Home » Modeling » EMF » Creating EMF model from XML schema - special characters - com.montages.xml.zip (0/1)
Creating EMF model from XML schema - special characters - com.montages.xml.zip (0/1) [message #422900] Thu, 18 September 2008 11:53 Go to next message
Marc Moser is currently offline Marc MoserFriend
Member
I have a problem with some characters when creating an EMF model from
an XML schema. The relevant parts of the XML schema looks like this:
<xsd:complexType name="Questionnaire">
<xsd:attribute ecore:transient="true"
ecore:derived="true" ecore:volatile="true" ecore:changeable="false"
name="maxPoints" type="xsd:int">
<xsd:annotation>
<xsd:appinfo ecore:key="derive"
source="http://www.xocl.org/OCL">self.questions->collect(q: Query |
q.maxPoints)->sum()</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
</xsd:schema>
In particular, the OCL expression
self.questions->collect(q: Query | q.maxPoints)->sum()
gets transformed into
self.questions-&gt;collect(q: Query | q.maxPoints)-&gt;sum()
Now I understand that > is a special character in XML schema and that
it is correctly escaped using &gt; but I don't know what I have to do
in order to end up with > in the ecore. I tried escaping the > with
&gt; in my XML schema, but then I still end up with &gt; in the ecore.
Anyone has an idea?
Attached is simple project with the complete XML schema in it.
Best,
Marc
Re: Creating EMF model from XML schema - special characters - com.montages.xml.zip (0/1) [message #422924 is a reply to message #422900] Thu, 18 September 2008 19:25 Go to previous message
Marc,
Comments below.
Marc Moser wrote:
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:schema>
It should not matter. By the time you read it into memory it will be
the right character.
> Anyone has an idea?
You shouldn't worry about what it looks like in the *.ecore file, as
long as it's the correct character once it's read in. Any XML parser
will yield the correct characters from reading &gt...
> Best,
> Marc
Previous Topic:Can I generate enums mixed case?
Next Topic:CDO Adding a new resource
Current Time: Sat Feb 22 20:53:07 GMT 2020
Powered by FUDForum. Page generated in 0.03836 seconds
