used to generate the unique names
count + " ." + " Device Property",
"Proper combination of plugin.properties will appear here",
HdfPackage.Literals.DEVICE__DEVICE_PROPERTIES, //name of the
list we want to handle
true,
false,
false,
ItemPropertyDescriptor.GENERIC_VALUE_IMAGE,
null,
null);
itemPropertyDescriptors.add
(new ItemPropertyDescriptorDecorator(childProperty,
childPropertyItemPropertyDescriptor)
public Object getPropertyValue(Object o)
super.getPropertyValue(o);
return this.object;
public Collection<?> getChoiceOfValues(Object o)
return null;
++count;
return itemPropertyDescriptors;
Probably you don't need following files, but still, I am posting them here.
This is my ecore model
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="hdf"
nsURI="http://www.example.org/hd" nsPrefix="hd">
<eClassifiers xsi:type="ecore:EClass" name="HardwareDefinition">
<eStructuralFeatures xsi:type="ecore:EReference" name="devices"
upperBound="-1"
eType="#//Device" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="buses"
upperBound="-1"
eType="#//Bus" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Device">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="deviceName"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
name="deviceProperties" upperBound="-1"
eType="#//Property" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Bus">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="busName"
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E String "/>
<eStructuralFeatures xsi:type="ecore:EReference" name="busProperties"
upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Property">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="enumProperty"
eType="#//HDENUM"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="floatValue"
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E Float "/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="HDENUM">
<eLiterals name="WinXP"/>
<eLiterals name="LINUX"/>
<eLiterals name="UNIX"/>
<eLiterals name="SOLARIS"/>
</eClassifiers>
</ecore:EPackage>
And I have generated the code setting the item providers to be stateful.
This is my genmodel
<genmodel:GenModel xmi:version="2.0"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel"
modelDirectory="/sample/src"
modelPluginID="sample" modelName="Sample"
importerID="org.eclipse.emf.importer.ecore"
complianceLevel="5.0" copyrightFields="false"
usedGenPackages=" platform:/plugin/org.eclipse.emf.ecore/model/Ecore.genmodel# //ecore ">
<foreignModel>sample.ecore</foreignModel>
<genPackages prefix="Hdf" disposableProviderFactory="true"
ecorePackage="sample.ecore#/">
<genEnums typeSafeEnumCompatible="false"
ecoreEnum="sample.ecore#//HDENUM">
<genEnumLiterals ecoreEnumLiteral="sample.ecore#//HDENUM/WinXP"/>
<genEnumLiterals ecoreEnumLiteral="sample.ecore#//HDENUM/LINUX"/>
<genEnumLiterals ecoreEnumLiteral="sample.ecore#//HDENUM/UNIX"/>
<genEnumLiterals ecoreEnumLiteral="sample.ecore#//HDENUM/SOLARIS"/>
</genEnums>
<genClasses provider="Stateful"
ecoreClass="sample.ecore#//HardwareDefinition">
<genFeatures property="None" children="true" createChild="true"
ecoreFeature="ecore:EReference sample.ecore#//HardwareDefinition/devices"/>
ecoreFeature="ecore:EReference sample.ecore#//HardwareDefinition/buses"/>
</genClasses>
<genClasses provider="Stateful" ecoreClass="sample.ecore#//Device">
<genFeatures createChild="false" ecoreFeature="ecore:EAttribute
sample.ecore#//Device/deviceName"/>
ecoreFeature="ecore:EReference sample.ecore#//Device/deviceProperties"/>
</genClasses>
<genClasses provider="Stateful" ecoreClass="sample.ecore#//Bus">
sample.ecore#//Bus/busName"/>
ecoreFeature="ecore:EReference sample.ecore#//Bus/busProperties"/>
</genClasses>
<genClasses provider="Stateful" ecoreClass="sample.ecore#//Property">
sample.ecore#//Property/name"/>
sample.ecore#//Property/value"/>
sample.ecore#//Property/enumProperty"/>
sample.ecore#//Property/floatValue"/>
</genClasses>
</genPackages>
</genmodel:GenModel>
This is just an example as I can't share the real code with you... :-).
But, here you can try adding the child nodes with descriptors and go back
to the parent node and it will not reflect the properties of child node
until and unless you close the editor and open it. So, that's the problem.
