Notification of cahnges in proxy elements [message #420659] |
Sun, 06 July 2008 21:35 |
Originally posted by: balutavasile.yahoo.se
Hi.
I am working on a gmf diagram editor and I try to do the following: I have
in one model A an element 1 and in a model b an element 2. The element 1
contains a reference to the element 2 that is in the other model b. If I
change the element 2, element 1 should be notified but it does not. I
tried to register a listener (EMF Adapter) with the instance of element 2
in the model A but it does not work. If element 2 is in the same model
with element 1 it works.
So any idea how proxy changes can notify elements in other resources? I do
not mean to go through the whole resource but just to register an element
in one resource(model) to listen for changes in another element existing
in another resource(model).
Thanks for the help.
Re: Notification of cahnges in proxy elements [message #420665 is a reply to message #420660] |
Mon, 07 July 2008 09:37 |
I know that only the element 2 is notified if it is changed but in this
case it does not notifies all its instances. It seems like there are two
instances of element 2 one associated with model A and one associated with
model B if i change the element 2 only the instance associated with model
B is notified since element 2 resides in it. But the proxy
address/identifier is the same for both instances since it is the same
element. The strange thing is that the instance associated with model A
updates also but it does not trigger its notifications. I do not know how
this gets done.
So my element 2 is referenced from different resources but this references
are (when loaded) instances of the same type with the same content. Their
proxy address/identifier is the same but it is not the same instance that
is registered with all models. It would have helped.
The problem is when the resources referencing element 2 are loaded.
Re: Notification of cahnges in proxy elements [message #420666 is a reply to message #420665] |
Mon, 07 July 2008 10:10 |
If this is difficult to understand then what I want is to notify all the
elements that reside in different models and containing the element 2.
When I set element 2 to the respective property in the containing elements
I tried to register an Adapter with that instance of element 2. This means
I have several adapters associated with element 2 in different models. But
these adapters are not all associated with the same instance because
element 2 has on instance in each loaded model. So if I change element 2
only its instance in the model it resides is notified. Not the other
instances.
I hope you understand what I mean by instance. It is like me being in
several places at the same time but not knowing of what happened to me in
one place. I know it sounds strange but this is what i have noticed while
debugging. I am not sure how it works and if this can happen. Somewhere
should be a setting to trigger notifications for all instances having the
same proxy address.
Re: Notification of cahnges in proxy elements [message #420687 is a reply to message #420671] |
Mon, 07 July 2008 20:31 |
Hi.
Interesting things you are telling me here. However I can not do what I
want. An object of element1 has a field name and a field containing a
reference to the element2 that resides in another diagram. The element2
has also a field name. What I want is that when changing the name of the
"real" element2 the name of the element1 should be set to that. This must
be done immediately without the user clicking in the diagram and in this
way triggering the getters that will resolve the proxies. The name setter
on element1 will notify all the viewers listening to it to update what the
user sees in the diagram so that part is covered.
I tried to register a ECrossReferenceAdapter to the resource set of
element1 but it does not work.
So what I need is that when changing the "real" element2's name all the
references to the "real" value should be identified and their adapters
notified. I see that ECrossReferenceAdapter has some methods for handling
crossReferences and InverseReferences(and I do not really understand what
that is), but I do not know how to use this class. Where should I hook it
and what method to override.
Re: Notification of cahnges in proxy elements [message #420692 is a reply to message #420689] |
Mon, 07 July 2008 21:14 |
Hi again Ed. Is you have noticed I an not well accustomed with emf
framework.
ED: Did you try to do the resolve all proxies thing?
No. I do not know how to do that. I have noticed that the getter for
element2 in element1 has something that does that(it is a generated
getter) but otherwise no idea where and when all proxies can be resolved.
ED: Did you try changing your logic for attaching an adapter such that it
responds to proxy resolves?
The problem is where should I attach the adapter? To element1, to whatever
instance of element 2(this is in many places) or to resource set. I have
actually tried all these but the adapter does not get notified.
ED: I imagine you might specialize the ECrossReferenceAdapter to override
notifyChanged to detect when an element2's field name is changed; be sure
to call super when you override this method since handling notification
via calls to selfAdapt is important. When you detect such a notification,
you could call getInverseReferences for element2 to find all the other
objects that are referencing element2.
Well the same problem where to attach this specialized adapter? To what
object? Should it be the resource set? Inside an item provider?
Re: Notification of cahnges in proxy elements [message #420721 is a reply to message #420693] |
Tue, 08 July 2008 17:03 |
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated NOT
public void setRequirement(Requirement newRequirement) {
Requirement oldRequirement = requirement;
requirement = newRequirement;
requirement.eResource().getResourceSet().eAdapters().add(new
ECrossReferenceAdapter() {
public void notifyChanged(Notification notification) {
// TODO Auto-generated method stub
super.notifyChanged(notification);
setName(requirement.getName());
if (eNotificationRequired())
eNotify(new ENotificationImpl(this, Notification.SET,
SysmlPackage.SATISFIES_PROPERTY__REQUIREMENT, oldRequirement,
requirement));
Well element1 is in reality a class called SatisfiedByProperty and
element2 is requirement in above code. My first idea was that when the
requirement is set to register an adapter to it here. And I am still stuck
on my idea because for the moment I can not see other alternative since I
do not have enough knowledge about the platform. Above is when I try to
attach it to the resource set of requirement.
