Home » Modeling » EMF » [Teneo] Exception using ManyToMany annotation
Re: [Teneo] Exception using ManyToMany annotation [message #423288 is a reply to message #423287] |
Fri, 26 September 2008 10:35 |
Hi David,
I think there should be a comma between MERGE and PERSIST in the cascade attribute.
gr. Martin
David Wynter wrote:
> I followed the ejb3_example on the many to many annotations. Ended up
> with this
> <xsd:schema xmlns:secmsec="http://www.stpware.com/secmsecurity"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> attributeFormDefault="unqualified" elementFormDefault="qualified"
> targetNamespace="http://www.stpware.com/secmsecurity"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
> <xsd:import schemaLocation="xml.xsd"
> namespace="http://www.w3.org/XML/1998/namespace" />
> <xsd:simpleType name="javaDate" ecore:instanceClass="java.util.Date">
> <xsd:restriction base="xsd:dateTime">
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:complexType name="User">
> <xsd:annotation>
> <xsd:documentation>
> <xsd:p>The basic user entity. Kept simple, the Role attribute is
> just a string. 'Admin', 'Cleanse', 'ReadOnly' and 'CrudUser'</xsd:p>
> </xsd:documentation>
> </xsd:annotation>
> <xsd:sequence minOccurs="0" maxOccurs="1">
> <xsd:element name="userrole" type="xsd:IDREF"
> ecore:reference="secmsec:UserRole" maxOccurs="unbounded"
> ecore:opposite="user">
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">
> @ManyToMany(fetch=LAZY cascade={MERGE PERSIST}
> targetEntity="UserRole" mappedBy="user" indexed="false")
> @JoinTable(name="UserRole")
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> <xsd:attribute name="id" type="xsd:int">
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">@Id
> @GeneratedValue(strategy=IDENTITY)</xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:attribute name="firstName" type="xsd:string" />
> <xsd:attribute name="surname" type="xsd:string" />
> <xsd:attribute name="email" type="xsd:string" />
> <xsd:attribute name="salutation" type="xsd:string" />
> <xsd:attribute name="loginName" type="xsd:string" />
> <xsd:attribute name="password" type="xsd:string" />
> <xsd:attribute name="phone" type="xsd:string" />
> <xsd:attribute name="lastLogin" type="secmsec:javaDate" />
> <xsd:attribute name="userStart" type="secmsec:javaDate" />
> <xsd:attribute name="userEnd" type="secmsec:javaDate" />
> </xsd:complexType>
> <xsd:element name="user" type="secmsec:User">
> </xsd:element>
> <xsd:element name="role" type="secmsec:Role"></xsd:element>
> <xsd:complexType name="Role">
> ecore:opposite="role">
> <xsd:annotation>
> targetEntity="UserRole" mappedBy="role")
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:attribute name="name" type="xsd:string"></xsd:attribute>
> </xsd:complexType>
> <xsd:complexType name="UserRole">
> <xsd:sequence>
> <xsd:element name="user" type="xsd:IDREF"
> ecore:reference="secmsec:User" maxOccurs="unbounded"
> ecore:opposite="userrole">
> <xsd:annotation>
> @ManyToMany(fetch=EAGER cascade={MERGE PERSIST}
> targetEntity="User" indexed="false")
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> <xsd:element name="role" type="xsd:IDREF"
> ecore:reference="secmsec:Role" maxOccurs="unbounded"
> <xsd:annotation>
> targetEntity="Role")
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:element name="userrole" type="secmsec:UserRole"></xsd:element>
> </xsd:schema>
> This gives me the exception:
> Exception in thread "main"
> org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption:
> Found Attribute Name but expected one of : Array End (}), = character,
> Comma (,).
> @ManyToMany(fetch=LAZY cascade={MERGE PERSIST_}
> Current lexeme: PERSIST
> at
> org.eclipse.emf.teneo.annotations.parser.AnnotationParser.ch eckToken(AnnotationParser.java:261)
> at
> org.eclipse.emf.teneo.annotations.parser.AnnotationParser.pa rseArray(AnnotationParser.java:217)
> at
> org.eclipse.emf.teneo.annotations.parser.AnnotationParser.pa rseContent(AnnotationParser.java:181)
> It is very explicit, but I cannot see what is different in structure to
> the example.
