Home » Modeling » EMF » [CDO]Model update
Re: [CDO]Model update [message #425261 is a reply to message #425260] |
Fri, 21 November 2008 09:14 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
xxlu, Simon,
maybe you could take look at this:
"COPE - Coupled Evolution of Metamodels and Models"
http://cope.in.tum.de
Quite impressive stuff. I allows you to modify a model, record the
changes you've made on it and then generate a plugin capable of update
old model instances to the new version.
Still, you would need to change your model URI (for instance, changing
the version: from http://foo.bar.org/example/1.0 to
http://foo.bar.org/example/2.0), but the generated migration plugin
should help you dealing with it!
We just need to execute that transformation with a CDOResource. We could
probably add the context menu migration action (which is currently only
available at package explorer/resource navigator context menu) to
CDOSession View by passing to their migration API a CDOResource instead.
And I think this would be a cool experiment :)
I've read It's going to be probably contributed to Eclipse.
xxlu escribió:
> I think this is a very complicated question, too. : (
> In my project, model will be updated frequently. It's so discommodious to
> migrate my database everytime. ;(
> "Simon McDuff" <smcduff@hotmail.com>
>> At the moment CDO does not support evolving classes.
>> Currently in CDO, a package with a given URI (X) should never be modified.
>> If you do so, a new URI(for the package) should be given.
>> If you follow this your objects will still be available using the old
>> model.
>> Does CDO should do more ? (Let me think about it during the night (it is
>> around 23:48 here :-))
>> This is a very complicated question that needs to be think deeply!
>> Usually you will need to change the URI of your package.. and migrate
>> your databases...
>> Maybe Eike will have another idea.
>> Simon
>> xxlu wrote:
>>> Hi Ed,
>>> I have a problem that I can't resolve. I create a database for my
>>> model with CDO2.0M3. When I update my model, for example, I add an
>>> attribute for one class, I can't reload the old data from database. The
>>> exception is following:
>>> java.lang.IllegalStateException: range.size() != metaIDRange.size()
>>> at
>>> org.eclipse.emf.internal.cdo.CDOSessionImpl.registerEPackage (CDOSessionImpl.java:544)
>>> at
>>> org.eclipse.emf.internal.cdo.util.CDOPackageRegistryImpl$Rem otePackageDescriptor.getEPackage(CDOPackageRegistryImpl.java :182)
>>> at
>>> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.lo adPackage(CDOSessionPackageManagerImpl.java:152)
>>> at
>>> org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loa d(CDOPackageImpl.java:401)
>>> at
>>> org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loo kupClass(CDOPackageImpl.java:288)
>>> at
>>> org.eclipse.emf.cdo.internal.common.model.CDOClassRefImpl.re solve(CDOClassRefImpl.java:71)
>>> at
>>> org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO ClassRefAndResolve(CDODataInputImpl.java:218)
>>> at
>>> org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORevisionImpl.java:114)
>>> at
>>> org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO Revision(CDODataInputImpl.java:309)
>>> at
>>> org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:116)
>>> at
>>> org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:1)
>>> at
>>> org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClientRequest.java:103)
>>> at
>>> org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:118)
>>> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
>>> at
>>> org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:98)
>>> at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:68)
>>> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
>>> at
>>> org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:392)
>>> at
>>> org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:82)
>>> at
>>> org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
>>> at
>>> org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.send(CDO RevisionManagerImpl.java:149)
>>> at
>>> org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.loadRevi sion(CDORevisionManagerImpl.java:104)
>>> at
>>> org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:94)
>>> at
>>> org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:1)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOViewImpl.getRevision(CDOView Impl.java:714)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOViewImpl.createObject(CDOVie wImpl.java:857)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOViewImpl.getObject(CDOViewIm pl.java:752)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOTransactionImpl.getObject(CD OTransactionImpl.java:449)
>>> at
>>> org.eclipse.emf.internal.cdo.CDOViewImpl.convertIDToObject(C DOViewImpl.java:1023)
>>> at org.eclipse.emf.internal.cdo.CDOStore.convertToEMF(CDOStore. java:381)
>>> at org.eclipse.emf.internal.cdo.CDOStore.get(CDOStore.java:175)
>>> at
>>> org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreELis t.delegateGet(EStoreEObjectImpl.java:225)
>>> at
>>> org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)
>>> at
>>> org.eclipse.emf.common.util.DelegatingEList$EIterator.doNext (DelegatingEList.java:1075)
>>> at
>>> org.eclipse.emf.common.util.DelegatingEList$EIterator.next(D elegatingEList.java:1062)
>>> at
>>> org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProviderAdapter.java:340)
>>> at
>>> org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProviderAdapter.java:310)
>>> at
>>> org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElements(AdapterFactoryContentProvider.java:160)
>>> What should I do?