As yo can see this code is generated from an ecore model and I have only
generated the model and edit code. The editor is generated with GMF.
The adaper is not populated since I wanted to see if it is notified if
attached in this way. It is not difficult for me to populate the adapter
but I need to find a place where to attach it. Or where to use resolve
all.
Re: Notification of cahnges in proxy elements [message #420725 is a reply to message #420721] |
Tue, 08 July 2008 19:16 |
Ed Merks Messages: 33141 Registered: July 2009 |
Vali,
Comments below.
> * @generated NOT
No, you'd use just new AdapterImpl. An ECrossReferenceAdapter attaches
itself to an entire tree of objects so this code is brutal. You'd also
need to worry about removing the adapter from oldRequirement. And as we
discussed already, you'd need to worry about change the adapter from
listening to the proxy to listening to the resolved object (which
happens in the getRequirement method.
> @Override
Is the name feature itself transient (so that it isn't serialized)? Is
the name feature derived (so that it isn't copied)?
> requirement));
> stuck on my idea because for the moment I can not see other
> alternative since I do not have enough knowledge about the platform.
> Above is when I try to attach it to the resource set of requirement.
You'd need a normal adapter. You'd need to be sure to remove the
adapter from the old requirement and set it to the new requirement every
time set is called. And you'd have to ensure you do the same thing when
the proxy is resolved. Another way you might do that is attach an
adapter to the "this/element1" object itself and listen for changes to
the "requirement" feature, i.e., pay attention to SET and RESOLVE
notifications and attach the element2 adapter to the new value and also
remove it from the old value.
> only generated the model and edit code. The editor is generated with
> GMF. The adaper is not populated since I wanted to see if it is
> notified if attached in this way. It is not difficult for me to
> populate the adapter but I need to find a place where to attach it. Or
> where to use resolve all.
If you want all this to happen directly in the model itself, what I'd
probably do is override eNotificationRequired to return true, so that a
notification is always produced, override eNotify (the same way as if
you'd attached an adapter to "this") to monitor notifications for the
"requirements" feature (being sure to call super), and then using
notifications on the "requirements" feature to add and remove the
adapter you attach to the requirements feature (and to copy the name
over at the time the requirements feature changes).
Something like this:
protected Adapter adapter =
new AdapterImpl()
// Pay attention to the name feature
public boolean eNotificationRequired()
return true;
public void eNotify(Notification notification)
if (notification.getFeature() ==
YourPackage.Literals.ELEMENT1_REQUIREMENT)
switch (notification.getEventType())
case Notification.SET:
case Notification.RESOLVE:
RequirementoldValue = (Requirement)notification.getOldValue();
if (oldValue != null)
oldValue.eAdapters().remove(adapter);
RequirementnewValue = (Requirement)notification.getNewValue();
if (newValue != null)
oldValue.eAdapters().add(adapter);
// set the name...
break;
super.eNotify(notification);
Ed Merks
Re: Notification of cahnges in proxy elements [message #420727 is a reply to message #420725] |
Tue, 08 July 2008 20:58 |
Finally. It works.
Is it a standard way to attach/detach adapters in eNotify?
I did not need to override eNotificationRequired. Just overrided eNotify
in element1 and of course used an adapter.
Thanks and I hope I did not ruined your days. :)
Re: Notification of cahnges in proxy elements [message #420728 is a reply to message #420727] |
Tue, 08 July 2008 21:15 |
--------------040800070102090506080905
Vali,
Comments below.
Vali wrote:
> Finally. It works.
Part of this is just kind of a tricky way for an object to listen to its
own notifications without having to attach an adapter. If you look at
EContentAdapter, which is an adapter that maintains itself on all
objects contained in the tree and hence has to add to new ones that are
attached and remove from ones that are detached, it has much the same logic:
Notifier oldValue = (Notifier)notification.getOldValue();
removeAdapter(oldValue);
Notifier newValue = (Notifier)notification.getNewValue();
addAdapter(newValue);
break;
> eNotify in element1 and of course used an adapter.
Keep in mind though that eNotify is called if and only if there is an
adapter listening, so you'd be best to override it to ensure that it's
always called since you are relying on it always being called.
No. You'll have to try harder next time. :-P
<html>
<head>
http-equiv="Content-Type">
</head>
Vali,<br>
<br>
Comments below.<br>
<br>
Vali wrote:
<blockquote
cite="mid:957196721955ed96808a349d7c4ff931$1@www.eclipse.org"
type="cite">Finally. It works.
<br>
<br>
Is it
Ed Merks
FUDForum. Page generated in 0.04970 seconds