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Exception using ManyToMany annotation [message #423289 is a reply to message #423288] |
Fri, 26 September 2008 10:58 |
David Wynter Messages: 4624 Registered: July 2009 |
In which case the example on ManyToMany on
http://www.elver.org/hibernate/ejb3_examples.html is wrong.
Now that it generates it generates way too many tables for my liking.
I know to represent User >-< Role (many to many) I need one table, lets
call it UserRole, it has 2 columns, user_id and role_id. user_id joins
to User.id and role_id joins to Role.id
What I get is 3 tables:
userrole_role with columns - userrole, role userrole_idx
userole with columns - e_id, user, userrole
role_userrole with columns - role, userole, role_userole_idx
Is there a way to end up with a simpler schema? What advantages do these
3 tables give over a single table? If I have lot of many to many my
schema will be much larger and much more difficult for people to understand.
Thx,
David
Martin Taal wrote:
> Hi David,
> attribute.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> with this
>> <?xml version="1.0" encoding="UTF-8"?>
>> </xsd:restriction>
>> </xsd:simpleType>
>> <xsd:annotation>
>> <xsd:documentation>
>> is just a string. 'Admin', 'Cleanse', 'ReadOnly' and 'CrudUser'</xsd:p>
>> </xsd:annotation>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> <xsd:sequence>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> </xsd:appinfo>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> Comma (,).
>> at
>> at
>> at
>> to the example.
>> Thx.
>> David
Re: [Teneo] Exception using ManyToMany annotation [message #423290 is a reply to message #423289] |
Fri, 26 September 2008 11:29 |
Hi David,
Thanks for pointing that out, I have repaired that.
In your case afaics you have an explicit join type UserRole. So technically the reference from user
to userrole and from role to userrole are not manytomany but onetomany. Because you explicitly say
that is a manytomany you get three tables:
for the join between user and userrole
for userrole itself
for the join from role to userrole.
In case you had not explicitly modelled the join type then a manytomany is appropriate.
Changing the annotation to OneToMany will solve this for you.
The targetentity is not required in the manytomany/onetomany. Normally this is computed by Teneo.
Also I noticed that you had indexed="false" only on one side. If you don't need the index on any of
the associations then you can also
PersistenceOptions.MAP_ALL_LISTS_AS_IDBAG to true (then always a idbag is used), or
PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG to true then always a hibernate bag is used.
gr. Martin
David Wynter wrote:
> understand.
> Thx,
> David
> Martin Taal wrote:
>> Hi David,
>> cascade attribute.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> with this
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> <xsd:annotation>
>>> <xsd:documentation>
>>> </xsd:annotation>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> </xsd:element>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> <xsd:annotation>
>>> </xsd:appinfo>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> character, Comma (,).
>>> at
>>> at
>>> at
>>> to the example.
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423301 is a reply to message #423290] |
Fri, 26 September 2008 16:15 |
After reading the Hibernate manual a little I found this example for one
to many, many to one
<class name="Person">
<id name="id" column="personId">
<generator class="native"/>
</id>
<set name="addresses"
table="PersonAddress">
<key column="personId"/>
<many-to-many column="addressId"
unique="true"
class="Address"/>
</set>
</class>
<class name="Address">
<id name="id" column="addressId">
</id>
<join table="PersonAddress"
inverse="true"
optional="true">
<key column="addressId"/>
<many-to-one name="person"
column="personId"
not-null="true"/>
</join>
</class>
What annotation would we use to achieve this configuration?
Thx.
David
Martin Taal wrote:
> Hi David,
> technically the reference from user to userrole and from role to
> for userrole itself
> is appropriate.
> don't need the index on any of the associations then you can also
> is used), or
> gr. Martin
> David Wynter wrote:
>> Hi,
>> lets call it UserRole, it has 2 columns, user_id and role_id. user_id
>> joins to User.id and role_id joins to Role.id
>> these 3 tables give over a single table? If I have lot of many to many
>> my schema will be much larger and much more difficult for people to
>> understand.
