Re: How can i poof an elist data? [message #423365 is a reply to message #423364] |
Mon, 29 September 2008 14:44 |
Jörg schrieb:
> Sorry for the spelling mistake.
> Jörg schrieb:
>> Hello,
>> I have an Elist like this. EList<Property> Pi
>> Now i fill this EList with some Elements. But i want to proof these
>> Elements dynamically. So is there a way to get the information, that
>> this elist only holds propertys?
Jörg, I'm curious: Which non-Property classed objects do you think would
Java allow you to add to such a list?
Cheers
/Eike
>> This is only an example, there are some more lists, whiches holds
>> other elements.
>> Greetings
>> Jörg
Cheers
/Eike
http://www.esc-net.de
Re: How can i poof an elist data? [message #423368 is a reply to message #423367] |
Mon, 29 September 2008 14:48 |
Jörg schrieb:
> There is no non-property class i can at. I know this. this is the
> reason i want to proof it, before i call the put method.
I still don't understand. Why do you want to proof something that you
already know?
> Eike Stepper schrieb:
>>> Jörg schrieb:
>>>> Hello,
>>>> that this elist only holds propertys?
>> would Java allow you to add to such a list?
>> Cheers
>> /Eike
>>>> other elements.
>>>> Greetings
>>>> Jörg
Cheers
/Eike
Re: How can i poof an elist data? [message #423370 is a reply to message #423368] |
Mon, 29 September 2008 14:50 |
> already know?
Ah, do you mean how to test if a given object "is a" Property?
That would be a pure Java question and I'd say
if (object instanceof Property) list.add((Property)object);
>>>> Jörg schrieb:
>>>>> Hello,
>>>>> these Elements dynamically. So is there a way to get the
>>>>> information, that this elist only holds propertys?
>>> Cheers
>>> /Eike
>>>>> other elements.
>>>>> Greetings
>>>>> Jörg
Cheers
/Eike
FUDForum. Page generated in 0.03058 seconds