> yep.
>> Thank you,
>> Asha R.
>> Ed Merks wrote:
>>> Asha,
>>> Comments below.
>>> Asha R wrote:
>>>> Hi,
>>> command?
>>>> list?
>>>> parent node.
>>>> Thank you,
>>>> Asha R.
Re: How to force a node to refresh it's properties view [message #425638 is a reply to message #425637] |
Wed, 03 December 2008 15:25 |
Member |
Hi Ed,
Some comments in the code are written for my TL who does not know eclipse
:)). Not for you.
Hope you don't mind for them.
Then, I thanked you because I was really waiting for you reply.
But, not because I wanted you to provide me a solution.
Asha R.
Asha R wrote:
> Hi Ed,
> Ed Merks wrote:
>> Asha,
>> Comments below.
>> Asha R wrote:
>>> Hi Ed,
>>> + 1. Property
>>> + 2. Property
>>> etc.
>>> Device class.
>>> the editor.
>> looks like?
> if (hasProperties)
> int count = 1;
> new
> true,
> false,
> false,
> null,
> null);
> @Override
> return this.object;
> @Override
> return null;
> ++count;
> xmlns:xmi="http://www.omg.org/XMI"
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> eType="#//HDENUM"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> This is my genmodel
> </genEnums>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genPackages>
>> yep.
>>> Thank you,
>>> Asha R.
>>> Ed Merks wrote:
>>>> Asha,
>>>> Comments below.
>>>> Asha R wrote:
>>>>> Hi,
>>>> command?
>>>>> list?
>>>>> parent node.
>>>>> Thank you,
>>>>> Asha R.
Re: How to force a node to refresh it's properties view [message #425640 is a reply to message #425637] |
Wed, 03 December 2008 15:35 |
Asha,
Comments below.
Asha R wrote:
> Hi Ed,
> Ed Merks wrote:
>> Asha,
>> Comments below.
>> Asha R wrote:
>>> Hi Ed,
> you mean by this and I don't know such good English. :)). So, I am not
> getting what you said. I hope you are not sarcastic :)).
A little bit sarcastic. The questions are arriving faster than I can
answer them which makes me cranky.
Not so much. :-P
> really feel bad for taking help from you all the time.
>>> of a list to appear as if they are properties of it's parent node.
>>> + 1. Property
>>> + 2. Property
>>> etc.
>>> Device class.
>>> the editor.
>> looks like?
> object) {
So this is exactly what I'm getting at. Once you compute the list,
you'll never recompute it and because your item providers are stateless
(by default), one adapter is used for all instances. Instead try
itemPropertyDescriptors = null;
I.e., always set it to null, always call super and always do the rest of
your logic.
> if (hasProperties)
> int count = 1;
> new
> names
> will appear here",
> HdfPackage.Literals.DEVICE__DEVICE_PROPERTIES, //name of the list we
> want to handle
> true,
> false,
> false,
> null,
> null);
> (new
> @Override
> return this.object;
> @Override
> return null;
> ++count;
> here.
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> name="busProperties" upperBound="-1"
> </eClassifiers>
> name="enumProperty" eType="#//HDENUM"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> This is my genmodel
> </genEnums>
> </genClasses>
> </genClasses>
> </genClasses>
> </genClasses>
> </genPackages>
> back to the parent node and it will not reflect the properties of
> child node until and unless you close the editor and open it. So,
> that's the problem.
>>> count and expandable tree.
>> and normally doing that will be reflected in the tree view. Then the
>> item provider just creates property descriptors to wrap those
>> Property instances.
>> yep.
>>> know, why they are not working?
>> to see the code so that I'll be sure the question is answered.
>>> Thank you,
>>> Asha R.
>>> Ed Merks wrote:
>>>> Asha,
>>>> Comments below.
>>>> Asha R wrote:
>>>>> Hi,
>>>> command?
>>>>> so that it generates property descriptors for newly added values
>>>>> in the list?
>>>>> the parent node.
>>>>> child descriptors actions, it appears as a child,
>>>> ensure it's being recomputed.
>>>>> Thank you,
>>>>> Asha R.
Ed Merks
Current Time: Thu Apr 25 05:16:11 GMT 2024
Powered by FUDForum. Page generated in 0.03348 seconds
