Home » Modeling » EMF » getting additional resources via customized reflective editor
getting additional resources via customized reflective editor [message #423121] Tue, 23 September 2008 14:48 Go to next message
Tristan Faure is currently offline Tristan FaureFriend
I am working on an custom EMF reflective editor where we the user will be
able to see models in "box mode" where he can navigate in each compartment
My plugin works good but i have a problem when a user do a "load resource"
in his model.
When i get Elements referenced i got proxy elements where the eResource
method returns null.
when i do a EcoreUtil.resolveAll(myRootObject) i can see additional
resources but i can't see contents and when i do load on these i have a
filenotfoundException :'(
the additional resources' URI format are "filename.extension" withno
platform information ...
if anybody can help me to obtain EObjects through the proxy it could be
very nice :)
Re: getting additional resources via customized reflective editor [message #423125 is a reply to message #423121] Tue, 23 September 2008 15:05 Go to previous messageGo to next message
Tristan,
The key to these kinds of proxy issues always turns out to involve me
asking the same basic questions. What is the URI of the resource being
loaded? What is the URI of the proxy within that resource? Then I
point out that the URI of the resource being loaded should be absolute,
i.e., file:/c:/..., http://..., platform:/resource/project/... and
remind folks that the relative URI within the resource will be resolved
against the absolute URI used to load that resource. I'll also ask what
the URI of each resource in the resource set looks like. The probably
look wrong...
Tristan FAURE wrote:
> Hi
> be able to see models in "box mode" where he can navigate in each
> compartment
> resource" in his model.
> eResource method returns null.
> a filenotfoundException :'(
> be very nice :)
Re: getting additional resources via customized reflective editor [message #423126 is a reply to message #423125] Tue, 23 September 2008 15:11 Go to previous messageGo to next message
Sorry i understand
so i'm working in a workspace
myRootObject.eResource().getURI() : "/test/test.uml"
EcoreUtil.getURI(myProxyObject) : "child.uml"
-ResourceSet before EcoreUtil.resolveAll(myRootObject) :
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl@7614d6
resources=[org.eclipse.uml2.uml.internal.resource.UMLResourceImpl@1262c96
uri='/test/Test.uml']
-after resolveAll
uri='/test/Test.uml',
org.eclipse.uml2.uml.internal.resource.UMLResourceImpl@1cd468c
uri='child.uml'
Ed Merks wrote:
> Tristan,
> look wrong...
>> Hi
>> compartment
>> be very nice :)
Re: getting additional resources via customized reflective editor [message #423127 is a reply to message #423126] Tue, 23 September 2008 15:21 Go to previous messageGo to next message
Tristan,
Comments below.
> Sorry i understand so i'm working in a workspace
This looks bad already. Use
URI.createPlatformResourceURI(iResource.getFullPath().toStri ng()) so
that you end with with platform:/resource/test/test.uml instead.
> -after resolveAll
> uri='child.uml'
> Ed Merks wrote:
>> Tristan,
>> being loaded? What is the URI of the proxy within that resource?
>> Then I point out that the URI of the resource being loaded should be
>> absolute, i.e., file:/c:/..., http://...,
>> platform:/resource/project/... and remind folks that the relative URI
>> within the resource will be resolved against the absolute URI used to
>> load that resource. I'll also ask what the URI of each resource in
>> the resource set looks like. The probably look wrong...
>>> Hi
>>> will be able to see models in "box mode" where he can navigate in
>>> each compartment
>>> have a filenotfoundException :'(
>>> be very nice :)
Re: getting additional resources via customized reflective editor [message #423129 is a reply to message #423127] Tue, 23 September 2008 15:34 Go to previous message
Thank you so much it was a problem when i loaded my model
Ed Merks wrote:
> Tristan,
> Comments below.
>> -after resolveAll
>> uri='child.uml'
>> Ed Merks wrote:
>>> Tristan,
>>>> Hi
>>>> each compartment
>>>> be very nice :)
Previous Topic:Does ID property have to be unique in the whole Resource?
Next Topic:EMF and Maps
Current Time: Sun Feb 23 21:35:21 GMT 2020
Powered by FUDForum. Page generated in 0.10175 seconds