>> Thx,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> cascade attribute.
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> up with this
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> <xsd:annotation>
>>>> <xsd:documentation>
>>>> attribute is just a string. 'Admin', 'Cleanse', 'ReadOnly' and
>>>> 'CrudUser'</xsd:p>
>>>> </xsd:annotation>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> </xsd:element>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> <xsd:annotation>
>>>> </xsd:appinfo>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> at
>>>> at
>>>> at
>>>> to the example.
>>>> Thx.
>>>> David
Re: [Teneo] Exception using ManyToMany annotation [message #423305 is a reply to message #423301] |
Fri, 26 September 2008 17:22 |
Hi David,
To be sure we are not discussing the User, UserRole, Role (whereby userrole is present as a separate
type) case anymore are we?
To get the result of what you want with hibernate add this annotation in the efeature which is the list:
@OneToMany(indexed=false, mappedBy="one")
@JoinTable(name="maniesofone")
where one is the opposite feature name.
Some other info:
Teneo as a default maps non-containment associations with a jointable (is controlled by the option:
PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_ASSOCIATIONS ).
However, for bidirectional lists the many-to-one mapping creates an additional foreign key on the
many side. This because hibernate does not support bidirectional lists. To prevent this you should
also disable the mapping of the list index (see the map as bag and map as idbag in the other
replies, or used indexed="false").
So to summarize you can try to set the option PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG to true and
then see where join tables are created.
Note that for a bidirectional one-to-many/many-to-one a join table is not strictly required because
the many is always only used once (as the relation is bidirectional).
gr. Martin
David Wynter wrote:
> </id>
> unique="true"
> class="Address"/>
> </set>
> </class>
> </id>
> inverse="true"
> optional="true">
> column="personId"
> not-null="true"/>
> </join>
> </class>
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> for userrole itself
>> is used), or
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> many my schema will be much larger and much more difficult for people
>>> to understand.
>>> Thx,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> cascade attribute.
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> up with this
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> <xsd:annotation>
>>>>> <xsd:documentation>
>>>>> 'CrudUser'</xsd:p>
>>>>> </xsd:annotation>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> </xsd:element>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> <xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> <xsd:annotation>
>>>>> </xsd:appinfo>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> </xsd:complexType>
>>>>> </xsd:schema>
>>>>> at
>>>>> at
>>>>> at
>>>>> structure to the example.
>>>>> Thx.
>>>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423379 is a reply to message #423305] |
Mon, 29 September 2008 16:21 |
The suggestions you gave did generate the correct database tables. But I
am confused, as the generate methods do not reflect the underlying
tables. For example I have
<xsd:complexType name="Group">
<xsd:element minOccurs="0" maxOccurs="unbounded"
name="groupUser" type="secmsec:User" ecore:opposite="group">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa"> @OneToMany(indexed=false,
mappedBy="user") @JoinTable(name="UserGroup")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="userGroup"
type="secmsec:Group" ecore:opposite="user">
<xsd:annotation>
mappedBy="group") @JoinTable(name="UserGroup")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
This generates the following hibernate.hbm.xml
Inside Group entity declaration we have
<bag name="groupUser" inverse="true" table="`usergroup`" lazy="true"
cascade="all,delete-orphan">
<key update="true">
<column name="`group_id`" not-null="true" unique="false"/>
</key>
<many-to-many entity-name="User" unique="true"
foreign-key="group_groupuser">
<column name="`user_id`" not-null="true" unique="false"/>
</many-to-many>
</bag>
Inside User declaration we have
<bag name="userGroup" inverse="true" table="`usergroup`" lazy="true"
<key update="true">
</key>
<many-to-many entity-name="Group" unique="true"
foreign-key="user_usergroup">
</many-to-many>
</bag>
But the generated User Interface has a method "Group getGroup();"
The generated Group Interface has "User getUser();"
This should be "EList<Group> getGroup();" and "Elist<User> getUser();"
shouldn't it?
