Home » Modeling » EMF » HibernateResource vs XmiResourceImpl performances ?
HibernateResource vs XmiResourceImpl performances ? [message #425073] |
Fri, 14 November 2008 14:28 |
Stephane fournier Messages: 340 Registered: July 2009 |
Testing Teneo, I've made some performances comparisons against a standard
XmiResource.
Scenario : I'm using the ExtendedLibrary meta-model. I have initialized a
mysql database (installed on my computer) with a library with 10 000
children : sub-libraries, books, writers, employees...
As a library can be contained by another library, Library meta-class is
not considered as a top class by Teneo.
So, loading my resource gives me an empty resource content. I query the
database to retrieve my root library (I tried to load the resource from an
uri that specifies the initial query, but the open editor is in read-only).
Some figures :
Empty resource loaded in : 11012ms
Root Library retrieved in : 16ms
Root library added in the empty resource : 15225ms.
I doesn't understand why it's so long to add the root library in the
HibernateResource.
Does anyone have an idea ?
I've made some additional tests against XmiResource.
If I add a sub-tree with 10 000 children to a library already contained in
a resource, it took 1s.
If I add a sub-tree with 10 000 children to a temporary library not
attached to a resource yet, it took 200ms + 63ms to attach the temporary
library to a library contained in a resource.
Does anyone have an idea to explain the performance differences ?
I export the database content as a xml file.
Export resource loaded in : 736ms
Retrieving the root library in the database is straight forward (16ms),
the library children are resolved (checked with the debugger just before
adding the root library to the resource content).
What is the Teneo option to avoid library children auto resolution when
querying for it.
I would like to perform the children resolution when expanding the
TreeItem only. (I set containment proxy to true in the genmodel). I tested
PersistenceOptions.SET_PROXY but I didn't speed up resource loading.
Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425075 is a reply to message #425073] |
Fri, 14 November 2008 14:35 |
Ed Merks Messages: 33140 Registered: July 2009 |
Stéphane,
Comments below.
Stéphane Fournier wrote:
> standard XmiResource.
> initialized a mysql database (installed on my computer) with a library
> with 10 000 children : sub-libraries, books, writers, employees...
> is not considered as a top class by Teneo. So, loading my resource
> gives me an empty resource content. I query the database to retrieve
> my root library (I tried to load the resource from an uri that
> Some figures :
> HibernateResource.
> contained in a resource, it took 1s.
> temporary library to a library contained in a resource.
How much work does ResourceImpl.attached doing? Is it walking the whole
tree and computing UUIDs or something like that?
> (16ms), the library children are resolved (checked with the debugger
> just before adding the root library to the resource content).
> when querying for it.
> tested PersistenceOptions.SET_PROXY but I didn't speed up resource
> loading.
> Stephane.
Ed Merks
Re: HibernateResource vs XmiResourceImpl performances ? [message #425122 is a reply to message #425075] |
Fri, 14 November 2008 15:06 |
Ed Merks wrote:
> Stéphane,
> Comments below.
>> Hi,
>> Some figures :
>> HibernateResource.
I'm not using UUIDs, I use the default behavior based on positions.
When I add 10 000 children to library contained in a resource,
ResourceImpl.attached is called for each object but that code is never
executed :
for (TreeIterator<EObject> tree = getAllProperContents(eObject);
tree.hasNext(); )
attachedHelper(tree.next());
When adding a sub tree containing 10 000 objects to a not attached
library, the ResourceImpl.attached is called once when the temporary lib
is added to a resource contained one but the this time, the TreeIterator
is walked to attach every contained objects.
>> loading.
>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425123 is a reply to message #425122] |
Fri, 14 November 2008 15:17 |
Stéphane,
So the tree walk is the answer. Can you tell why it's needing to walk
the tree? It's guarded such that the tree walk is avoided in most cases...
> Ed Merks wrote:
>> Stéphane,
>> Comments below.
>>> Hi,
>>> library with 10 000 children : sub-libraries, books, writers,
>>> employees...
>>> Some figures :
>>> HibernateResource.
>> whole tree and computing UUIDs or something like that?
> executed :
> tree.hasNext(); )
> lib is added to a resource contained one but the this time, the
> TreeIterator is walked to attach every contained objects.
>>> loading.
>>> Stephane.
Ed Merks
Re: HibernateResource vs XmiResourceImpl performances ? [message #425126 is a reply to message #425123] |
Fri, 14 November 2008 15:41 |
Ed Merks wrote:
> Stéphane,
Here is my analysis :
The tree is walked (on the added sub tree) because when I add a temp lib
with a sub tree containing my 10 000 children, no one is attached to a
resource.
