Home » Modeling » EMF » Can I generate enums mixed case?
Can I generate enums mixed case? [message #422890] Thu, 18 September 2008 04:43 Go to next message
Bryan Hunt is currently offline Bryan HuntFriend
Is there a parameter to get my enums generated with mixed case instead
of all upper case? I tried setting both the name and literal to mixed
case hoping one of them would control the actual enum, but that didn't
work.
Bryan
Re: Can I generate enums mixed case? [message #422921 is a reply to message #422890] Thu, 18 September 2008 19:19 Go to previous message
Bryan,
No. It's a static final constant and so by Java naming conventions, it
really should be all upper case.
> work.
> Bryan
Ed Merks
Previous Topic:Forcing EMF code generation for EPackage that contain sub-EPackage only
Next Topic:Creating EMF model from XML schema - special characters - com.montages.xml.zip (0/1)
Current Time: Mon Sep 28 00:21:13 GMT 2020
Powered by FUDForum. Page generated in 0.02046 seconds
