Home » Modeling » EMF » Date attribute in Ecore model
Re: Date attribute in Ecore model [message #423509 is a reply to message #423500] |
Wed, 01 October 2008 15:32 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------000604000903070200070405
Andy,
In that case, you need to conform to how EDate serializes dates. These
XML Schema-style formats are supported:
protected static final DateFormat [] EDATE_FORMATS =
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSSZ"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSS"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss"),
new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm"),
new SafeSimpleDateFormat("yyyy-MM-dd")
Andy Carpenter wrote:
> Ed,
> Comments below
> "Ed Merks" <Ed.Merks@gmail.com> wrote in message
> news:gbvqml$vfo$1@build.eclipse.org...
>> Andy,
>> Comments below.
>>> I have an Ecore model that includes an attribute with the type
>>> Date. As part of the early stages of my development, I've generated
>>> the model, edit and editor code for this model. Now when I run the
>>> editor code to create an instance of the model the status bar for the
>>> editor shows 'WrappedException : java.text.ParseException:
>>> Unparsable date: "Tuesday, April 12, 1952"'
>> Did you use Ecore's EDate data type? It looks like maybe you defined
>> your own EDataType and then didn't specialize the XyzFactoryImpl's
>> createAbcFromString/convertAbcToString for that data type.
> I used Date in my Emfatic model which appears to have been
> mapped to EDate in the resource used to generate the EMF model.
> The XyzFactoryImpl contains no 'date' type.
>>> Does anyone know if a date can be set via the properties field of
>>> the editor, or do I need to wait until I integrate my model into a more
>>> complete environment before I can set the value of a date attribute?
>> It really comes down to what data type you are using to support your
>> string round tripping..
>>> thanks
>>> Andy.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Andy,<br>
<br>
XML Schema-style formats are supported:<br>
<blockquote><small> protected static final DateFormat [] EDATE_FORMATS
= </small><br>
<small> {</small><br>
<small> new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSSZ"),</small ><br>
<small> new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss'.'SSS"),</small ><br>
<small> new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss"),</small><br >
<small> new SafeSimpleDateFormat("yyyy-MM-dd'T'HH:mm"),</small><br>
<small> new SafeSimpleDateFormat("yyyy-MM-dd")</small><br>
<small> };</small><br>
</blockquote>
<br>
<blockquote cite="mid:gbvvaq$7ip$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
Comments below
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gbvqml$vfo$1@build.eclipse.org">news:gbvqml$vfo$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Andy,
Comments below.
</pre>
<pre wrap="">I have an Ecore model that includes an attribute with the type
</pre>
</blockquote>
<pre wrap="">Did you use Ecore's EDate data type? It looks like maybe you defined
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">Does anyone know if a date can be set via the properties field of
</pre>
</blockquote>
<pre wrap="">It really comes down to what data type you are using to support your
</pre>
<pre wrap=""> thanks
Andy.
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------000604000903070200070405--
Ed Merks
Re: Date attribute in Ecore model [message #423512 is a reply to message #423509] |
Wed, 01 October 2008 15:49 |
Andy Carpenter Messages: 145 Registered: July 2009 |
Ed,
Thanks, that enabled me to enter a value.
Andy.
news:gc0561$8sq$1@build.eclipse.org...
> Andy,
>> Ed,
>> Comments below
>>> Andy,
>>> Comments below.
>>>> thanks
>>>> Andy.
Current Time: Wed Apr 24 19:26:29 GMT 2024
Powered by FUDForum. Page generated in 0.03131 seconds
