Home » Modeling » EMF » [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALUE, &
Re: [Teneo - Spring] No property 'ePackageClasses' found [message #425363 is a reply to message #425291] |
Sat, 22 November 2008 16:27 |
Hi Ole,
No other thoughts then that I have noticed with Hibernate also a similar thing (as I remember it),
apparently the second upper-cased character (the P) gives confusion.
gr. Martin
Ole Ersoy wrote:
> I'm trying out Teneo with Spring. I noticed that using ePackageClasses
> to set the ePackages does not work, but if I change the property name to
> EPackageClasses it does.
> Anyone know if this is a Spring bug? I looked at the method:
> public void setEPackageClasses(java.util.List<String>
> ePackageClasses) {
> if (ePackageConstructor == null) {
> ePackageConstructor = new EPackageConstructor();
> ePackageConstructor.setModelClasses(ePackageClasses);
> It looks fine. I also tried a simpler mockup version of setting a
> property via setter injection, when the property is not present on the
> class, and it works.
> Thoughts?
> - Ole
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652707 is a reply to message #425176] |
Sat, 05 February 2011 18:10 |
David Wynter Messages: 4624 Registered: July 2009 |
Hi Martin,
Not sure what is happening here, as I followed your advice over 2years
ago and I seem to remember it working.
Using org.eclipse.emf.teneo.hibernate 1.1.1
I use
<xsd:simpleType name="javaDateTime"
ecore:instanceClass="java.sql.TimeStamp">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Temporal(TIMESTAMP)</xsd:appinfo>
</xsd:annotation>
<xsd:restriction base="xsd:dateTime">
</xsd:restriction>
</xsd:simpleType>
and
<xsd:complexType name="CleansingException">
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id
@GeneratedValue(strategy=IDENTITY)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name="timeReported" type="datamanager:javaDateTime" />
</xsd:complexType>
<xsd:element name="cleansingException"
type="datamanager:CleansingException"/>
and yet I get the following after reloading genmodel, regenerating the
code and running my HibernateUtil.
2011-02-0518:01:15.321 GMT+0000 21354 [main] ERROR org.mortbay.log -
failed HibernateSessionRequestFilter
org.hibernate.HibernateException: Wrong column type in
DMANAGER.PUBLIC.cleansingexception for column timereported. Found:
timestamp, expected: date
at org.hibernate.mapping.Table.validateColumns(Table.java:284)
at org.hibernate.cfg.Configuration.validateSchema(Configuration .java:1130)
at
org.hibernate.tool.hbm2ddl.SchemaValidator.validate(SchemaVa lidator.java:139)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:359)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:218)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:93)
at
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:74)
at com.example.something.HibernateUtil.init(HibernateUtil.java: 94)
I only need millisecond precision but it is not clear how you get a
timestamp column type from annotations, any examples? So I tried the
full timestamp route and it failed. Any ideas?
Thx,
David
On 18/11/08 09:58, Martin Taal wrote:
> Hi David,
> For many cases the java.util.Date works fine (as it is detailed to the
> millis level).
> If you want TimeStamp then you need to introduce a simpleType for
> timestamp with the specific java.sql.TimeStamp instanceclass. You can
> also place the annotation in the timestamp simpletype, then you don't
> need to repeat it every time in the xsd:
> <xsd:simpleType name="javaTimeStamp"
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:restriction>
> </xsd:simpleType>
> and then use this datatype (without annotation):
> <xsd:attribute name="snapTime" type="gensec:javaTimeStamp"/>
> gr. Martin
> David Wynter wrote:
>> Hi,
>> I have a set of columns that I need to be timestamps. So I use this
>> <xsd:simpleType name="javaDate" ecore:instanceClass="java.util.Date">
>> </xsd:restriction>
>> </xsd:simpleType>
>> <xsd:attribute name="snapTime" type="gensec:javaDate" >
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> The hibernate.hbm.xml shows this
>> <property name="snapTime" lazy="false" insert="true" update="true"
>> not-null="false" unique="false" type="timestamp">
>> <column not-null="false" unique="false" name="`snaptime`"/>
>> </property>
>> But the schema generated creates Date columns, not Timestamp?
