Home » Modeling » EMF » XSD ID -> EMF ID -> hibernate id
Re: XSD ID -> EMF ID -> hibernate id [message #423613 is a reply to message #423612] |
Fri, 03 October 2008 00:10 |
Originally posted by: cdamus.zeligsoft.com
Hi, Andrew,
EMF's EObject IDs are intended to be resource-unique, as in XSD. The
UUID utility is a convenience for generating IDs that probably are
universally unique, but nothing in EMF expects this property.
HTH,
Christian
Andrew H wrote:
> As discussed in
> http://www.eclipse.org/newsportal/article.php?id=36086&g roup=eclipse.tools.emf#36086
> I started with some XSD's, generated EMF models and then persisted with
> Teneo. Fields that were declared in XSD as ID fields went into EMF as ID
> fields and then as id elements in the hibernate mappings. i.e. these
> fields became primary key fields.
> However, the XSD authors never intended them to be globally unique, just
> unique within a single document. They use IDREF fields elsewhere in the
> doc to refer to them.
> Consequently they are not suitable as id fields in the hibernate mappings.
> I fixed this with Martin's help by turning off the mapping from EMF ID
> to hibernate id.
> However, its not clear to me whether this was the best place to fix it.
> Is the semantics of ID in EMF that the field is intended to be a unique
> primary key for that class?
> If so then I should probably sever the mapping of XSD ID to EMF ID for
> these fields instead? If so how do I do that?
> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423648 is a reply to message #423613] |
Sat, 04 October 2008 01:08 |
Andrew H Messages: 117 Registered: July 2009 |
Thanks Christian
So I guess it comes down to what a resource is. In some cases it might
be a document, in others a table in a DB.
Christian W. Damus wrote:
> Hi, Andrew,
> HTH,
> Christian
> Andrew H wrote:
>> As discussed in
>> with Teneo. Fields that were declared in XSD as ID fields went into
>> EMF as ID fields and then as id elements in the hibernate mappings.
>> i.e. these fields became primary key fields.
>> just unique within a single document. They use IDREF fields elsewhere
>> in the doc to refer to them.
>> mappings.
>> to hibernate id.
>> it. Is the semantics of ID in EMF that the field is intended to be a
>> unique primary key for that class?
>> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423650 is a reply to message #423648] |
Sat, 04 October 2008 09:34 |
Hi Andres,
Or the resource represents the whole database, with Teneo a resource is connected to the database as
a whole, i.e. a Teneo EMF resource uses a hibernate session and with queries you can load data from
all the tables into the resource.
gr. Martin
andrew987650000@yahoo.com.au wrote:
> Thanks Christian
>> Hi, Andrew,
>> HTH,
>> Christian
>> Andrew H wrote:
>>> As discussed in
>>> mappings.
>>> ID to hibernate id.
>>> for these fields instead? If so how do I do that?
>>> Thoughts?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: XSD ID -> EMF ID -> hibernate id [message #423651 is a reply to message #423650] |
Sat, 04 October 2008 09:36 |
And here with the correct spelling of your name, sorry (the s and w are too close to eachother for
my fingers apparently :-)
Hi Andrew,
connected to the database as a whole, i.e. a Teneo EMF resource uses a
hibernate session and with queries you can load data from all the tables
into the resource.
gr. Martin
>> Thanks Christian
>>> Hi, Andrew,
>>> HTH,
>>> Christian
>>> Andrew H wrote:
>>>> As discussed in
>>>> elsewhere in the doc to refer to them.
>>>> mappings.
>>>> ID to hibernate id.
>>>> Thoughts?
The Netherlands
Re: XSD ID -> EMF ID -> hibernate id [message #423654 is a reply to message #423651] |
Sat, 04 October 2008 16:49 |
Hi, Martin,
Perhaps Andrew would enjoy being Spanish for a day?
You should use the Dvorak layout, as I do. There is a greater
separation between the S and the W. My own problem is between the N and
S, and the A and O. I sometimes sign my own name as Christios ... looks
vaguely Greek.
:-D
On a more serious note, I think the mapping of EMF's resource do the
database as a whole is very intuitive. It's convenient to have a closed
universe containing everything, and external references modeled simply
as URIs, which makes for a very explicit proxy concept.
cW
> too close to eachother for my fingers apparently :-)
> Hi Andrew,
> into the resource.
> gr. Martin
>>> Thanks Christian
>>> might be a document, in others a table in a DB.
>>>> Hi, Andrew,
>>>> The UUID utility is a convenience for generating IDs that probably
>>>> are universally unique, but nothing in EMF expects this property.
>>>> HTH,
>>>> Christian
>>>> Andrew H wrote:
>>>>> As discussed in
>>>>> mappings.
>>>>> ID to hibernate id.
>>>>> a unique primary key for that class?
>>>>> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423759 is a reply to message #423654] |
Tue, 07 October 2008 06:16 |
Thanks Christios & Marten :-)
So I think the problem then in this case is the association with XSD ID
and EMF ID. The XSD's that I originally imported are for B2B applications.
They use XML ID for references within a document. I should stop these
mapping to EMF ID fields as this implies uniqueness withing our database
for these objects.
thanks for everyones thoughts
> Hi, Martin,
> vaguely Greek.
> :-D
> cW
>> Hi Andrew,
>> into the resource.
>> gr. Martin
>>>> Thanks Christian
>>>>> Hi, Andrew,
>>>>> HTH,
>>>>> Christian
>>>>> Andrew H wrote:
>>>>>> As discussed in
>>>>>> mappings.
>>>>>> ID to hibernate id.
>>>>>> Thoughts?
Current Time: Thu Apr 25 22:32:07 GMT 2024
Powered by FUDForum. Page generated in 0.03831 seconds
