Re: Custom serialization [message #425305 is a reply to message #425299] |
Sat, 22 November 2008 08:00 |
Ed Merks Messages: 33137 Registered: July 2009 |
Alex,
Comments below.
Alex Boyko wrote:
> Is there any possibility to provide a custom serialization for an EList.
> By default it's serialized (properties is the feature's name):
> <properties>entry_1</properties>
> <properties>entry_n</properties>
> An example of custom serialization:
> <properties>entry_1 entry_2 ... entry_n</properties>
There's nothing that will ever directly serialize a multi-valued
property as a single value. XML Schema does support this with
<xsd:list> data types, but then you end up with a single valued property
for which the value is a list value.
> Would extended metadata annotations be of any help?
> Could you give a link to some tutorial on extended metadata usage
> please? (I admit that didn't search very hard for it)
There is a document describing them. Often it's easiest to write a
schema for what you expect and look at the resulting annotations of that.
Or you could specialize XMLSaveImpl and XMLHandler to deal in a special
way with you feature.
> Thanks in advance!
> Cheers,
> Alex
Ed Merks
FUDForum. Page generated in 0.03261 seconds