When adding the temp lib in a lib attached to a resource, the
EObjectContainmentWithInverseEList.Resolving#add calls the opposite
relation i.e setParentBranch(..) that calls eBasicSetContainer(..) that
calls ResourceImpl.attached(..).
ResourceImpl.getAllProperContents returns the added sub tree objects that
are not attached to the parent library resource yet.
Nevertheless, my tests show that's worth calling once
ResourceImpl.attached() with a tree walk on children rather than calling x
times this methods without tree walk.
>> Ed Merks wrote:
>>> Stéphane,
>>> Comments below.
>>>> Hi,
>>>> employees...
>>>> Some figures :
>>>> HibernateResource.
>> executed :
>> tree.hasNext(); )
>>>> loading.
>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425130 is a reply to message #425129] |
Fri, 14 November 2008 16:19 |
because in
protected boolean isAttachedDetachedHelperRequired()
return useIDs() || super.isAttachedDetachedHelperRequired();
useIDs() always returns true in XmlResourceImpl. In the genmodel,
ResourceType is set to NONE.
Ed Merks wrote:
> Stéphane,
> Sorry my point is it's guarded like this:
> public void attached(EObject eObject)
> if (isAttachedDetachedHelperRequired())
> attachedHelper(eObject);
> getAllProperContents(eObject); tree.hasNext(); )
> protected boolean useIDs()
> return eObjectToIDMap != null || idToEObjectMap != null || useUUIDs();
> protected boolean useIDAttributes()
> return true;
> protected boolean useUUIDs()
> return false;
> return isTrackingModification() || getIntrinsicIDToEObjectMap() != null;
> So generally I would expect the guard to return false by default. So
> I'm wondering why it's returning true.
>> Ed Merks wrote:
>>> Stéphane,
>>> walk the tree? It's guarded such that the tree walk is avoided in
>>> most cases...
>> lib with a sub tree containing my 10 000 children, no one is attached
>> to a resource.
>> that calls ResourceImpl.attached(..).
>> that are not attached to the parent library resource yet.
>> calling x times this methods without tree walk.
>>>> Ed Merks wrote:
>>>>> Stéphane,
>>>>> Comments below.
>>>>>> Hi,
>>>>>> employees...
>>>>>> meta-class is not considered as a top class by Teneo. So, loading
>>>>>> from an uri that specifies the initial query, but the open editor
>>>>>> is in read-only).
>>>>>> Some figures :
>>>>>> the HibernateResource.
>>>>>> not attached to a resource yet, it took 200ms + 63ms to attach the
>>>> never executed :
>>>> tree.hasNext(); )
>>>>>> debugger just before adding the root library to the resource
>>>>>> content).
>>>>>> I tested PersistenceOptions.SET_PROXY but I didn't speed up
>>>>>> resource loading.
>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425131 is a reply to message #425130] |
Fri, 14 November 2008 16:27 |
Stéphane,
The assumption being that XMI resources will generally use xmi:id which
in strict conformance to the XMI specification is required. In any
case, this is clearly something you can specialize. I.e., you might
just use XMLResourceImpl instead...
> because in
> Ed Merks wrote:
>> Stéphane,
>> useUUIDs();
>> return true;
>> return false;
>> != null;
>>> Ed Merks wrote:
>>>> Stéphane,
>>>> most cases...
>>> attached to a resource.
>>>>> Ed Merks wrote:
>>>>>> Stéphane,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>>> employees...
>>>>>>> the database to retrieve my root library (I tried to load the
>>>>>>> resource from an uri that specifies the initial query, but the
>>>>>>> Some figures :
>>>>>>> the temporary library to a library contained in a resource.
>>>>>> the whole tree and computing UUIDs or something like that?
>>>>> never executed :
>>>>> tree.hasNext(); )
>>>>> temporary lib is added to a resource contained one but the this
>>>>> time, the TreeIterator is walked to attach every contained objects.
>>>>>>> content).
>>>>>>> resolution when querying for it.
>>>>>>> the TreeItem only. (I set containment proxy to true in the
>>>>>>> genmodel). I tested PersistenceOptions.SET_PROXY but I didn't
>>>>>>> Stephane.
Ed Merks
Re: HibernateResource vs XmiResourceImpl performances ? [message #425132 is a reply to message #425131] |
Fri, 14 November 2008 17:16 |
Ed Merks wrote:
> Stéphane,
I've made the change, now the guard does its job i.e the code in the guard
block is never executed.
I've ran my tests again, it does not change a lot the overall performances.
Creating a sub tree and adding it at creation end to a library attached to
a resource is always the fastest way.
Nevertheless, performances with standard resources either XMI or XML are
great to me :)
My issue is regarding HibernateResource. I do hope that Martin could give
a hint to improve that !
