Re: Generating ecore model code with maven or ant [message #422990] |
Sat, 20 September 2008 01:11 |
Ed Merks Messages: 33141 Registered: July 2009 |
Martin,
Please use the EMF newsgroup to ask about EMF's Ant tasks.
I'm not sure what to say about the failures. EMF's Ant tasks do require
installing the tasks and Eclipse in order to work properly, but I have
no idea how Maven invokes ant tasks differently from Eclipse... It just
sounds like you've not installed the tasks properly...
Martin Johansen wrote:
> Hello
> I am building a project using maven where I have an ecore model from
> which I want to build the model code automatically. i.e. I have a
> file called PSL.ecore and I want the sources build whenever I run
> maven package etc so that the correct dependencies are resolved etc. A
> quite common task in maven, that is.
> I have two problems:
> 1. The EMFgen plugin in the maven repository does not work
> (net.sf.mapasuta.build.maven.plugins.maven-emfgen-plugin), and it
> required the user to download the dependencies automatically, which is
> contrary to the maven philosophy. Hence I don't know any maven plugin
> which handles this.
> 2. I tried using the ant-tasks emf.Ecore2Java instead. The problem is
> that I get the error-message
> "Problem: failed to create task or type emf.Ecore2Java
> Cause: The name is undefined.
> Action: Check the spelling.
> Action: Check that any custom tasks/types have been declared.
> Action: Check that any <presetdef>/<macrodef> declarations have
> taken place."
> even though the emf.Ecore2Java is mentioned in the eclipse preferences
> as a possible option. This method would work if the ant task worked.
> I would be interrested in any solution which would allow me to
> automatically build the java model code from my ecore model, and then,
> especially with maven or ant.
> Thanks!
> - Martin Johansen.
Ed Merks
FUDForum. Page generated in 0.02948 seconds