Thx.
David
Martin Taal wrote:
> Hi David,
> userrole is present as a separate type) case anymore are we?
> Some other info:
> additional foreign key on the many side. This because hibernate does not
> support bidirectional lists. To prevent this you should also disable the
> other replies, or used indexed="false").
> PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG to true and then see where
> not strictly required because the many is always only used once (as the
> gr. Martin
> David Wynter wrote:
>> Hi,
>> one to many, many to one
>> </id>
>> unique="true"
>> class="Address"/>
>> </set>
>> </class>
>> </id>
>> inverse="true"
>> optional="true">
>> column="personId"
>> not-null="true"/>
>> </join>
>> </class>
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> for userrole itself
>>> idbag is used), or
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> user_id joins to User.id and role_id joins to Role.id
>>>> Thx,
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> cascade attribute.
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> up with this
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> <xsd:annotation>
>>>>>> <xsd:documentation>
>>>>>> 'CrudUser'</xsd:p>
>>>>>> </xsd:annotation>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:element>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> </xsd:element>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:element>
>>>>>> </xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> <xsd:sequence>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:element>
>>>>>> <xsd:annotation>
>>>>>> </xsd:appinfo>
>>>>>> </xsd:annotation>
>>>>>> </xsd:element>
>>>>>> </xsd:sequence>
>>>>>> </xsd:complexType>
>>>>>> </xsd:schema>
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thx.
>>>>>> David
Re: [Teneo] Exception using ManyToMany annotation [message #423386 is a reply to message #423379] |
Mon, 29 September 2008 17:14 |
Hi David,
I would expect that there is a method getGroupUser in Group returning an EList<User> and a
getUserGroup in User which returns an EList<Group>.
Did you reload the xsd in the genmodel and then regenerate the model code?
gr. Martin
David Wynter wrote:
> <xsd:element minOccurs="0" maxOccurs="unbounded" name="groupUser"
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> name="userGroup" type="secmsec:Group" ecore:opposite="user">
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> lazy="true" cascade="all,delete-orphan">
> <key update="true">
> </key>
> </many-to-many>
> </bag>
> <key update="true">
> </key>
> </many-to-many>
> </bag>
> shouldn't it?
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> Some other info:
>> not support bidirectional lists. To prevent this you should also
>> idbag in the other replies, or used indexed="false").
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> </id>
>>> unique="true"
>>> class="Address"/>
>>> </set>
>>> </class>
>>> </id>
>>> inverse="true"
>>> optional="true">
>>> column="personId"
>>> not-null="true"/>
>>> </join>
>>> </class>
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> say that is a manytomany you get three tables:
>>>> for userrole itself
>>>> idbag is used), or
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> Thx,
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> cascade attribute.
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> Ended up with this
>>>>>>> </xsd:restriction>
>>>>>>> </xsd:simpleType>
>>>>>>> <xsd:annotation>
>>>>>>> <xsd:documentation>
>>>>>>> 'CrudUser'</xsd:p>
>>>>>>> </xsd:annotation>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:element>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> </xsd:element>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:element>
>>>>>>> </xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </xsd:complexType>
>>>>>>> <xsd:sequence>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:element>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:appinfo>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:element>
>>>>>>> </xsd:sequence>
>>>>>>> </xsd:complexType>
>>>>>>> </xsd:schema>
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Thx.
>>>>>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423387 is a reply to message #423386] |
Mon, 29 September 2008 18:06 |
This time I deleted the User and Group interface and classes. When I
generated it did indeed add the getUserGroup and getGroupUser methods
where expected.
The thing I did not expect was that the the Group.getUser() and
User.getGroup(), both returning a single object. I can just ignore these
but it is a little confusing to have them there.
regards,
David
Martin Taal wrote:
> Hi David,
> EList<User> and a getUserGroup in User which returns an EList<Group>.
> gr. Martin
> David Wynter wrote:
>> Hi,
>> I am confused, as the generate methods do not reflect the underlying
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </many-to-many>
>> </bag>
>> <key update="true">
>> </key>
>> unique="false"/>
>> </many-to-many>
>> </bag>
>> shouldn't it?