Stephane.
>> because in
>> Ed Merks wrote:
>>> Stéphane,
>>> useUUIDs();
>>> return true;
>>> return false;
>>> != null;
>>>> Ed Merks wrote:
>>>>> Stéphane,
>>>>> most cases...
>>>>>> Ed Merks wrote:
>>>>>>> Stéphane,
>>>>>>> Comments below.
>>>>>>>> Hi,
>>>>>>>> employees...
>>>>>>>> Some figures :
>>>>>> never executed :
>>>>>> tree.hasNext(); )
>>>>>>>> content).
>>>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425134 is a reply to message #425132] |
Fri, 14 November 2008 21:43 |
Hi Stephane,
The use case is not completely clear for me yet. I understand this:
1) you create a HibernateResource and load it, it remains empty
2) you use a separate hibernate session to read a library from the db and add it to the hibernate
resource?
Then you have two scenarios:
A- read a library and add it to the resource, then read a second library (with the 10000 children)
and add it to the library which is already present in the resource?, or
B- read a library (with the 10000 children) from the db and add it to the resource directly
or did I miss anything?
In which scenario do you see which tree-walking behavior?
gr. Martin
> Ed Merks wrote:
>> Stéphane,
>> which in strict conformance to the XMI specification is required. In
>> any case, this is clearly something you can specialize. I.e., you
>> might just use XMLResourceImpl instead...
> guard block is never executed.
> to a resource is always the fastest way.
> great to me :)
> give a hint to improve that !
> Stephane.
>>> because in
>>> Ed Merks wrote:
>>>> Stéphane,
>>>> useUUIDs();
>>>> return true;
>>>> return false;
>>>> != null;
>>>> So I'm wondering why it's returning true.
>>>>> Ed Merks wrote:
>>>>>> Stéphane,
>>>>>> most cases...
>>>>> temp lib with a sub tree containing my 10 000 children, no one is
>>>>> objects that are not attached to the parent library resource yet.
>>>>>>> Ed Merks wrote:
>>>>>>>> Stéphane,
>>>>>>>> Comments below.
>>>>>>>>> Hi,
>>>>>>>>> a standard XmiResource.
>>>>>>>>> employees...
>>>>>>>>> Some figures :
>>>>>>>>> in the HibernateResource.
>>>>>>> never executed :
>>>>>>> tree.hasNext(); )
>>>>>>> attached library, the ResourceImpl.attached is called once when
>>>>>>> the temporary lib is added to a resource contained one but the
>>>>>>> this time, the TreeIterator is walked to attach every contained
>>>>>>> objects.
>>>>>>>>> content).
>>>>>>>>> Stephane.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: HibernateResource vs XmiResourceImpl performances ? [message #425139 is a reply to message #425134] |
Sat, 15 November 2008 17:53 |
Hi Martin,
1st scenario :
1) I create a HibernateResource that remains empty due to my meta-model
(ExtendedLibrary). I have no top class because a Library can contain
another one.
The elapsed time to load my empty HibernateResource is long from my
point of view : 11s more or less.
2) On the SessionWrapper provided by the loaded resource, I open a
transaction.
I query the db to find my root library (the db contains a root library
with 10 000 children).
The query is really fast to retrieve the library : 16ms.
3) Then, I add this root library to the empty loaded HibernateResource
content.
It took 15s more or less. It's long because all library children objects
are already resolved (checked with the debugger). I haven't understood
where time is wasted.
4) I close the transaction.
5)My editor finishes to open with this resource.
2nd scenario (the editor is open with the root library ant its 10 000
children):
1) I select a library either a child of the root one or the root one itself.
2) I create 10 000 children on the selected library.
3) I save the HibernateResource.
As performances were not good (for me), I made some tests with standard
EMF resources to have an idea of standard performances with XML files.
In doing theses tests with XML resources, I got better performances if I
create objects as children of an object not attached to a resource. At
the end, I add the not attached object to an object contained in a resource.
Ed and I discussed this point in this post.
Stephane.
Martin Taal wrote:
> Hi Stephane,
> and add it to the hibernate resource?
> (with the 10000 children) and add it to the library which is already
> gr. Martin
>> Ed Merks wrote:
>>> Stéphane,
>> performances.
>> attached to a resource is always the fastest way.
>> are great to me :)
>> Stephane.
>>>> because in
>>>> Ed Merks wrote:
>>>>> Stéphane,
>>>>> useUUIDs();
>>>>> return true;
>>>>> return false;
>>>>> != null;
>>>>>> Ed Merks wrote:
>>>>>>> Stéphane,
>>>>>>> to walk the tree? It's guarded such that the tree walk is
>>>>>> opposite relation i.e setParentBranch(..) that calls
>>>>>> eBasicSetContainer(..) that calls ResourceImpl.attached(..).
