Re: [Teneo] How to model a map? [message #423061 is a reply to message #423054] |
Mon, 22 September 2008 14:36 |
Originally posted by: luzi.anderegg.ergon.ch
Unfortunately, I'm not allowed to post the whole ecore. Below you find
the parts containing the map:
<eClassifiers xsi:type="ecore:EClass" name="IntegerToToolPinMapEntry"
instanceClassName="java.util.Map$Entry">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="value"
eType="#//ToolPin"
containment="true"/>
</eClassifiers>
and the referencing class:
<eClassifiers xsi:type="ecore:EClass" name="ToolElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="inputPins"
upperBound="-1"
eType="#//IntegerToToolPinMapEntry" containment="true"/>
</eClassifiers>
Luzi
Martin Taal wrote:
> Hi Luzi,
> Yes maps should work. There are two ways in which Teneo can map maps:
> - as a list of map entries (key, value pair), in this case the hibernate
> mapping will have a list as the association
> - as a real map (so with a map tag in the hbm).
> If you set the option PersistenceOptions.EMAP_AS_TRUE_MAP to false
> (default is true) then Teneo will map your emap as a list.
> Attached you can find an example of an emap from the Teneo testcases.
> Can you post your ecore and the resulting hbm?
> gr. Martin
> Luzi Anderegg wrote:
>> I modelled a map in my ecore according to
>> http://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF .3F. If I
>> use this map in my program, a MappingException arises? Is there
>> anything special with maps and teneo? Do I have to annotate my ecore?
>> Regards,
>> Luzi
Re: [Teneo] How to model a map? [message #423064 is a reply to message #423061] |
Mon, 22 September 2008 14:58 |
Hi Luzi,
For my info, can you also post the relevant part of the mapping? And the stack trace of the
mappingexception?
gr. Martin
> eType="#//ToolPin"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> Luzi
> Martin Taal wrote:
>> Hi Luzi,
>> hibernate mapping will have a list as the association
>> gr. Martin
>>> Regards,
>>> Luzi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] How to model a map? [message #423070 is a reply to message #423064] |
Mon, 22 September 2008 15:07 |
Hi Martin,
here is the relevant part of the mapping (I hope):
<class name="xxxxxxxxxxxxxxxxxx.impl.ToolElementImpl"
entity-name="ToolElement" abstract="false" lazy="false"
discriminator-value="ToolElement" table="`toolelement`">
<meta attribute="eclassName">ToolElement</meta>
<meta attribute="epackage">http:///xxxxxxxxxxxxxx.ecore</meta>
<map name="inputPins" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="toolelement_inputpins">
<column name="`toolelement_inputpins_e_id`" not-null="false"
unique="false"/>
</key>
<map-key type="java.lang.Integer"/>
<one-to-many entity-name="ToolPin"/>
</map>
</class>
Gr.
Luzi
Martin Taal wrote:
> Hi Luzi,
> stack trace of the mappingexception?
> gr. Martin
>> eType="#//ToolPin"
>> </eClassifiers>
>> upperBound="-1"
>> </eClassifiers>
>> Luzi
>> Martin Taal wrote:
>>> Hi Luzi,
>>> gr. Martin
>>>> I use this map in my program, a MappingException arises? Is there
>>>> Regards,
>>>> Luzi
Re: [Teneo] How to model a map? [message #423073 is a reply to message #423070] |
Mon, 22 September 2008 15:14 |
Hi Luzi,
And can you post the mappingexception?
gr. Martin
> Hi Martin,
> not-null="false" unique="false"/>
> </key>
> </map>
> </class>
> Gr.
> Luzi
> Martin Taal wrote:
>> Hi Luzi,
>> the stack trace of the mappingexception?
>> gr. Martin
>>> find the parts containing the map:
>>> eType="#//ToolPin"
>>> </eClassifiers>
>>> upperBound="-1"
>>> </eClassifiers>
>>> Luzi
>>> Martin Taal wrote:
>>>> Hi Luzi,
>>>> gr. Martin
>>>>> Regards,
>>>>> Luzi
The Netherlands
FUDForum. Page generated in 0.03417 seconds