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> Some other info:
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> </id>
>>>> unique="true"
>>>> class="Address"/>
>>>> </set>
>>>> </class>
>>>> </id>
>>>> inverse="true"
>>>> optional="true">
>>>> column="personId"
>>>> not-null="true"/>
>>>> </join>
>>>> </class>
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> for userrole itself
>>>>> you don't need the index on any of the associations then you can also
>>>>> idbag is used), or
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> Thx,
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> cascade attribute.
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> Ended up with this
>>>>>>>> </xsd:restriction>
>>>>>>>> </xsd:simpleType>
>>>>>>>> <xsd:annotation>
>>>>>>>> <xsd:documentation>
>>>>>>>> 'CrudUser'</xsd:p>
>>>>>>>> </xsd:annotation>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:element>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> </xsd:element>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:element>
>>>>>>>> </xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </xsd:complexType>
>>>>>>>> <xsd:sequence>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:element>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:appinfo>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:element>
>>>>>>>> </xsd:sequence>
>>>>>>>> </xsd:complexType>
>>>>>>>> </xsd:schema>
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Thx.
>>>>>>>> David
Re: [Teneo] Exception using ManyToMany annotation [message #423388 is a reply to message #423387] |
Mon, 29 September 2008 18:29 |
Hi David,
Normally EMF should regenerate the code without the need to delete the classes/interfaces. Also I
can't really imagine that the getUser or getGroup originate from the two multi-occurence element you
showed below.
Maybe because there is a sequence with minOccurs="0" that you get these, but I can't really
understand why. (maybe Ed knows)
You can also check the ecore to see if Group has a user efeature (and User a group efeature). Then
when importing the xsd in the genmodel I think you can specify somewhere to generate a xsd2ecore
map. This generates an extra file, if you open that file then you can see the relation between the
ecore model elements and their corresponding xsd element. This could give more info.
gr. Martin
David Wynter wrote:
> where expected.
> regards,
> David
> Martin Taal wrote:
>> Hi David,
>> an EList<User> and a getUserGroup in User which returns an EList<Group>.
>> code?
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> But I am confused, as the generate methods do not reflect the
>>> underlying tables. For example I have
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> </xsd:sequence>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:element>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> unique="false"/>
>>> </many-to-many>
>>> </bag>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> unique="false"/>
>>> </many-to-many>
>>> </bag>
>>> getUser();" shouldn't it?
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> Some other info:
>>>> is not strictly required because the many is always only used once
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> for one to many, many to one
>>>>> </id>
>>>>> unique="true"
>>>>> class="Address"/>
>>>>> </set>
>>>>> </class>
>>>>> </id>
>>>>> inverse="true"
>>>>> optional="true">
>>>>> column="personId"
>>>>> not-null="true"/>
>>>>> </join>
>>>>> </class>
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> for userrole itself
>>>>>> idbag is used), or
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> liking.
>>>>>>> table, lets call it UserRole, it has 2 columns, user_id and
>>>>>>> role_id. user_id joins to User.id and role_id joins to Role.id
>>>>>>> do these 3 tables give over a single table? If I have lot of many
>>>>>>> to many my schema will be much larger and much more difficult for
>>>>>>> Thx,
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> cascade attribute.
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> Ended up with this
>>>>>>>>> </xsd:restriction>
>>>>>>>>> </xsd:simpleType>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> <xsd:documentation>
>>>>>>>>> 'CrudUser'</xsd:p>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:element>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> </xsd:element>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:element>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:attribute>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> <xsd:sequence>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:element>
>>>>>>>>> <xsd:annotation>
>>>>>>>>> </xsd:appinfo>
>>>>>>>>> </xsd:annotation>
>>>>>>>>> </xsd:element>
>>>>>>>>> </xsd:sequence>
>>>>>>>>> </xsd:complexType>
>>>>>>>>> </xsd:schema>
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Thx.
>>>>>>>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423390 is a reply to message #423388] |
Mon, 29 September 2008 19:03 |
Ed Merks Messages: 33113 Registered: July 2009 |
Martin,
Comments below.
