Re: xsd import/export [message #422015 is a reply to message #422014] |
Wed, 20 August 2008 12:07 |
Ed Merks Messages: 33141 Registered: July 2009 |
Gitanjali,
Comments below.
Gitanjali Punj wrote:
> Hi Ed,
> we have our own modeling framework with our own meta meta,
> meta models.
That's a lot of metas. Does it make your brain hurt? :-P
> Using the eclipse parser and its api we created
> import and export of cmof/emof xml file(xmi).
Not sure what you mean by "the eclipse parser". I suppose you means
org.eclipse.emf.ecore.xmi's ability to read and write .xmi files for
which *.ecore models exist.
> Now what changes will be required in the existing code/project so that
> on clicking export
Clicking it where? In the Generator when working with a GenModel?
> the meta/user models xml schema/xsd should be generated.
I'm lost in meta space.
> Because in cmof export what we did was:
> take our meta model then create and instance of cmof meta model
Even further lost in the metaness of it all...
> in that instance model the meta model was copied.
Wow. I could cry now.
> the instance model was then transformed into cmof xmi so that it maps
> to all the tags like <ownedmember>, <memberEnd> etc.
I am crying now...
> Is it possible to make some changes in the existing code or the
> implemetation for xsd schema is totally different from this.
I no longer have any idea what "this" really is. I'm scared to ask you
to explain further.
Ed Merks
FUDForum. Page generated in 0.03572 seconds
