Home » Modeling » EMF » [CDO] best practice for 'getting' a resource
[CDO] best practice for 'getting' a resource [message #422972] Fri, 19 September 2008 17:30 Go to next message
Mark Geib is currently offline Mark GeibFriend
I have a slightly unusual problem that I am having trouble solving.
I have a model that is persisted with CDO. When I create an empty
database I call transaction.createResource() to create the resource...
When I subsequently access an existing resource I call
transaction.getResource() to get the resource... No problems except that
I need to provide the user with the ability to drop the database, create
a new one and the create the resource from scratch. I have not been able
to consistently 'get' the resource when I don't know whether the
resource has previously been created or not. That is I want to be able
to return a resource whether I need to create or just get the resource.
What is the suggested best practice here, for 'providing' a CDO backed
resource.?
Mark.
Re: [CDO] best practice for 'getting' a resource [message #422974 is a reply to message #422972] Fri, 19 September 2008 17:57 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Mark,
I think these two methods are the key:
- org.eclipse.emf.cdo.CDOView.hasResource(String)
- org.eclipse.emf.cdo.CDOTransaction.getOrCreateResource(Strin g)
They were added through:
217236: Provide a way to query if a specific resource (path) exists
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217236
Cheers
/Eike
> that I need to provide the user with the ability to drop the database,
> create a new one and the create the resource from scratch. I have not
> been able to consistently 'get' the resource when I don't know whether
> the resource has previously been created or not. That is I want to be
> able to return a resource whether I need to create or just get the
> resource.
> resource.?
> Mark.
Re: [CDO] best practice for 'getting' a resource [message #422976 is a reply to message #422974] Fri, 19 September 2008 18:20 Go to previous messageGo to next message
Beautiful Eike.
I guess I need to start reading release notes and the javadoc.
It just gets BETTER and BETTER..
Mark.
Eike Stepper wrote:
> Hi Mark,
> Cheers
> /Eike
>> resource.
>> resource.?
>> Thanks,
>> Mark.
Re: [CDO] best practice for 'getting' a resource [message #422985 is a reply to message #422976] Fri, 19 September 2008 20:16 Go to previous messageGo to next message
Eike,
I am not using getOrCreateResource() but I have a problem that only the
first session seems to work. If I create a new resource, then add an
object and save and exit, then run again I seem to get a resource but
the call to resource.getContents() always fails. If I drop the database
I can then create and access the resource, but never again.
I have also tried with the EnhancedEditor and the CDO launcher. If I
ONLY use the editor everything works fine, even subsequent access.
Mark.
Mark Geib wrote:
> Beautiful Eike.
> Mark.
> Eike Stepper wrote:
>> Hi Mark,
>> Cheers
>> /Eike
>>> resource... When I subsequently access an existing resource I call
>>> database, create a new one and the create the resource from scratch.
>>> I have not been able to consistently 'get' the resource when I don't
>>> know whether the resource has previously been created or not. That is
>>> I want to be able to return a resource whether I need to create or
>>> backed resource.?
>>> Thanks,
>>> Mark.
Re: [CDO] best practice for 'getting' a resource [message #422987 is a reply to message #422985] Fri, 19 September 2008 20:44 Go to previous messageGo to next message
Simon Mc Duff is currently offline Simon Mc DuffFriend
When you say it fails, what does that mean ?
Did you have an exception, stack trace, getContents is empty ?
Also which version of CDO are you using ?
The best would be to provide a testcase! :-)
Are you using Derby or Teneo as your database ?
Simon
Simon
"Mark Geib" <mark.geib@echostar.com> a
Re: [CDO] best practice for 'getting' a resource [message #422988 is a reply to message #422987] Fri, 19 September 2008 22:04 Go to previous messageGo to next message
Simon,
I am sorry for the false alarm. I honestly don't know what I did, but
when I went to reproduce for you...it all works.
I guess I should go home..
Sorry again,
Mark.
> Simon
> Simon
> "Mark Geib" <mark.geib@echostar.com> a écrit dans le message de news:
> gb11af$4n2$1@build.eclipse.org...
>> Eike,
>> object and save and exit, then run again I seem to get a resource but the
>> call to resource.getContents() always fails. If I drop the database I can
>> I have also tried with the EnhancedEditor and the CDO launcher. If I ONLY
>> Mark.
>> Mark Geib wrote:
>>> Beautiful Eike.
>>> Thanks,
>>> Mark.
>>> Eike Stepper wrote:
>>>> Hi Mark,
>>>> Cheers
>>>> /Eike
>>>>> resource.
>>>>> resource.?
>>>>> Thanks,
>>>>> Mark.
Re: [CDO] best practice for 'getting' a resource [message #422989 is a reply to message #422988] Fri, 19 September 2008 22:10 Go to previous message
I like false alarm!! :-)
Have a good evening!
Previous Topic:Mapping xmi:type to EMF type
Next Topic:Re: Generating ecore model code with maven or ant
Current Time: Thu Feb 20 13:27:51 GMT 2020
Powered by FUDForum. Page generated in 0.02278 seconds