Re: [CDO]Model update [message #425270 is a reply to message #425261] |
Fri, 21 November 2008 12:19 |
Guys,
Indeed, model evolution is a very interesting problem and certainly hard
to solve in the context of a persistent model repository with support
for temporality. I'd also appreciate to start discussion and see if we
can do something constructive in this area.
I also think that COPE is an interesting first step to look at. But in
the long term I'd like to see an approach that doesn't go through a
regular user transaction at client side but rather modifies the
repository directly at the server side. For huge models this seems to be
the only appropriate way and models seem to grow constantly.
Here are some points to consider:
1) Would COPE be able to help us at the server side? We don't have EMF
there...
2) Should there be a new protocol (signals) to implement API like
CDOSessionPackageManager::evolvePackage(String oldURI, EPackage
newPackage, CDODataMigrationRules rules) ?
3) Should these data migration rules operate on the CDORevision level or
on back-end concepts level?
4) What about on-demand migration per instance (as opposed to one huge
migration process for the whole repository)?
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> xxlu, Simon,
> could probably add the context menu migration action (which is
> currently only available at package explorer/resource navigator
> context menu) to CDOSession View by passing to their migration API a
>> discommodious to migrate my database everytime. ;(
>>> modified. If you do so, a new URI(for the package) should be given.
>>> old model.
>>> (it is around 23:48 here :-))
>>> migrate your databases...
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> my model with CDO2.0M3. When I update my model, for example, I add
>>>> an attribute for one class, I can't reload the old data from
>>>> database. The exception is following:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO]Model update [message #425275 is a reply to message #425261] |
Fri, 21 November 2008 12:43 |
Simon Mc Duff Messages: 596 Registered: July 2009 |
Víctor Roldán Betancort wrote:
> xxlu, Simon,
I saw it few days ago while reading Ed blogs!! Very interesting!!
It will work lovely with CDO since the URI will change!
Good to know!
>>> model.
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Re: [CDO]Model update [message #425276 is a reply to message #425275] |
Fri, 21 November 2008 12:45 |
Didn't refresh my newsgroup!! Eike already answered!!
>> xxlu, Simon,
> Good to know!
>>>> old model.
>>>> Simon
>>>> xxlu wrote:
>>>>> Hi Ed,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> What should I do?
Re: [CDO/Teneo]Model update [message #425475 is a reply to message #425473] |
Thu, 27 November 2008 05:45 |
Xxlu,
Please notice that Martin Taal from the Teneo project developed a CDO
back-end integration based on Teneo.
So you might be able to enjoy the advantages of both CDO and Teneo.
Cheers
/Eike
xxlu schrieb:
> I experimentalize this with Teneo. I found Teneo can automatically
> update database by modified model. I think this feature is necessary. I
> should not migrate our database once my model modified. :(
> "Simon McDuff" <smcduff@hotmail.com> :
>>>> xxlu, Simon,
>>> Good to know!
>>>>>> model.
>>>>>> your databases...
>>>>>> Simon
>>>>>> xxlu wrote:
>>>>>>> Hi Ed,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> What should I do?
Cheers
/Eike
Re: [CDO]Model update [message #425497 is a reply to message #425496] |
Fri, 28 November 2008 07:39 |
Xxlu,
I've opened this bugzilla:
256856: Support model evolution
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256856
My comment 1 in this bugzilla explains a possible *manual* way to
migrate data instances after model evolution...
Cheers
/Eike
xxlu schrieb:
> Shoud I rebuild a database, then use ecore2ecore or other methods migrate my
> database? Any suggestion?
> "xxlu" <lu.xingxiao@gmail.com>
>> I want to know how can I migrate my databases. Thanks. :)
>>> model.
>>> your databases...
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Cheers
/Eike
Re: [CDO]Model update [message #425498 is a reply to message #425497] |
Fri, 28 November 2008 08:04 |
Xingxiao Lu Messages: 91 Registered: July 2009 |
Member |
Eike,
Thank you very much!
But I think it's impossible to migrate the objects in the same schema.
For example:
test.ecroe V1 and test.ecore V2 both have classA. When excute migration,
exception will be throwed:
org.eclipse.net4j.db.DBException: DBTable exists classA. :(
"Eike Stepper" <stepper@esc-net.de>
> Xxlu,
> My comment 1 in this bugzilla explains a possible *manual* way to migrate
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> my database? Any suggestion?
