Two way references and Dyanmic Feature Delegation [message #425544] |
Mon, 01 December 2008 12:37 |
J F Messages: 256 Registered: July 2009 |
I think there may be a problem with 2 way reference generation using
Dynamic Feature Delegation generation.
I am generating the code under EMF 2.5 (2.5.0.v200811032126) with
Eclipse 3.5 ( I20081030-1917 ). I run under EMF 2.4 (2.4.1.v200808251517)
with Eclipse 3.4. This follows Ed's suggestion about cdo
( http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 5397.html)
Take the simple library tuorial model and generate the model code using
Dynamic feature delegation.
BookImpl has an inverseAdd generated to cope with setting its author from
Writer which all looks as expected;
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public NotificationChain eInverseAdd(InternalEObject otherEnd, int
featureID, NotificationChain msgs) {
switch (featureID) {
case LibraryPackage.BOOK__AUTHOR:
Writer author = basicGetAuthor();
if (author != null)
msgs = ((InternalEObject)author).eInverseRemove(this,
LibraryPackage.WRITER__BOOKS, Writer.class, msgs);
return basicSetAuthor((Writer)otherEnd, msgs);
return super.eInverseAdd(otherEnd, featureID, msgs);
However if we look at basicSetAuthor we see
* @generated
public NotificationChain basicSetAuthor(Writer newAuthor,
msgs = eDynamicInverseRemove((InternalEObject)newAuthor,
LibraryPackage.BOOK__AUTHOR, msgs);
return msgs;
When I add a book to a writer the author property in the book is never set.
Is this a bug, or am I missing something?
Writer writer = LibraryFactory.eINSTANCE.createWriter();
writer.setName("Pierre Menard");
Book book = LibraryFactory.eINSTANCE.createBook();
book.setTitle("Quixote");
writer.getBooks().add(book);
System.out.println("Writer " + writer.getName() + " wrote " +
(writer.getBooks().isEmpty()?"nothing":writer.getBooks().iterator().next().getTitle()));
System.out.println("The Book " + book.getTitle() + " was written by " +
(book.getAuthor()==null?"no one":book.getAuthor().getName()));
System.out.println("");
Writer writer2 = LibraryFactory.eINSTANCE.createWriter();
writer2.setName("Cervantes");
Book book2 = LibraryFactory.eINSTANCE.createBook();
book2.setTitle("Don Quixote");
book2.setAuthor(writer2);
System.out.println("Writer " + writer2.getName() + " wrote " +
(writer2.getBooks().isEmpty()?"nothing":writer2.getBooks().iterator().next().getTitle()));
System.out.println("The Book " + book2.getTitle() + " was written by " +
(book2.getAuthor()==null?"no one":book2.getAuthor().getName()));
outputs:
Writer Pierre Menard wrote Quixote
The Book Quixote was written by no one
Writer Cervantes wrote Don Quixote
The Book Don Quixote was written by Cervantes
If I do that with a model (same environment) generated with Feature
Delegation None, I get what I expected;
The Book Quixote was written by Pierre Menard
Re: Two way references and Dyanmic Feature Delegation [message #425547 is a reply to message #425544] |
Mon, 01 December 2008 13:24 |
Ed Merks Messages: 33137 Registered: July 2009 |
JF,
Comments below.
JF wrote:
> (2.4.1.v200808251517) with Eclipse 3.4. This follows Ed's suggestion
> about cdo
> using Dynamic feature delegation.
> from Writer which all looks as expected;
> * @generated
> @Override
> if (author != null)
> msgs =
> * @generated
> return msgs;
> set.
Hmmm. Even at a glance it seems it should be eDynamicInverseAdd,
right? Could you try that and open a bugzilla with your findings?
> public static void main(String[] args) {
> written by " + (book.getAuthor()==null?"no
> written by " + (book2.getAuthor()==null?"no
> outputs:
Ed Merks
FUDForum. Page generated in 0.03309 seconds
