Home » Modeling » EMF » [CDO] Listening to changes in a CDOResource
Re: [CDO] Listening to changes in a CDOResource [message #422617 is a reply to message #422605] |
Thu, 11 September 2008 11:02 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Hi Simon,
it think this handler might work. Thanks!
However, this seems like I'll get notified of events that would happen
within a specific transaction (the handler gets added to a transaction
through CDOTransaction.addHandler()). What happens if someone else
modifies my resource? Will I get notified? Furthermore, CDOView doesn't
have such handlers, which means that a view won't get notified of a
resource being changed.
> I think we should add
> public void detachingObject(CDOTransaction transaction, CDOObject
object);
> Will it fill your needs ?
> If yes, please open a bugzilla !
I think it would :D
Thanks!
Simon McDuff escribió:
> Hi Victor,
> You can start to look at CDOTransactionHandler.
> public void addingObject(CDOTransaction transaction, CDOObject object);
> public void modifyingObject(CDOTransaction transaction, CDOObject object,
> CDOFeatureDelta featureDelta);
> public void committingTransaction(CDOTransaction transaction);
> public void rolledBackTransaction(CDOTransaction transaction);
> Is it what you are looking for ?
> To be notified when an object is being detached...we don't have that.
> public void detachingObject(CDOTransaction transaction, CDOObject object);
> "Víctor Roldán Betancort" <vroldan@opencanarias.com> a écrit dans le message
> de news: ga938t$mti$1@build.eclipse.org...
>> Hi Eike,
>> I've been trying to obtain notifications from a CDOResource.
>> For instance, I would like to know when did the resource changes got
>> committed, to refresh some views we have, or even if the resource got
>> deleted.
>> I already tried out adding a new Adapter to CDOResource.eAdapters(), but
>> with no success.
>> Could you point me out which is the best way to achieve this?
>> Thank you very much.
>> ViK
Re: [CDO] Listening to changes in a CDOResource [message #422618 is a reply to message #422617] |
Thu, 11 September 2008 11:29 |
Víctor Roldán Betancort schrieb:
> Hi Simon,
Who is someone else?
Another local thread or a remote user?
The CDOTransactionHandler is really a local concept to intercept the
framework while local changes are happening or committed.
If you want to intercept remote changes you will want to use a change
subscription or the CDOSessionInvalidationEvent or the
CDOInvalidationNotification.
> Furthermore, CDOView doesn't have such handlers, which means that a
> view won't get notified of a resource being changed.
A resource attached to a CDOView can't be changed locally (CDOView is
read-only). You need a CDOTransaction to change a resource locally.
For remote changes my above explanations apply ;-)
Cheers
/Eike
> object);
> I think it would :D
> Thanks!
>> Hi Victor,
>> object, CDOFeatureDelta featureDelta);
>> object);
>> message de news: ga938t$mti$1@build.eclipse.org...
>>> Hi Eike,
>>> got deleted.
>>> but with no success.
>>> ViK
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Listening to changes in a CDOResource [message #422624 is a reply to message #422620] |
Thu, 11 September 2008 11:50 |
> Hi Eike,
> remote user.
> I already saw CDOViewImpl.subscribe(EObject, Adapter). Maybe that's
> what Im looking for. I'll try it out!
Yes, but don't use the CDOViewImpl class! Instead call:
CDOView.setChangeSubscriptionPolicy(CDOChangeSubscriptionPol icy.ALL);
And then just add adapters to your objects as usual.
You might want to optimze this later by specifying your own
CDOChangeSubscriptionPolicy.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] Listening to changes in a CDOResource [message #422636 is a reply to message #422624] |
Thu, 11 September 2008 15:03 |
Hi Eike,
I already notification work (found a possible glitch in
CDONotificationImpl... not sure though). However, what I get is not what
I actually expected.
I add the adapter to the CDOResource, and I only get notified of changes
in the CDOResource, not in their children. Listening to changes in the
whole object tree would imply adding an adapter to each object (usage of
EContentAdapter?), which doesn't seem feasible when the object graph is
huge, and specially, when they are store in a remote database, I assume
that would load locally the whole object graph locally, disabling one of
the best advantages of CDO: lazy loading.
Another solution is the initial indicated by simon, by just listening to
changes in transactions opened in the local machine, and ignore remote
changes. How does CDO act in the case a client tries to commit changes
over a resource that was already changed remotely? Invalidation
notifications?
Re: [CDO] Listening to changes in a CDOResource [message #422645 is a reply to message #422643] |
Thu, 11 September 2008 16:28 |
> de news: gabbvi$1l9$1@build.eclipse.org...
>> Hi Eike,
>> CDONotificationImpl... not sure though). However, what I get is not what I
>> actually expected.
> You are right.
> But, how it is useful to know an objects was modified when the client didn't
> load it.
....uhm, you are right. I would be more coherent to add adapters to this
objects only when loaded.
> Because what we could do is add an adapter automatically when it is loaded
> for every objects for a specific Resource. In some cases will be slow but it
> is feasible.
I think that would be a great idea! So it will be something like a
EContentAdapter, but with lazy self-adapt, right? This way we don't have
to take care of adding an adapter each time an object is loaded.
> Will it fill your needs? If yes please create a new bugzilla! :-)
I'll fill that bugzilla :D
>> notifications?
> When you talk about resource, do you mean every objects that is contained by
> the resource ?
Sorry, yes, I meant here "all the object graph under a resource".
> If isPassiveUpdate is turned on, the invalidation process will put objects
> into conflict
> If isPassiveUpdate is turned off, at commit time you will get an exception.
Good to know, thanks!
> If you want to fix the detach to be added in the interface please create a
> new bugzilla!
I'll do it!
> Thank you
Thank you!
Re: [CDO] Listening to changes in a CDOResource [message #422663 is a reply to message #422653] |
Fri, 12 September 2008 10:52 |
Simon,
the bug has been created.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247141
Thanks!
> I will wait for you bugzilla to start it!
> de news: gabgvl$qam$1@build.eclipse.org...
>>> message de news: gabbvi$1l9$1@build.eclipse.org...
>>>> Hi Eike,
>>> You are right.
>>> didn't load it.
>>> loaded for every objects for a specific Resource. In some cases will be
>>> slow but it is feasible.
>>>> notifications?
>>> by the resource ?
>>> objects into conflict
>>> exception.
>>> a new bugzilla!
>> I'll do it!
>>> Thank you
>> Thank you!
Current Time: Thu Apr 25 07:04:34 GMT 2024
Powered by FUDForum. Page generated in 0.04198 seconds