>>>> model.
>>>> your databases...
>>>> Simon
>>>> xxlu wrote:
>>>>> Hi Ed,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> What should I do?
Re: [CDO]Model update [message #425499 is a reply to message #425498] |
Fri, 28 November 2008 08:11 |
--------------010201080901010004000704
Xxlu,
Please try the following option in the cdo-server.xml (given, you're
using the DBStore!):
<cdoServer>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
_<property name="qualifiedNames" value="*true*"/>_
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
See also:
http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roperty_qualifiedNames
Cheers
/Eike
xxlu schrieb:
> Eike,
> For example:
>> Xxlu,
>> Cheers
>> /Eike
>>>>> model.
>>>>> your databases...
>>>>> Simon
>>>>> xxlu wrote:
>>>>>> Hi Ed,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> What should I do?
<html>
<head>
http-equiv="Content-Type">
</head>
Xxlu,<br>
<br>
using the DBStore!):<br>
<br>
<?xml version="1.0" encoding="UTF-8"?><br>
<cdoServer><br>
Cheers
/Eike
Re: [CDO]Model update [message #425501 is a reply to message #425499] |
Fri, 28 November 2008 09:55 |
Member |
------=_NextPart_000_014B_01C95182.73E9A4A0
charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
En...I think I must modify the EPackage's name.
"Eike Stepper" <stepper@esc-net.de>=20
Xxlu,
Please try the following option in the cdo-server.xml (given, you're =
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<cdoServer>
<repository name=3D"repo1">
<property name=3D"overrideUUID" =
value=3D"1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name=3D"supportingAudits" value=3D"true"/>
<property name=3D"verifyingRevisions" value=3D"false"/>
<property name=3D"currentLRUCapacity" value=3D"10000"/>
<property name=3D"revisedLRUCapacity" value=3D"100"/>
=20
<store type=3D"db">
<mappingStrategy type=3D"horizontal">
<property name=3D"qualifiedNames" value=3D"true"/>
<property name=3D"toManyReferences" =
value=3D"ONE_TABLE_PER_REFERENCE"/>
<property name=3D"toOneReferences" =
value=3D"LIKE_ATTRIBUTES"/>
</mappingStrategy>
See also: =
http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roperty_quali=
fiedNames
Cheers
/Eike
xxlu schrieb:=20
Eike,
But I think it's impossible to migrate the objects in the same =
schema.=20
For example:
test.ecroe V1 and test.ecore V2 both have classA. When excute =
migration,=20
Xxlu,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D256856
My comment 1 in this bugzilla explains a possible *manual* way to =
migrate=20
Cheers
/Eike
xxlu schrieb:
Shoud I rebuild a database, then use ecore2ecore or other methods =
migrate=20
Currently in CDO, a package with a given URI (X) should never be=20
If you follow this your objects will still be available using the old=20
model.
Does CDO should do more ? (Let me think about it during the night (it=20
Usually you will need to change the URI of your package.. and migrate=20
your databases...
Simon
xxlu wrote:
Hi Ed,
I have a problem that I can't resolve. I create a database for my=20
model with CDO2.0M3. When I update my model, for example, I add an=20
attribute for one class, I can't reload the old data from database.=20
java.lang.IllegalStateException: range.size() !=3D metaIDRange.size()
at=20
org.eclipse.emf.internal.cdo.CDOSessionImpl.registerEPackage (CDOSessionIm=
pl.java:544)
at=20
org.eclipse.emf.internal.cdo.util.CDOPackageRegistryImpl$Rem otePackageDes=
criptor.getEPackage(CDOPackageRegistryImpl.java:182)
at=20
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegis=
tryImpl.java:133)
at=20
org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.lo adPackage(CDO=
at=20
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loa d(CDOPackageI=
mpl.java:401)
at=20
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loo kupClass(CDOP=
at=20
org.eclipse.emf.cdo.internal.common.model.CDOClassRefImpl.re solve(CDOClas=
sRefImpl.java:71)
at=20
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO ClassRefAndRe=
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORe=
at=20
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO Revision(CDOD=
at=20
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(Load=
at=20
at=20
org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClie=
ntRequest.java:103)
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestW=
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithCon=
firmation.java:98)
at=20
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:3=
92)
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirma=
tion.java:82)
at=20
tion.java:73)
at=20
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.send(CDO RevisionManag=
erImpl.java:149)
at=20
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.loadRevi sion(CDORevis=
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getR=
at=20
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.getRevision(CDOView Impl.java:714=
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.createObject(CDOVie wImpl.java:85=
7)
at=20
at=20
org.eclipse.emf.internal.cdo.CDOTransactionImpl.getObject(CD OTransactionI=
mpl.java:449)
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.convertIDToObject(C DOViewImpl.ja=
va:1023)
at=20
at=20
org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreELis t.delegateGet=
at=20
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)=
at=20
org.eclipse.emf.common.util.DelegatingEList$EIterator.doNext (DelegatingEL=
ist.java:1075)
at=20
org.eclipse.emf.common.util.DelegatingEList$EIterator.next(D elegatingELis=
t.java:1062)
at=20
org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProvide=
rAdapter.java:340)
at=20
org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProvide=
rAdapter.java:310)
at=20
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElement=
What should I do?