Martin Taal wrote:
> Hi David,
> classes/interfaces. Also I can't really imagine that the getUser or
> getGroup originate from the two multi-occurence element you showed below.
They originate from the "ecore:opposite" annotations. The opposite of a
containment feature is a container feature and you can have at most one
container.
> these, but I can't really understand why. (maybe Ed knows)
> User a group efeature). Then when importing the xsd in the genmodel I
> think you can specify somewhere to generate a xsd2ecore map. This
> relation between the ecore model elements and their corresponding xsd
> gr. Martin
> David Wynter wrote:
>> Hi,
>> where expected.
>> these but it is a little confusing to have them there.
>> regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> returning an EList<User> and a getUserGroup in User which returns an
>>> EList<Group>.
>>> code?
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> <xsd:annotation>
>>>> @OneToMany(indexed=false, mappedBy="user")
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> @OneToMany(indexed=false, mappedBy="group")
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> unique="false"/>
>>>> </many-to-many>
>>>> </bag>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> unique="false"/>
>>>> </many-to-many>
>>>> </bag>
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> Some other info:
>>>>> an additional foreign key on the many side. This because hibernate
>>>>> map as idbag in the other replies, or used indexed="false").
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> </id>
>>>>>> unique="true"
>>>>>> class="Address"/>
>>>>>> </set>
>>>>>> </class>
>>>>>> </id>
>>>>>> inverse="true"
>>>>>> optional="true">
>>>>>> column="personId"
>>>>>> not-null="true"/>
>>>>>> </join>
>>>>>> </class>
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> explicitly say that is a manytomany you get three tables:
>>>>>>> for userrole itself
>>>>>>> also
>>>>>>> idbag is used), or
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> liking.
>>>>>>>> many to many my schema will be much larger and much more
>>>>>>>> Thx,
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Ended up with this
>>>>>>>>>> <xsd:schema
>>>>>>>>>> </xsd:restriction>
>>>>>>>>>> </xsd:simpleType>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> <xsd:documentation>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> <xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> </xsd:schema>
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Thx.
>>>>>>>>>> David
Ed Merks
Re: [Teneo] Exception using ManyToMany annotation [message #423392 is a reply to message #423390] |
Mon, 29 September 2008 19:21 |
Ed,
You are right! Hmm, that I missed that one :-(...
gr. Martin
Ed Merks wrote:
> Martin,
> Comments below.
> Martin Taal wrote:
>> Hi David,
> container.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> where expected.
>>> regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> EList<Group>.
>>>> code?
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> Some other info:
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </id>
>>>>>>> unique="true"
>>>>>>> class="Address"/>
>>>>>>> </set>
>>>>>>> </class>
>>>>>>> </id>
>>>>>>> inverse="true"
>>>>>>> optional="true">
>>>>>>> column="personId"
>>>>>>> not-null="true"/>
>>>>>>> </join>
>>>>>>> </class>
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> for userrole itself
>>>>>>>> also
>>>>>>>> idbag is used), or
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> liking.
>>>>>>>>> Thx,
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Ended up with this
>>>>>>>>>>> <xsd:schema
>>>>>>>>>>> </xsd:restriction>
>>>>>>>>>>> </xsd:simpleType>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> <xsd:documentation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:schema>
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423412 is a reply to message #423388] |
Tue, 30 September 2008 08:59 |
I added the option to create the xsd2ecore map. Here are the relevant
parts. I cannot see what there is in this that suggests that the Group
getGroup() would be generated on the User interface.
