Re: Connector is not connected [message #425542 is a reply to message #425526] |
Mon, 01 December 2008 11:35 |
Tankut,
I nearly overlooked you question because it is neither tagged with [CDO]
nor with [Net4j]. Just a hint for future questions ;-)
From your question I only see that a connection was not opened. This
copuld have so many reasons, including:
- server not started
- server started but acceptor not started
- acceptor listens on different port or address
- connector and acceptor started but network failed
- connector deactivated locally after initial requests had been sent
I'd really need more context information to answer your question. Could
you describe what you have done so far?
Additionally you could provide the client and server console logs (did
you enable tracing at both ends?)...
Cheers
/Eike
Tankut Koray schrieb:
> I am trying to run a CDO server but when I client (CDO Sessions View)
> tries to connect, It gives the following exception:
> [ERROR] Connector is not connected
> java.lang.IllegalStateException: Connector is not connected
> at
> org.eclipse.net4j.internal.tcp.ControlChannel.assertConnecte d(ControlChannel.java:238)
> at
> org.eclipse.net4j.internal.tcp.ControlChannel.handleBufferFr omMultiplexer(ControlChannel.java:137)
> at
> org.eclipse.net4j.internal.tcp.TCPConnector.handleRead(TCPCo nnector.java:179)
> at
> org.eclipse.net4j.internal.tcp.TCPSelector.handleSelection(T CPSelector.java:255)
> at org.eclipse.net4j.internal.tcp.TCPSelector.run(TCPSelector.j ava:170)
> at java.lang.Thread.run(Unknown Source)
> Any ideas,
> Tankut
Cheers
/Eike
http://www.esc-net.de
Re: Connector is not connected [CDO] [message #425751 is a reply to message #425750] |
Sun, 07 December 2008 09:45 |
Tankut,
Oh yes, the negotiators of a connector / acceptor pair must match
together or be empty both.
Good that you found it.
Cheers
/Eike
> Thanks Eike,
> I was writing a reply with my logs but I have another look at
> configuration
> of server and when I commented out the negotiator in my acceptor, every
> thing is working fine now.
> Just a note if someone will have the same issue,
> Tankut
> "Eike Stepper" <stepper@esc-net.de> wrote in message
> news:gh0i5k$vfc$5@build.eclipse.org...
>> Tankut,
>> [CDO] nor with [Net4j]. Just a hint for future questions ;-)
>> Could you describe what you have done so far?
>> (did you enable tracing at both ends?)...
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>>> Hi,
>>> View) tries to connect, It gives the following exception:
>>> at
>>> at
>>> at
>>> at
>>> Any ideas,
>>> Tankut
Cheers
/Eike
FUDForum. Page generated in 0.02027 seconds