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Stéphane,
>>>>>>>>> Comments below.
>>>>>>>>>> Hi,
>>>>>>>>>> employees...
>>>>>>>>>> query the database to retrieve my root library (I tried to
>>>>>>>>>> load the resource from an uri that specifies the initial
>>>>>>>>>> Some figures :
>>>>>>>>>> library not attached to a resource yet, it took 200ms + 63ms
>>>>>>>>>> to attach the temporary library to a library contained in a
>>>>>>>>>> resource.
>>>>>>>> never executed :
>>>>>>>> tree.hasNext(); )
>>>>>>>> objects.
>>>>>>>>>> forward (16ms), the library children are resolved (checked
>>>>>>>>>> with the debugger just before adding the root library to the
>>>>>>>>>> resource content).
>>>>>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425161 is a reply to message #425139] |
Mon, 17 November 2008 20:19 |
Hi Stéphane,
See questions inline.
gr. Martin
> Hi Martin,
> 1st scenario :
> another one.
MT>> This is long indeed, can you enable hibernate logging (using log4j) to see what hibernate is doing?
> transaction.
MT>> Yes probably only one record is read
> content.
MT>> You mean it takes long because the 10000 children are read from the db? I would be surprised
that the children are read in step 2 (depends on your cascading options) in the 16ms.
Maybe the collection of children contains proxy objects, which are resolved?
> children):
> itself.
MT>> And what performance do you get here?
> resource.
> Stephane.
> Martin Taal wrote:
>> Hi Stephane,
>> library (with the 10000 children) and add it to the library which is
>> gr. Martin
>>> Ed Merks wrote:
>>>> Stéphane,
>>>> In any case, this is clearly something you can specialize. I.e.,
>>>> you might just use XMLResourceImpl instead...
>>> performances.
>>> are great to me :)
>>> Stephane.
>>>>> because in
>>>>> Ed Merks wrote:
>>>>>> Stéphane,
>>>>>> useUUIDs();
>>>>>> return true;
>>>>>> return false;
>>>>>>> Ed Merks wrote:
>>>>>>>> Stéphane,
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Stéphane,
>>>>>>>>>> Comments below.
>>>>>>>>>>> Hi,
>>>>>>>>>>> against a standard XmiResource.
>>>>>>>>>>> a library with 10 000 children : sub-libraries, books,
>>>>>>>>>>> Some figures :
>>>>>>>>>>> resource.
>>>>>>>>>>> differences ?
>>>>>>>>> positions.
>>>>>>>>> is never executed :
>>>>>>>>> objects.
>>>>>>>>>>> resource content).
>>>>>>>>>>> expanding the TreeItem only. (I set containment proxy to true
>>>>>>>>>>> in the genmodel). I tested PersistenceOptions.SET_PROXY but I
>>>>>>>>>>> Stephane.
The Netherlands
Re: HibernateResource vs XmiResourceImpl performances ? [message #425177 is a reply to message #425161] |
Tue, 18 November 2008 12:30 |
Martin Taal wrote:
> Hi Stéphane,
> gr. Martin
>> Hi Martin,
>> 1st scenario :
>> another one.
SF :
Hibernate is loading data "from Person" query due to
loadUsingTopClasses(SessionWrapper) call. Indeed, Person is the only one
top class in the ExtendedLibrary meta-model. Writer extends Person thus,
writers are loaded, and I think objects involved in Writer relationships
are loaded too. Hence, that loads the entire model.
I didn't use a file input uri with a query inside, because such an uri
gives an open editor in read-only i.e contextual menu items provided by
Edit are grayed.
I do not want to modify my Editing domain to fix that.
I have overridden the HibernateResource to change the loadFromStore method
to use a query that suits my needs i.e retrieving my root library.
Now, the resource is loaded in :
first time : 30s.
second time (editor closed and re-open): 22s.
third time (editor closed and re-open) : 30s.
fourth time (editor closed and re-open) : 30s
All root library children are loaded, I use the default
CASCADE_POLICY_ON_CONTAINMENT option. Which are the option values to
select to get children loaded when I will expand the related TreeItem
only? I'm a bit lost with MERGE, PERSIST, REFRESH, REMOVE values.
>> transaction.
SF : I agree with that.
>> content.
the 16ms.
SF: How do I recognize resolved proxy objects against resolved ones ?
I would like to get a behavior closed to the EMF one when using proxy
containment set to true.
>> children):
>> itself.