>> Thx.
>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652708 is a reply to message #652707] |
Sat, 05 February 2011 18:36 |
On 05/02/11 18:10, David Wynter wrote:
> Hi Martin,
> I use
> <xsd:annotation>
> </xsd:annotation>
> </xsd:restriction>
> </xsd:simpleType>
> and
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> at
> at
> at
> at
> at
> at
> Thx,
> David
>> Hi David,
>> millis level).
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> </xsd:restriction>
>> </xsd:simpleType>
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </property>
>>> Thx.
>>> David
I also tried this
<xsd:attribute name="attemptDate" type="xsd:dateTime">
<xsd:annotation>
<xsd:appinfo
</xsd:annotation>
</xsd:attribute>
with the same results.
So am unable to use a millisecond precision.
David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652749 is a reply to message #652708] |
Sun, 06 February 2011 09:48 |
Hi David,
How does the generated hbm look like? (datastore.getMappingXML())
You are not using a fixed hbm file are you (so the hbm is generated in-memory)?
gr. Martin
>> Hi Martin,
>> I use
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:restriction>
>> </xsd:simpleType>
>> and
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> at
>> at
>> at
>> at
>> at
>> at
>> Thx,
>> David
>>> Hi David,
>>> millis level).
>>> <xsd:annotation>
>>> <xsd:appinfo
>>> </xsd:annotation>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </property>
>>>> Thx.
>>>> David
> I also tried this
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652752 is a reply to message #652749] |
Sun, 06 February 2011 11:05 |
I thought I'd try the 1.2.0 version of Teneo before I got your reply. So
updated EMF to 2.6.0 and Teneo to 1.2.0, and the dependencies you
provide but when I try to add V1.2.0 as a dependent plugin, it does not
appear, V1.1.2 does. I have org.eclipse.emf.ecore selected as V2.6.0.
V1.2.0 of Teneo hibernate does appear in the installation dialog for
Eclipse 3.6.
What else do I need to do to update?
I'll downgrade back to EMF V2.5.0 and get the hbm detail.
Thx.
David
On 06/02/11 09:48, Martin Taal wrote:
> Hi David,
> in-memory)?
> gr. Martin
>>> Hi Martin,
>>> I use
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> and
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thx,
>>> David
>>>> Hi David,
>>>> millis level).
>>>> <xsd:annotation>
>>>> <xsd:appinfo
>>>> </xsd:annotation>
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </property>
>>>>> Thx.
>>>>> David
>> I also tried this
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652758 is a reply to message #652752] |
Sun, 06 February 2011 12:26 |
Yes you can take v1.1.2 in this case.
gr. Martin
On 02/06/2011 12:05 PM, David Wynter wrote:
> I thought I'd try the 1.2.0 version of Teneo before I got your reply. So updated EMF to 2.6.0 and Teneo to 1.2.0, and
> the dependencies you provide but when I try to add V1.2.0 as a dependent plugin, it does not appear, V1.1.2 does. I have
> org.eclipse.emf.ecore selected as V2.6.0. V1.2.0 of Teneo hibernate does appear in the installation dialog for Eclipse 3.6.
> Thx.
> David
>> Hi David,
>> in-memory)?
>> gr. Martin
>>>> Hi Martin,
>>>> I use
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> and
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thx,
>>>> David
>>>>> Hi David,
>>>>> millis level).
>>>>> <xsd:annotation>
>>>>> <xsd:appinfo
>>>>> </xsd:annotation>
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </property>
>>>>>> Thx.
>>>>>> David
>>> I also tried this
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652847 is a reply to message #652758] |
Mon, 07 February 2011 11:02 |
Sadly, Eclipse delivers the usual DLL hell. I uninstalled EMF 2.6.0 and
it will not allow me to install EMF V2.5.0 due to other borken
dependencies now, several of them. I have learnt from experience it is
better to scrap this Eclipse install rather than spend days trying to
sort out the DLL hell that is Eclipse whenever you don't use a complete
installation.