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.6000.16735" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3D宋体 size=3D3>En...I think I must modify =
the EPackage's=20
name.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Eike Stepper" <<A=20
href=3D"mailto:stepper@esc-net.de">stepper@esc-net.de</A>>=20
</DIV>Xxlu,<BR><BR>Please try the following option in the =
cdo-server.xml=20
(given, you're using the DBStore!):<BR><BR><?xml version=3D"1.0"=20
encoding=3D"UTF-8"?><BR><cdoServer> <BR> =20
<repository name=3D"repo1"><BR> =
=20
<property name=3D"overrideUUID"=20
value=3D"1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/><BR > =
=20
<property name=3D"supportingAudits"=20
value=3D"true"/><BR> =
<property=20
name=3D"verifyingRevisions" value=3D"false"/><BR> =
<property name=3D"currentLRUCapacity"=20
value=3D"10000"/><BR> =
<property=20
name=3D"revisedLRUCapacity" value=3D"100"/><BR> =20
<BR> <store =
type=3D"db"><BR> =
=20
<mappingStrategy type=3D"horizontal"><BR> =20
<U><property=20
name=3D"qualifiedNames" =
value=3D"<B>true</B>"/></U><BR> =20
<property=20
name=3D"toManyReferences"=20
value=3D"ONE_TABLE_PER_REFERENCE"/><BR> =
=20
<property =
name=3D"toOneReferences"=20
value=3D"LIKE_ATTRIBUTES"/><BR> =
=20
</mappingStrategy><BR>[...]<BR><BR><BR>See =
also: <A=20
class=3Dmoz-txt-link-freetext=20
href=3D" http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roper=
ty_qualifiedNames">http://wiki.eclipse.org/CDO_Server_Configuration_Refer=
ence#Property_qualifiedNames</A><BR><BR>Cheers<BR>/Eike <BR><BR>----<BR><A=
=20
href=3D"http://thegordian.blogspot.com">http://thegordian.blogspot.com</A=
><BR><BR><BR><BR>xxlu=20
schrieb:=20
<BLOCKQUOTE cite=3Dmid:ggo8n5$cjf$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Eike,
schema.=20
For example:
migration,=20
"Eike Stepper" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:stepper@esc-net.de"><stepper@esc-net.de></A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Xxlu,
<A class=3Dmoz-txt-link-freetext =
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D256856">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D256856</A>
migrate=20
Cheers
/Eike
xxlu schrieb:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Shoud I rebuild a =
database, then use ecore2ecore or other methods migrate=20
"xxlu" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:lu.xingxiao@gmail.com"><lu.xingxiao@gmail.com></A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I want to know how can =
"Simon McDuff" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:smcduff@hotmail.com"><smcduff@hotmail.com></A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">At the moment CDO =
model.
your databases...
Simon
xxlu wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Ed,
at=20
pl.java:544)
at=20
at=20
tryImpl.java:133)
at=20
at=20
mpl.java:401)
at=20
at=20
sRefImpl.java:71)
at=20
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .<init>=
at=20
at=20
at=20
at=20
ntRequest.java:103)
at=20
at=20
firmation.java:98)
at=20
92)
at=20
tion.java:82)
at=20
tion.java:73)
at=20
erImpl.java:149)
at=20
at=20
at=20
at=20
at=20
7)
at=20
at=20
mpl.java:449)
at=20
va:1023)
at=20
at=20
at=20
at=20
ist.java:1075)
at=20
t.java:1062)
at=20
rAdapter.java:340)
at=20
rAdapter.java:310)
at=20
What should I do?
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_014B_01C95182.73E9A4A0--
Current Time: Sat Apr 20 01:03:47 GMT 2024
Powered by FUDForum. Page generated in 0.04357 seconds