SF: 6 to 7s to create objects directly added to a library contained in the
HibernateResource and 43s to save the resource with these 10 000 objects
added.
It is faster to create objects attached to standard resources (XMI, XMl)
than the hibernate one.
What performance do you expect ?
>> resource.
>> Stephane.
>> Martin Taal wrote:
>>> Hi Stephane,
>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Stéphane,
>>>> performances.
>>>> are great to me :)
>>>> Stephane.
>>>>>> because in
>>>>>> Ed Merks wrote:
>>>>>>> Stéphane,
>>>>>>> useUUIDs();
>>>>>>> return true;
>>>>>>> return false;
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Stéphane,
>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> Stéphane,
>>>>>>>>>>> Comments below.
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> Some figures :
>>>>>>>>>>>> resource.
>>>>>>>>>>>> differences ?
>>>>>>>>>> positions.
>>>>>>>>>> is never executed :
>>>>>>>>>> objects.
>>>>>>>>>>>> resource content).
>>>>>>>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425178 is a reply to message #425177] |
Tue, 18 November 2008 13:34 |
Hi Stéphane,
The hibernate resource will be significantly slower than the xml/xmi store. On a standard
development system with mysql you can count on inserting 1-2000 records per second. This without
optimizing the db.
Hibernate is able to persist complex object graphs. To do this often multiple statements are used to
persist one object. For example what can happen in hibernate is that first an object is inserted in
the db with all foreign keys set to null. At that point all id's are known. Then update statements
are used to update the assocation between two objects.
The cascade option does not influence loading behavior, but persist/save behavior.
You can set the option PersistenceOptions.SET_PROXY to true. This will enable hibernate proxying and
make many-to-one relations lazy.
Regarding the load of the resource, it takes far too long. I guess everything is loaded because of
some traversal through the object graph which loads collections which should not be loaded. I think
this what you discussed with Ed. I did not completely follow that discussion. Can you check this and
summarize the behavior you see for me?
gr. Martin
> Martin Taal wrote:
>> Hi Stéphane,
>> gr. Martin
>>> Hi Martin,
>>> 1st scenario :
>>> meta-model (ExtendedLibrary). I have no top class because a Library
>>> can contain another one.
>> log4j) to
> SF : Hibernate is loading data "from Person" query due to
> Edit are grayed.
> method to use a query that suits my needs i.e retrieving my root library.
> first time : 30s.
>>> transaction.
>>> library with 10 000 children).
>>> HibernateResource content.
>>> objects are already resolved (checked with the debugger). I haven't
>>> understood where time is wasted.
>> the db?
>> options) in
> the 16ms.
>> resolved?
>>> children):
>>> itself.
> the HibernateResource and 43s to save the resource with these 10 000
> objects added.
>>> standard EMF resources to have an idea of standard performances with
>>> XML files.
>>> if I create objects as children of an object not attached to a
>>> resource. At the end, I add the not attached object to an object
>>> Stephane.
>>> Martin Taal wrote:
>>>> Hi Stephane,
>>>> db and add it to the hibernate resource?
>>>> gr. Martin
>>>>> Ed Merks wrote:
>>>>>> Stéphane,
>>>>> the guard block is never executed.
>>>>> performances.
>>>>> XML are great to me :)
>>>>> could give a hint to improve that !
>>>>> Stephane.
>>>>>>> because in
>>>>>>> Ed Merks wrote:
>>>>>>>> Stéphane,
>>>>>>>> useUUIDs();
>>>>>>>> return true;
>>>>>>>> return false;
>>>>>>>> default. So I'm wondering why it's returning true.
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Stéphane,
>>>>>>>>>> needing to walk the tree? It's guarded such that the tree
>>>>>>>>> is attached to a resource.
>>>>>>>>> than calling x times this methods without tree walk.
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>> Comments below.
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> with a library with 10 000 children : sub-libraries, books,
>>>>>>>>>>>>> Some figures :
>>>>>>>>>>>>> library in the HibernateResource.
>>>>>>>>>>>>> already contained in a resource, it took 1s.
>>>>>>>>>>>>> 63ms to attach the temporary library to a library contained
>>>>>>>>>>>>> in a resource.
>>>>>>>>>>>>> differences ?
>>>>>>>>>>>> walking the whole tree and computing UUIDs or something like
>>>>>>>>>>>> that?
>>>>>>>>>>> positions.
>>>>>>>>>>> resource, ResourceImpl.attached is called for each object but
>>>>>>>>>>> that code is never executed :
>>>>>>>>>>> when the temporary lib is added to a resource contained one
>>>>>>>>>>> but the this time, the TreeIterator is walked to attach every
>>>>>>>>>>> contained objects.
>>>>>>>>>>>>> loading.