I assume I could not see the Teneo V1.2.0 ias an available dependency
because some versioning in the plugin manifest is wrong?
David
> gr. Martin
>> Hi,
>> Thx.
>> David
>>> Hi David,
>>> in-memory)?
>>> gr. Martin
>>>>> Hi Martin,
>>>>> I use
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> and
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx,
>>>>> David
>>>>>> Hi David,
>>>>>> the
>>>>>> millis level).
>>>>>> <xsd:annotation>
>>>>>> <xsd:appinfo
>>>>>> </xsd:annotation>
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </xsd:restriction>
>>>>>>> </xsd:simpleType>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </property>
>>>>>>> Thx.
>>>>>>> David
>>>> I also tried this
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652849 is a reply to message #652847] |
Mon, 07 February 2011 11:15 |
It is different, the Teneo 1.2.0 version contains plugins at 1.1.2, that's all.
gr. Martin
On 02/07/2011 12:02 PM, David Wynter wrote:
> Sadly, Eclipse delivers the usual DLL hell. I uninstalled EMF 2.6.0 and it will not allow me to install EMF V2.5.0 due
> to other borken dependencies now, several of them. I have learnt from experience it is better to scrap this Eclipse
> install rather than spend days trying to sort out the DLL hell that is Eclipse whenever you don't use a complete
> installation.
> I assume I could not see the Teneo V1.2.0 ias an available dependency because some versioning in the plugin manifest is
> wrong?
> David
>> gr. Martin
>>> Hi,
>>> Thx.
>>> David
>>>> Hi David,
>>>> in-memory)?
>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> I use
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> and
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thx,
>>>>>> David
>>>>>>> Hi David,
>>>>>>> the
>>>>>>> millis level).
>>>>>>> <xsd:annotation>
>>>>>>> <xsd:appinfo
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:restriction>
>>>>>>> </xsd:simpleType>
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> </xsd:restriction>
>>>>>>>> </xsd:simpleType>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </property>
>>>>>>>> Thx.
>>>>>>>> David
>>>>> I also tried this
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652862 is a reply to message #652849] |
Mon, 07 February 2011 12:34 |
Ok, Finally got there with V1.2.0 (or V1.1.2?)
To have it all in one place, here is the annotation in the XSD
<xsd:annotation>
<xsd:appinfo
source="teneo.jpa">@TemporalType(TIMESTAMP)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
Here is the mapping, which show type="date" for the above
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="com.example.application.impl.ChangeAttemptImpl"
entity-name="ChangeAttempt" abstract="false" lazy="false"
table="`changeattempt`">
<meta attribute="eclassName" inherit="false">ChangeAttempt</meta>
<meta attribute="epackage"
inherit="false">http://www.example.com/application</meta>
<id name="id" type="int" unsaved-value="0">
<column not-null="true" unique="false" name="`id`"/>
<generator class="identity"/>
</id>
<property name="attemptDate" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="date">
<column not-null="false" unique="false" name="`attemptdate`"/>
</property>
<property name="changeSource" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`changesource`"/>
</property>
<property name="changeValue" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`changevalue`"/>
</property>
<many-to-one name="userProtectedValues"
entity-name="UserProtectedValues" lazy="false"
cascade="merge,persist,save-update,lock,refresh"
foreign-key="chngeattempt_serprtectedvles" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`userprotectedvalues`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.CleansingExceptionImpl"
entity-name="CleansingException" abstract="false" lazy="false"
table="`cleansingexception`">
<meta attribute="eclassName" inherit="false">CleansingException</meta>
</id>
<bag name="exceptionValue" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="clensingexceptin_exceptinvle">
<column name="`exceptionid`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="ExceptionValue"/>
</bag>
<property name="description" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`description`"/>
</property>
<property name="destFieldId" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`destfieldid`"/>
</property>
<property name="endDate" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`enddate`"/>
</property>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<property name="ownerId" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`ownerid`"/>
</property>
<property name="timeReported" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`timereported`"/>
</property>
<many-to-one name="exceptionType" entity-name="ExceptionType"
lazy="false" cascade="merge,persist,save-update,lock,refresh"
foreign-key="clnsingexceptin_exceptintype" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`exceptiontype`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.ExceptionTypeImpl"
