Home » Modeling » EMF » [CDO] Transparent CDO integration into generated EMF editor
[CDO] Transparent CDO integration into generated EMF editor [message #422261] Wed, 27 August 2008 16:13 Go to next message
Originally posted by: andras.okros.optxware.com
Hi group,
I would like to ask, which is the easiest solution to integrate CDO into
a standalone EMF editor?
I store the CDO properties (repository, location, etc) in a separate xml
file, with them I can start/use the integrated CDOeditor, but instead I
would like to create a connecting layer (or sg) between the CDO
repository handling and a normal EMF editor. Is there any solution,
which allows the original (generated) EMF editor to be nearly (or fully)
intact?
Can you suggest what built-in CDO classes should I use?
Thanks a lot in advance
András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422272 is a reply to message #422261] Thu, 28 August 2008 09:20 Go to previous messageGo to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Hi András,
I went through the same problem. I evaluated several possibilities and
ended up doing my own editor generator. This generator provides a
CDO-Ready extension of generated EMF Editors, this means, that you can
have your customized editor, extended with the capabilities a
CDOResource needs to be managed. It's already working and I proposed
this it to be donated to CDO project. Eike seems to be willing to
evaluate it, but asked me to do some changes that would take me some
time (more precisely, shifting from JET2 to JET1).
Regarding other alternatives, I'm not sure if a Sample Ecore generated
editor would work by itself without enhancement with CDOResources
(haven't tried, though), but when I look at CDOEditor code, I suspect I
would be not possible right now. We discussed this recently, and it
would need some work regarding EMF's ResourceSet and URIHandler.
HTH,
Víctor.
András Ökrös escribió:
> Hi group,
> intact?
> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422274 is a reply to message #422272] Thu, 28 August 2008 10:47 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hey guys,
Vik, I was in hope that you would answer this question because I'm
currently over busy with some presentations. I already searched Bugzilla
but I think you only sent the code to me privately, right? Maybe it's a
good idea to broaden the audience by making the code available through
Bugzilla. This way we could receive valuable feedback much earlier.
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> Hi András,
> I would be not possible right now. We discussed this recently, and it
> HTH,
> Víctor.
>> Hi group,
>> into a standalone EMF editor?
>> xml file, with them I can start/use the integrated CDOeditor, but
>> instead I would like to create a connecting layer (or sg) between the
>> CDO repository handling and a normal EMF editor. Is there any
>> solution, which allows the original (generated) EMF editor to be
>> nearly (or fully) intact?
>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422275 is a reply to message #422274] Thu, 28 August 2008 10:57 Go to previous messageGo to next message
Hi Eike,
yes, I have only sent it to you privately, no bugzilla yet. It's fine
for me to submit the generator, but you have to know it's still using
JET2 instead of JET1. If that's still ok for you, then I'll proceed to
refactor the project and then commit it to a bugzilla.
ViK.
Eike Stepper escribió:
> Hey guys,
> Cheers
> /Eike
>> Hi András,
>> HTH,
>> Víctor.
>>> Hi group,
>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422277 is a reply to message #422275] Thu, 28 August 2008 11:31 Go to previous messageGo to next message
> Hi Eike,
If you're just changing the templates from JET2 to JET1 this should have
no major impact on the generated artifacts. So if András is willing to
preview the editor you could consider his feedback earlier if you file a
Bugzilla now. Personally I don't mind because I won't be able to look at
this before the next week.
Cheers
/Eike
> Regards,
> ViK.
>> Hey guys,
>> Bugzilla but I think you only sent the code to me privately, right?
>> Maybe it's a good idea to broaden the audience by making the code
>> available through Bugzilla. This way we could receive valuable
>> Cheers
>> /Eike
>>> Hi András,
>>> and ended up doing my own editor generator. This generator provides
>>> a CDO-Ready extension of generated EMF Editors, this means, that you
>>> can have your customized editor, extended with the capabilities a
>>> generated editor would work by itself without enhancement with
>>> CDOResources (haven't tried, though), but when I look at CDOEditor
>>> code, I suspect I would be not possible right now. We discussed this
>>> recently, and it would need some work regarding EMF's ResourceSet
>>> and URIHandler.
>>> HTH,
>>> Víctor.
>>>> Hi group,
>>>> separate xml file, with them I can start/use the integrated
>>>> CDOeditor, but instead I would like to create a connecting layer
>>>> (or sg) between the CDO repository handling and a normal EMF
>>>> editor. Is there any solution, which allows the original
>>>> (generated) EMF editor to be nearly (or fully) intact?
>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422278 is a reply to message #422277] Thu, 28 August 2008 11:51 Go to previous messageGo to next message
>> Hi Eike,
Ok, I'll do my best.
Cheers.
Victor.
> Cheers
> /Eike
>> Regards,
>> ViK.
>>> Hey guys,
>>> Cheers
>>> /Eike
>>>> Hi András,
>>>> and URIHandler.
>>>> HTH,
>>>> Víctor.
>>>>> Hi group,
>>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422289 is a reply to message #422275] Thu, 28 August 2008 15:19 Go to previous messageGo to next message
Hello Victor, Eike,
Thanks for the fast replies!