>>>>>>>>>>>>> Stephane.
The Netherlands
Re: HibernateResource vs XmiResourceImpl performances ? [message #425184 is a reply to message #425178] |
Tue, 18 November 2008 15:51 |
Hi Martin,
First of all, thanks for your answers ! :)
My comments inline.
Stephane.
Martin Taal wrote:
> Hi Stéphane,
On a standard
> optimizing the db.
behavior.
I have tried that and I got ClassNotFoundException. My editor is based on
two meta-models:
1) ExtendedLibrary
2) ExtendedExtendedLibrary that only defines one class ExtendedBook ->
Book defined in ExtendedLibrary.
The data store registers both meta-model root packages i.e one for
ExtendedBook and another one for ExtendedExtendedBook.
When opening my editor, I got exceptions due to the ExtendedBook class
that is not found by a Teneo/Hibernate classloader...
Do you have an idea ? Is it linked to buddy policy ?
I have checked all packages are exported in the plug-in that hosts
ExtendedBook (library.ext). This plug-in depends on the library one which
depends and re-exports hibernate & teneo plug-ins. Finally, the
library.editor plug-in depends on library plug-in and library.ext plug-in.
Here is the exception I got when activating SET_PROXY option :
Caused by: net.sf.cglib.core.CodeGenerationException:
java.lang.reflect.InvocationTargetException-->null
at
net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:237)
at net.sf.cglib.proxy.Enhancer.createHelper(Enhancer.java:377)
at net.sf.cglib.proxy.Enhancer.createClass(Enhancer.java:317)
at
org.hibernate.proxy.pojo.cglib.CGLIBLazyInitializer.getProxy Factory(CGLIBLazyInitializer.java:127)
at
org.hibernate.proxy.pojo.cglib.CGLIBProxyFactory.postInstant iate(CGLIBProxyFactory.java:43)
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.buildPr oxyFactory(EMFTuplizer.java:214)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:135)
at
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.<init>(EMFTuplizer.java:76)
... 119 more
Caused by: java.lang.reflect.InvocationTargetException
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at net.sf.cglib.core.ReflectUtils.defineClass(ReflectUtils.java :384)
at
net.sf.cglib.core.AbstractClassGenerator.create(AbstractClas sGenerator.java:219)
... 126 more
Caused by: java.lang.NoClassDefFoundError:
com/thalesgroup/mde/tig/ext/extlibrary/extendedlibrary/Exten dedBook
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
... 132 more
Ok, I will check that and I let you know the result of my analysis.
> gr. Martin
>> Martin Taal wrote:
>>> Hi Stéphane,
>>> gr. Martin
>>>> Hi Martin,
>>>> 1st scenario :
>>> log4j) to
>> Edit are grayed.
>> first time : 30s.
>>>> transaction.
>>> the db?
>>> options) in
>> the 16ms.
>>> resolved?
>>>> children):
>>>> itself.
>> objects added.
>>>> XML files.
>>>> Stephane.
>>>> Martin Taal wrote:
>>>>> Hi Stephane,
>>>>> gr. Martin
>>>>>> Ed Merks wrote:
>>>>>>> Stéphane,
>>>>>> performances.
>>>>>> Stephane.
>>>>>>>> because in
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Stéphane,
>>>>>>>>> useUUIDs();
>>>>>>>>> return true;
>>>>>>>>> return false;
>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> Stéphane,
>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>>> Comments below.
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> Some figures :
>>>>>>>>>>>>>> in a resource.
>>>>>>>>>>>>>> differences ?
>>>>>>>>>>>>> that?
>>>>>>>>>>>> positions.
>>>>>>>>>>>> contained objects.
>>>>>>>>>>>>>> loading.
>>>>>>>>>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425186 is a reply to message #425184] |
Tue, 18 November 2008 16:26 |
Hi Stéphane,
The plugin with the hibernate and cglib jar files should have eclipse-buddypolicy set to dependent.
Otherwise cglib can't find the model class files. Do you have that set?
gr. Martin
> Hi Martin,
> My comments inline.
> Stephane.
> Martin Taal wrote:
>> Hi Stéphane,
>> store.
> On a standard
>> records per
>> optimizing the db.
>> first
>> known.
> behavior.
> on two meta-models:
> 1) ExtendedLibrary
> which depends and re-exports hibernate & teneo plug-ins. Finally, the
> at
> at
> at
> at
> at
> at
> ... 119 more
> at
> at
> at
> ... 126 more
> ... 132 more
>> should
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Stéphane,
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> 1st scenario :
>>>> log4j) to
>>> one top class in the ExtendedLibrary meta-model. Writer extends
>>> Person thus, writers are loaded, and I think objects involved in
>>> Writer relationships are loaded too. Hence, that loads the entire model.