<nested inputs="secmsecurity.xsd#//User;XSDComplexTypeDefinition"
outputs="secmsecurity.ecore#//User">
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDParticle /XSDModelGroup/XSDParticle "
outputs="secmsecurity.ecore#//User/userPref"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDParticle /XSDModelGroup/XSDParticle=1 "
outputs="secmsecurity.ecore#//User/userGroup"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDParticle /XSDModelGroup/XSDParticle=2 "
outputs="secmsecurity.ecore#//User/userRole"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=3 "
outputs="secmsecurity.ecore#//User/email"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=1 "
outputs="secmsecurity.ecore#//User/firstName"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse "
outputs="secmsecurity.ecore#//User/id"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=8 "
outputs="secmsecurity.ecore#//User/lastLogin"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=5 "
outputs="secmsecurity.ecore#//User/loginName"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=6 "
outputs="secmsecurity.ecore#//User/password"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=7 "
outputs="secmsecurity.ecore#//User/phone"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=4 "
outputs="secmsecurity.ecore#//User/salutation"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=2 "
outputs="secmsecurity.ecore#//User/surname"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=10 "
outputs="secmsecurity.ecore#//User/userEnd"/>
<nested
inputs=" secmsecurity.xsd#//User;XSDComplexTypeDefinition/XSDAttribut eUse=9 "
outputs="secmsecurity.ecore#//User/userStart"/>
</nested>
<nested inputs="secmsecurity.xsd#//Group;XSDComplexTypeDefinition=4 "
outputs="secmsecurity.ecore#//Group">
<nested
inputs=" secmsecurity.xsd#//Group;XSDComplexTypeDefinition=4/XSDParti cle/XSDModelGroup/XSDParticle "
outputs="secmsecurity.ecore#//Group/groupUser"/>
<nested
inputs=" secmsecurity.xsd#//Group;XSDComplexTypeDefinition=4/XSDAttri buteUse "
outputs="secmsecurity.ecore#//Group/id"/>
<nested
inputs=" secmsecurity.xsd#//Group;XSDComplexTypeDefinition=4/XSDAttri buteUse=1 "
outputs="secmsecurity.ecore#//Group/name"/>
</nested>
<nested inputs="secmsecurity.xsd#//group;XSDElementDeclaration=4"
outputs="secmsecurity.ecore#//DocumentRoot/group"/>
<nested
inputs="secmsecurity.xsd#//permission;XSDElementDeclaration=3 "
outputs="secmsecurity.ecore#//DocumentRoot/permission"/>
<nested inputs="secmsecurity.xsd#//role;XSDElementDeclaration=2"
outputs="secmsecurity.ecore#//DocumentRoot/role"/>
<nested inputs="secmsecurity.xsd#//user;XSDElementDeclaration"
outputs="secmsecurity.ecore#//DocumentRoot/user"/>
<nested inputs="secmsecurity.xsd#//userPref;XSDElementDeclaration=1 "
outputs="secmsecurity.ecore#//DocumentRoot/userPref"/>
The ecore User does have an eFeature for the Group as well as one for
the userGroup. The ecore Group does have an efeature for the User and
the valid one for the groupUser.
Changing the sequence to minOccurs and maxOccurs = 1 makes no difference
in the outcome.
Thx.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> David Wynter wrote:
>> Hi,
>> where expected.
>> regards,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> code?
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:element>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> unique="false"/>
>>>> </many-to-many>
>>>> </bag>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> unique="false"/>
>>>> </many-to-many>
>>>> </bag>
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> Some other info:
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> </id>
>>>>>> unique="true"
>>>>>> class="Address"/>
>>>>>> </set>
>>>>>> </class>
>>>>>> </id>
>>>>>> inverse="true"
>>>>>> optional="true">
>>>>>> column="personId"
>>>>>> not-null="true"/>
>>>>>> </join>
>>>>>> </class>
>>>>>> Thx.
>>>>>> David
>>>>>> Martin Taal wrote:
>>>>>>> Hi David,
>>>>>>> for userrole itself
>>>>>>> also
>>>>>>> idbag is used), or
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> liking.
>>>>>>>> Thx,
>>>>>>>> David
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi David,
>>>>>>>>> gr. Martin
>>>>>>>>> David Wynter wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Ended up with this
>>>>>>>>>> <xsd:schema
>>>>>>>>>> </xsd:restriction>
>>>>>>>>>> </xsd:simpleType>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> <xsd:documentation>
>>>>>>>>>> 'CrudUser'</xsd:p>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:attribute>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> <xsd:sequence>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> <xsd:annotation>
>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>> </xsd:annotation>
>>>>>>>>>> </xsd:element>
>>>>>>>>>> </xsd:sequence>
>>>>>>>>>> </xsd:complexType>
>>>>>>>>>> </xsd:schema>
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Thx.