The bugzilla would be great, at least we can try it out, and give some
feedback about it.
András
Víctor Roldán Betancort írta:
> Hi Eike,
> Regards,
> ViK.
>> Hey guys,
>> Cheers
>> /Eike
>>> Hi András,
>>> and ended up doing my own editor generator. This generator provides a
>>> recently, and it would need some work regarding EMF's ResourceSet and
>>> URIHandler.
>>> HTH,
>>> Víctor.
>>>> Hi group,
>>>> the CDO repository handling and a normal EMF editor. Is there any
>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422342 is a reply to message #422289] Mon, 01 September 2008 14:57 Go to previous messageGo to next message
Hi everyone,
the bugzilla has been raised:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245836
Awaiting comments!
Víctor.
> Hello Victor, Eike,
> feedback about it.
> Best regards,
> András
>> Hi Eike,
>> Regards,
>> ViK.
>>> Hey guys,
>>> Cheers
>>> /Eike
>>>> Hi András,
>>>> and URIHandler.
>>>> HTH,
>>>> Víctor.
>>>>> Hi group,
>>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422498 is a reply to message #422342] Sun, 07 September 2008 19:44 Go to previous messageGo to next message
Mark Geib is currently offline Mark GeibFriend
Just posted a comment to bugzilla.
I would like to try the generator but I can't see to make it do anything.
I always get a error that says "The chosen operation is not currently
available."
Víctor Roldán Betancort wrote:
> Hi everyone,
> Awaiting comments!
> Víctor.
>> Hello Victor, Eike,
>> feedback about it.
>> Best regards,
>> András
>>> Hi Eike,
>>> to refactor the project and then commit it to a bugzilla.
>>> Regards,
>>> ViK.
>>>> Hey guys,
>>>> Cheers
>>>> /Eike
>>>>> Hi András,
>>>>> you can have your customized editor, extended with the capabilities
>>>>> a CDOResource needs to be managed. It's already working and I
>>>>> proposed this it to be donated to CDO project. Eike seems to be
>>>>> willing to evaluate it, but asked me to do some changes that would
>>>>> take me some time (more precisely, shifting from JET2 to JET1).
>>>>> this recently, and it would need some work regarding EMF's
>>>>> HTH,
>>>>> Víctor.
>>>>>> Hi group,
>>>>>> CDO into a standalone EMF editor?
>>>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422511 is a reply to message #422498] Mon, 08 September 2008 08:55 Go to previous messageGo to next message
Mark,
comments in bugzilla :)
ViK
> available."
>> Hi everyone,
>> Awaiting comments!
>> Víctor.
>>> Hello Victor, Eike,
>>> some feedback about it.
>>> Best regards,
>>> András
>>>> Hi Eike,
>>>> fine for me to submit the generator, but you have to know it's still
>>>> using JET2 instead of JET1. If that's still ok for you, then I'll
>>>> proceed to refactor the project and then commit it to a bugzilla.
>>>> Regards,
>>>> ViK.
>>>>> Hey guys,
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi András,
>>>>>> provides a CDO-Ready extension of generated EMF Editors, this
>>>>>> means, that you can have your customized editor, extended with the
>>>>>> capabilities a CDOResource needs to be managed. It's already
>>>>>> working and I proposed this it to be donated to CDO project. Eike
>>>>>> seems to be willing to evaluate it, but asked me to do some
>>>>>> changes that would take me some time (more precisely, shifting
>>>>>> from JET2 to JET1).
>>>>>> HTH,
>>>>>> Víctor.
>>>>>>> Hi group,
>>>>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422590 is a reply to message #422342] Wed, 10 September 2008 17:41 Go to previous messageGo to next message
Hello Victor,
Thanks for the generator!
We tried it out this week, and it works fine. If some glitch turns out
I'll let you know :).
András
> Hi everyone,
> Awaiting comments!
> Víctor.
>> Hello Victor, Eike,
>> feedback about it.
>> Best regards,
>> András
>>> Hi Eike,
>>> Regards,
>>> ViK.
>>>> Hey guys,
>>>> Cheers
>>>> /Eike
>>>>> Hi András,
>>>>> HTH,
>>>>> Víctor.
>>>>>> Hi group,
>>>>>> András
Re: [CDO] Transparent CDO integration into generated EMF editor [message #422592 is a reply to message #422590] Wed, 10 September 2008 17:55 Go to previous message
Hi András,
thank you very much for the feedback!
Feel free to raise any question/comments in the generator's bugzilla.
ViK.
> Hello Victor,
> Best regards,
> András
>> Hi everyone,
>> Awaiting comments!
>> Víctor.
>>> Hello Victor, Eike,
>>> Best regards,
>>> András
>>>> Hi Eike,
>>>> Regards,
>>>> ViK.
>>>>> Hey guys,
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi András,
>>>>>> from JET2 to JET1).
>>>>>> HTH,
>>>>>> Víctor.
>>>>>>> Hi group,
>>>>>>> András
Previous Topic:[Teneo] 0..* associations, how to fetch parent from child
Next Topic:XSD to ecore
Current Time: Fri Feb 28 06:41:24 GMT 2020
Powered by FUDForum. Page generated in 0.10166 seconds