>>> uri gives an open editor in read-only i.e contextual menu items
>>> provided by Edit are grayed.
>>> library.
>>> first time : 30s.
>>>>> transaction.
>>>> the db?
>>>> options) in
>>> the 16ms.
>>>> resolved?
>>>>> 000 children):
>>>>> one itself.
>>> in the HibernateResource and 43s to save the resource with these 10
>>> 000 objects added.
>>> XMl) than the hibernate one.
>>>>> with XML files.
>>>>> Stephane.
>>>>> Martin Taal wrote:
>>>>>> Hi Stephane,
>>>>>> gr. Martin
>>>>>>> Ed Merks wrote:
>>>>>>>> Stéphane,
>>>>>>>> xmi:id which in strict conformance to the XMI specification is
>>>>>>>> required. In any case, this is clearly something you can
>>>>>>>> specialize. I.e., you might just use XMLResourceImpl instead...
>>>>>>> performances.
>>>>>>> Stephane.
>>>>>>>>> because in
>>>>>>>>> genmodel, ResourceType is set to NONE.
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Stéphane,
>>>>>>>>>> useUUIDs();
>>>>>>>>>> return true;
>>>>>>>>>> return false;
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> Stéphane,
>>>>>>>>>>> a temp lib with a sub tree containing my 10 000 children, no
>>>>>>>>>>> one is attached to a resource.
>>>>>>>>>>> yet.
>>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>>>> Comments below.
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> have initialized a mysql database (installed on my
>>>>>>>>>>>>>>> computer) with a library with 10 000 children :
>>>>>>>>>>>>>>> to load the resource from an uri that specifies the
>>>>>>>>>>>>>>> Some figures :
>>>>>>>>>>>>>>> differences ?
>>>>>>>>>>>>>> like that?
>>>>>>>>>>>>> positions.
>>>>>>>>>>>>> but that code is never executed :
>>>>>>>>>>>>>>> (checked with the debugger just before adding the root
>>>>>>>>>>>>>>> resource loading.
>>>>>>>>>>>>>>> Stephane.
The Netherlands
Re: HibernateResource vs XmiResourceImpl performances ? [message #425195 is a reply to message #425186] |
Wed, 19 November 2008 09:59 |
Martin Taal wrote:
> Hi Stéphane,
I did that and it only works for the library plug-in that directly depends
on the hibernate one. This library plug-in re-exports the hibernate one.
And the library.ext plug-in depends on the library one too. In theory, the
library.ext also depends on the hibernate plug-in. The PDE tooling shows
that with the plug-in dependency feature.
I have removed the library.ext plug-in to continue my tests and now it
works.
Now performances are a bit faster, but I have to figure out why my model
is entirely loaded.
> gr. Martin
>> Hi Martin,
>> My comments inline.
>> Stephane.
>> Martin Taal wrote:
>>> Hi Stéphane,
>>> store.
>> On a standard
>>> records per
>>> optimizing the db.
>>> first
>>> known.
>> behavior.
>> on two meta-models:
>> 1) ExtendedLibrary
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 119 more
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> ... 126 more
>> ... 132 more
>>> should
>>> gr. Martin
>>>> Martin Taal wrote:
>>>>> Hi Stéphane,
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> 1st scenario :
>>>>> log4j) to
>>>> library.
>>>> first time : 30s.
>>>>>> transaction.
>>>>> the db?
>>>>> options) in
>>>> the 16ms.
>>>>> resolved?
>>>>>> 000 children):
>>>>>> one itself.
>>>> 000 objects added.
>>>>>> with XML files.
>>>>>> Stephane.
>>>>>> Martin Taal wrote:
>>>>>>> Hi Stephane,
>>>>>>> gr. Martin
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Stéphane,
>>>>>>>> performances.
>>>>>>>> Stephane.
>>>>>>>>>> because in
>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> Stéphane,
>>>>>>>>>>> useUUIDs();
>>>>>>>>>>> return true;
>>>>>>>>>>> return false;
>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>> yet.
>>>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>>>>> Comments below.
>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>> Some figures :
>>>>>>>>>>>>>>>> differences ?
>>>>>>>>>>>>>>> like that?
>>>>>>>>>>>>>> positions.
>>>>>>>>>>>>>>>> resource loading.
>>>>>>>>>>>>>>>> Stephane.
Re: HibernateResource vs XmiResourceImpl performances ? [message #425219 is a reply to message #425195] |
Wed, 19 November 2008 23:13 |
Hi Stéphane,
Apparently buddypolicy dependent means that only the classpath of the directly depending plugin is
searched. In this case the classpath of library as it depends on hibernate. However, the classpath
of library does not contain the libraryext model and can't find it therefore.