entity-name="ExceptionType" abstract="false" lazy="false"
table="`exceptiontype`">
<meta attribute="eclassName" inherit="false">ExceptionType</meta>
</id>
<bag name="cleansingException" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="excptintype_clensingexceptin">
<column name="`typeid`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="CleansingException"/>
</bag>
</property>
</property>
<property name="typeOwnerId" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`typeownerid`"/>
</property>
<property name="validFrom" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`validfrom`"/>
</property>
<property name="validTo" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`validto`"/>
</property>
</class>
<class name="com.example.application.impl.ExceptionValueImpl"
entity-name="ExceptionValue" abstract="false" lazy="false"
table="`exceptionvalue`">
<meta attribute="eclassName" inherit="false">ExceptionValue</meta>
</id>
<bag name="userProtectedValues" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="exceptinvle_serprtectedvales">
<column name="`exceptionvalue`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="UserProtectedValues"/>
</bag>
<property name="partOfPK" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="boolean">
<column not-null="false" unique="false" name="`partofpk`"/>
</property>
<property name="replacementValue" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`replacementvalue`"/>
</property>
<property name="sourceFieldId" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`sourcefieldid`"/>
</property>
<property name="sourceTag" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`sourcetag`"/>
</property>
<property name="sourceValue" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`sourcevalue`"/>
</property>
<property name="timeRepaired" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`timerepaired`"/>
</property>
<many-to-one name="cleansingException"
entity-name="CleansingException" lazy="false"
foreign-key="exceptinvle_clensingexceptin" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`cleansingexception`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.UserProtectedValuesImpl"
entity-name="UserProtectedValues" abstract="false" lazy="false"
table="`userprotectedvalues`">
<meta attribute="eclassName" inherit="false">UserProtectedValues</meta>
</id>
<bag name="changeAttempt" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="userprtectedvles_chngettempt">
<column name="`userprotectedvalues`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="ChangeAttempt"/>
</bag>
<property name="columnName" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`columnname`"/>
</property>
<property name="correctionValue" lazy="false" insert="true"
<column not-null="false" unique="false" name="`correctionvalue`"/>
</property>
</property>
<property name="pkCol1Name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol1name`"/>
</property>
<property name="pkCol1Value" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol1value`"/>
</property>
<property name="pkCol2Name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol2name`"/>
</property>
<property name="pkCol2Value" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol2value`"/>
</property>
<property name="pkCol3Name" la...
Thx.
David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652889 is a reply to message #652862] |
Mon, 07 February 2011 13:17 |
Found the problem. This line of code not only makes the default Date but
also overrides any annotations for timestamp
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE,
"DATE");
I thought it would be the other way around, that the annotation
over-rode the default.
Thx.
David
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">@TemporalType(TIMESTAMP)</xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </id>
> </property>
> </property>
> </property>
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> <property name="sourceFieldId" lazy="false" insert="true" update="true"
> </property>
> </property>
> </property>
> </property>
> <many-to-one name="cleansingException" entity-name="CleansingException"
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> Thx.
> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652901 is a reply to message #652889] |
Mon, 07 February 2011 13:23 |
Hi David,
Indeed incorrect... Can you enter a bugzilla for this?
gr. Martin
On 02/07/2011 02:17 PM, David Wynter wrote:
> Found the problem. This line of code not only makes the default Date but also overrides any annotations for timestamp
> props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE, "DATE");
> I thought it would be the other way around, that the annotation over-rode the default.
> Thx.
> David
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> <?xml version="1.0" encoding="UTF-8"?>
>> </id>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> Thx.
>> David
The Netherlands
Current Time: Thu Apr 25 05:59:08 GMT 2024
Powered by FUDForum. Page generated in 0.05055 seconds