>>>>>>>>>> David
Re: [Teneo] Exception using ManyToMany annotation [message #423413 is a reply to message #423412] |
Tue, 30 September 2008 08:57 |
Hi David,
See the answer of Ed one or two posts back. The getGroup and getUser are generated because there is
an eopposite defined.
gr. Martin
David Wynter wrote:
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> <nested
> </nested>
> <nested
> <nested
> <nested
> </nested>
> <nested inputs="secmsecurity.xsd#//permission;XSDElementDeclaration=3 "
> in the outcome.
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> where expected.
>>> regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> EList<Group>.
>>>> code?
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> Some other info:
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </id>
>>>>>>> unique="true"
>>>>>>> class="Address"/>
>>>>>>> </set>
>>>>>>> </class>
>>>>>>> </id>
>>>>>>> inverse="true"
>>>>>>> optional="true">
>>>>>>> column="personId"
>>>>>>> not-null="true"/>
>>>>>>> </join>
>>>>>>> </class>
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> for userrole itself
>>>>>>>> also
>>>>>>>> idbag is used), or
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> liking.
>>>>>>>>> Thx,
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Ended up with this
>>>>>>>>>>> <xsd:schema
>>>>>>>>>>> </xsd:restriction>
>>>>>>>>>>> </xsd:simpleType>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> <xsd:documentation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:schema>
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
The Netherlands
Re: [Teneo] Exception using ManyToMany annotation [message #423419 is a reply to message #423390] |
Tue, 30 September 2008 09:38 |
Had not refreshed my newsgroup reader and missed the reply. Thanks it
works, am now in eCore nirvana, I can achieve both the db schema and the
generated source code I need to achieve my ends.
David
David
Ed Merks wrote:
> Martin,
> Comments below.
> Martin Taal wrote:
>> Hi David,
> container.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> where expected.
>>> regards,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> EList<Group>.
>>>> code?
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:element>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> unique="false"/>
>>>>> </many-to-many>
>>>>> </bag>
>>>>> Thx.
>>>>> David
>>>>> Martin Taal wrote:
>>>>>> Hi David,
>>>>>> Some other info:
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </id>
>>>>>>> unique="true"
>>>>>>> class="Address"/>
>>>>>>> </set>
>>>>>>> </class>
>>>>>>> </id>
>>>>>>> inverse="true"
>>>>>>> optional="true">
>>>>>>> column="personId"
>>>>>>> not-null="true"/>
>>>>>>> </join>
>>>>>>> </class>
>>>>>>> Thx.
>>>>>>> David
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi David,
>>>>>>>> for userrole itself
>>>>>>>> also
>>>>>>>> idbag is used), or
>>>>>>>> gr. Martin
>>>>>>>> David Wynter wrote:
>>>>>>>>> Hi,
>>>>>>>>> liking.
>>>>>>>>> Thx,
>>>>>>>>> David
>>>>>>>>> Martin Taal wrote:
>>>>>>>>>> Hi David,
>>>>>>>>>> gr. Martin
>>>>>>>>>> David Wynter wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Ended up with this
>>>>>>>>>>> <xsd:schema
>>>>>>>>>>> </xsd:restriction>
>>>>>>>>>>> </xsd:simpleType>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> <xsd:documentation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:attribute>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> <xsd:sequence>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> <xsd:annotation>
>>>>>>>>>>> </xsd:appinfo>
>>>>>>>>>>> </xsd:annotation>
>>>>>>>>>>> </xsd:element>
>>>>>>>>>>> </xsd:sequence>
>>>>>>>>>>> </xsd:complexType>
>>>>>>>>>>> </xsd:schema>
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Thx.
>>>>>>>>>>> David
Current Time: Thu Mar 28 16:37:14 GMT 2024
Powered by FUDForum. Page generated in 0.04745 seconds