Regarding your plugin setup, what I would propose is the following.
- Have a project/plugin which contains the testcases or application code
- let this plugin depend on hibernate, libraryext and library
- remove the dependency of library on hibernate and remove the reexport to libraryext and the
dependence of libraryext on hibernate
gr. Martin
> Martin Taal wrote:
>> Hi Stéphane,
> depends on the hibernate one. This library plug-in re-exports the
> hibernate one. And the library.ext plug-in depends on the library one
> too. In theory, the library.ext also depends on the hibernate plug-in.
> The PDE tooling shows that with the plug-in dependency feature. I have
> removed the library.ext plug-in to continue my tests and now it works.
> is entirely loaded.
>> gr. Martin
>>> Hi Martin,
>>> My comments inline.
>>> Stephane.
>>> Martin Taal wrote:
>>>> Hi Stéphane,
>>>> store.
>>> On a standard
>>>> records per
>>>> optimizing the db.
>>>> first
>>>> known.
>>>> persist/save
>>> behavior.
>>> based on two meta-models:
>>> 1) ExtendedLibrary
>>> -> Book defined in ExtendedLibrary.
>>> class that is not found by a Teneo/Hibernate classloader...
>>> plug-in.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 119 more
>>> at
>>> at
>>> at
>>> ... 126 more
>>> ... 132 more
>>>> which should
>>>> gr. Martin
>>>>> Martin Taal wrote:
>>>>>> Hi Stéphane,
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> 1st scenario :
>>>>>>> Library can contain another one.
>>>>>>> my point of view : 11s more or less.
>>>>>> log4j) to
>>>>> only one top class in the ExtendedLibrary meta-model. Writer
>>>>> extends Person thus, writers are loaded, and I think objects
>>>>> involved in Writer relationships are loaded too. Hence, that loads
>>>>> the entire model.
>>>>> library.
>>>>> first time : 30s.
>>>>> to select to get children loaded when I will expand the related
>>>>> TreeItem only? I'm a bit lost with MERGE, PERSIST, REFRESH, REMOVE
>>>>> values.
>>>>>>> a transaction.
>>>>>>> haven't understood where time is wasted.
>>>>>> from the db?
>>>>>> options) in
>>>>> the 16ms.
>>>>>> resolved?
>>>>> proxy containment set to true.
>>>>>>> 000 children):
>>>>>>> one itself.
>>>>> 000 objects added.
>>>>>>> with XML files.
>>>>>>> performances if I create objects as children of an object not
>>>>>>> attached to a resource. At the end, I add the not attached object
>>>>>>> Stephane.
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Stephane,
>>>>>>>> the db and add it to the hibernate resource?
>>>>>>>> gr. Martin
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Stéphane,
>>>>>>>>> in the guard block is never executed.
>>>>>>>>> performances.
>>>>>>>>> or XML are great to me :)
>>>>>>>>> Stephane.
>>>>>>>>>>> because in
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>> return useIDs() ||
>>>>>>>>>>>> || useUUIDs();
>>>>>>>>>>>> return true;
>>>>>>>>>>>> return false;
>>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>>> add a temp lib with a sub tree containing my 10 000
>>>>>>>>>>>>> children, no one is attached to a resource.
>>>>>>>>>>>>> the EObjectContainmentWithInverseEList.Resolving#add calls
>>>>>>>>>>>>> the opposite relation i.e setParentBranch(..) that calls
>>>>>>>>>>>>> tree objects that are not attached to the parent library
>>>>>>>>>>>>> resource yet.
>>>>>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>>>>>>> Stéphane,
>>>>>>>>>>>>>>>> Comments below.
>>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>>> Library meta-class is not considered as a top class by
>>>>>>>>>>>>>>>>> Teneo. So, loading my resource gives me an empty
>>>>>>>>>>>>>>>>> resource content. I query the database to retrieve my
>>>>>>>>>>>>>>>>> is in read-only).
>>>>>>>>>>>>>>>>> Some figures :
>>>>>>>>>>>>>>>>> differences ?
>>>>>>>>>>>>>>>> like that?
>>>>>>>>>>>>>>> positions.
>>>>>>>>>>>>>>> once when the temporary lib is added to a resource
>>>>>>>>>>>>>>> contained one but the this time, the TreeIterator is
>>>>>>>>>>>>>>>>> resource loading.
>>>>>>>>>>>>>>>>> Stephane.
The Netherlands
Current Time: Thu Apr 25 05:48:56 GMT 2024
Powered by FUDForum. Page generated in 0.05174 seconds
